Question about Philips Magnavox DVD/VCR Dual Player
Magnavox VCR/DVD recorder model ZV450mw8. VCR plays a tape for 6 seconds then shuts the whole unit down.
  • siggy3931 Apr 05, 2009
    I have the same problem, turns out mine is overheating. The fan is not turning at all when powered up.
  • smystic57 Apr 05, 2009
    am having problems with the VCR when I try to playback recorded tapes or any prerecorded store bought tape. It was running fine then after power went off and then back on it started having problems. You put a tape in and it seems to work fine but then after the count of 5-6 on the counter it will shut off the entire system. You have to turn back on the power to the whole thing. I thought maybe the VCR heads were dirty so tried a cleaner but it too will only run till count of 5-6 and do what happens with tapes. I tried turning on power and running the cleaner from where it stops but that get me no where. The DVD player works fine it is hjust the VCR side that is giving us problems. I was hoping to find my manual to see if it had something I could do but we have lost it somehow in the changing of things in house. I also wanted to know if I can use the DVD recorder to tape shows important to us and what type of DVD-R/RW is best or not good to use? Can anyone help me with either trying to trouble shoot the VCR problem, answering the question on DVD, type of DVD-R or getting a copy of the manual?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 173 Answers
You will need a technical person to open the unit. This problem can be as simple as a dirty sensor, or bad tape drive parts, or burned out computer chip.
Posted on Feb 03, 2009
Lost manual for DVD Recorder/VCR ZV450MW8 Need instructions to copy DVD Disk to VDD Disk or e-mail manual
To dub a DVD, first press Setup on the remote. Then select Recording (use the Up/Down arrows and then press OK). Navigate to and select Dubbing Mode. Select the direction for the duplication. Then press Setup to leave the Setup menu. Then press DVD to ensure that the unit is ready to play the DVD. (Press VCR if you are dubbing a video tape.) Then Press Play to advance to the section that you wish to duplicate, if needed, and then press Pause. (Press Pause a bit early; the dubbing process will lose about 5 seconds.) Now, press the other Mode button (VCR if recording to tape, DVD if recording to DVD). Next press D.Dubbing on the recorder or the remote. (The button is to the right of the Channel Up/Down buttons on the recorder. It's near the bottom left on the remote.) Press Stop when the section to be duplicated has been played in its entirety.
The Magnavox ZV450MW8 was manufactured by Funai with the Magnavox name. Thus Funai Service has the manual available: http://www.funaiservice.com/manual2012_search2.php . The direct link is http://www.funaiservice.com/manuals/MAGNAVOX/ZV450MW8/ZV450MW8.pdf . The directions for dubbing a DVD to VCR or vice versa start on page 48. Note: copy protected items cannot be duplicated.
I hope this helps.
Dec 10, 2014 | Televison & Video
When I insert a vhs tape into the turned on Magnavox zv450mw8 recorder it then shuts off, what goes
There are many delicate nylon parts in VCR's, they are usually the first to break, that is one possibility. The covers come off these pretty easily but I would pick it up and shake it first to see if something is rattling around inside, if you can hear something moving around in there and if it isn't something a child pushed inside (this often happens) then it is probably toast as it is more expensive to have fixed than it is worth. One other thing that is possible is that there is buildup on the capstan or tape guide rollers which can be sticky and wrap the tape around themselves and the machine will kick the tape out. If you are at all handy you could take the cover off, (FIRST MAKING SURE IT IS UNPLUGGED), plug it back in and insert a tape. As you watch the tape you can see at which stage of the cycle the tape backs out and maybe see the problem. As you can see many problems are possible, best to get another machine.
Jun 03, 2014 | Magnavox ZV450MW8 DVD Recorder VCR
Magnavox ZV450MW8 shuts off when trying to rewind.
Unplug the machine and pick it up and shake it, this will tell you if something is in there that shouldn't be or that something broke off.
So many things could be wrong that it is probably not worth fixing if it is not a foreign object inside.
May 15, 2014 | Magnavox ZV450MW8 DVD Recorder VCR
The tape pops back out
The loading mechanism has to seat the cassette in the play position. In this case the mechanism is unable to do this. If you cannot get any cassette to load, the vcr may be shot. It probably could be repaired but you would have to consider cost
Jan 06, 2013 | Magnavox ZV450MW8 DVD Recorder VCR
Magnavox vcr/dvd combo the vcr part only plays for 8 seconds
What you have is called a transport problem in the VCR unit--the mechanism is either jammed or something in it that loads the tape is bad.
Every time it is used it cycles to self check the mechanism--if it fails it is usually a belt bad or a gear assembly not working.
Someone would have to open unit to see what is happening.
May 28, 2012 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox ZV450MW8 shuts off within 10 seconds of being turned on
The problem is in the power supply, one or two capacitors fail and sometimes have a slight puff at the top, need to be replaced.
Mar 18, 2012 | Magnavox ZV450MW8 DVD Recorder VCR
Magnavox ZV450MW8A DVD/VCR Recorder Dubbing.
I bought a ;magnavox dvd disc and cassette recorder combo.
I am having trouble with setup items? I get nothing on the screen to select from?
Oct 24, 2009 | Televison & Video
Magnavox zv450mw8 Walmart VCR/DVD recorder. shuts off
on vcr's if the tape is hard to turn the tape will sense this and reject the tape. Try to get a tape that you can feel turn free eaiser. I would rewind it to the middle of the tape so each side is equal and it would make the tape run easier. If it runs ok then the unit is bad and is too sensitve to the pull on the tape. This is all designed in the electronics and there is not much you can do about it then get return it if you can.
Jan 01, 2009 | Philips Magnavox DVD/VCR Dual Player
I want to copy my VHS tape to a DVD
you should just have to hit the dubbing button on the front of the unit. Make sure you hit stop on both the vhs and the dvd sides. I found that in certain conditions it won't dub.
VCR problems
My solution was to call my warranty company. I'm sending it in and getting my money back. They said it would cost more to fix it than I paid for it.
Nov 10, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Philips Magnavox DVD/VCR Dual Player Logo
627 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
