Question about Epson Stylus RX500 All-In-One InkJet Printer
I have an Epson rx500 and I cannot get it to turn on. When I push the on button, the exclamation point lights up.
  • ljhinze Feb 03, 2009
    My printer just did the same thing...
    Problem Solver:
  • 17 Answers
Have you tried pressing the Load/Eject button?
Posted on Feb 14, 2009
Epson Stylus Photo RX500. I was cleaning print head when I got "printer error" message. The load eject light is on. I've unplugged printer, turned it on and off. no luck. solutions?
Press all these buttons:
Power+Load/Eject+Stop+B&W+Color
When printer turns ON, "Init eeprom" appears
Release and Press the Color button.
Jan 06, 2010 | Epson Stylus Photo RX500 Printer
Our epson stylus rx500 printer has been saying ERROR: Printer Error --> See documentation & call for support
this means that you may need a reset your ink waste counter. try to perform this
For the RX500 - Hold down "clear + setup + on"
continue to hold the buttons until the printer had powered on, then off again, then back on. Once I noticed that the LCD had flashed a blank screen, I let go of the 3 keys. In the LCD window I was given access to 3 options using the select keys.
The first had something to do with calibrating the scan light, the second option said "startup." The 3rd did the trick. An abbreviation resembling "ink pad level" was what I was looking for. Here is where I forget what I did... I think that I pressed "OK" on the keypad,. It did nothing. Then I think that I held down the clear button for around 10 seconds. When I let go of the clear button, the LCD read "Press Power to Reset." All better now!
post me a review should this work sir / ma'am coz it did for me
Sep 23, 2009 | Epson Stylus Photo RX500 Printer
Scanner error
Press the On button to turn off the Stylus Photo RX500. Unlock the transportation lock. Make sure that all packaging materials have been removed. Turn on your Stylus Photo RX500 again. If the error message still appears, call Epson so they can replace your printer.
Goodluck.
sherlyn C.
May 23, 2009 | Epson Stylus Photo RX500 Printer
When turned on only copy button lit and a red exclamation lighton
Hi
Try unplugging it and check for specks of paper inside the printer, then try to replug it from outlet and turn it back on. try if it will copy then try printing. Hope this helps
Dec 12, 2008 | Epson Stylus RX500 All-In-One InkJet...
Turning on the device ERROR
Try resetting the EEPROM
Turn the printer off.
Hold down the Stop, B&W, and the Color buttons.
Press the ON button.
The LCD screen should flash 3 times.
Release the Stop, B&W and Color buttons
Press the Color button again.
Then turn the printer off and back on.
Nov 01, 2008 | Epson Stylus RX500 All-In-One InkJet...
Epson Stylus RX500
Turn printer off.
Sep 17, 2008 | Epson Stylus RX500 All-In-One InkJet...
Cannot get LCD screen to show Replace Ink message
try this
1. Make sure your unit is powered and not printing.
2. Press the SETUP button and then use the select arrows until you see REPLACE INK, then press the COLOR COPY button. The ink cartridges will move to the replacement position.
3. Lift up the unit's cover, to access the ink cartridges.
4. Pinch the tabs on the front and back of the cartridge, and lift it out of the printer.
5. Before removing the new cartridge from it's package, shake the cartridge 4-5 times. Do not shake the cartridge once it has been removed from the cartridge holder.
6. Lower the new cartridge into its holder, then press down on the top of the cartridge until it clicks in place. Caution: Don't touch the green circuit board on the back of the cartridge, as you may inhibit normal operation and printing.
7. Repeat steps 4-6 for any other ink cartridges that require replacement.
8. Once complete, please lower the scanner and press it down until it clicks into place. The EPSON Stylus RX500 begins charging the ink delivery system.
The On light flashes and the EPSON Stylus RX500 makes noise. Charging takes about 30 seconds. When it's finished, the On light stops flashing and stays on steady. At this point press COPY to move back to COPY mode.
Caution: Never turn off the EPSON Stylus RX500 while the On light is flashing, unless the Stylus RX500 hasn't moved or made noise for more than 5 minutes.
May 20, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson rx500
Ensure that all the plugs are connected correctly
Jan 27, 2008 | Epson Stylus RX500 All-In-One InkJet...
Epson Stylus RX500 All-In-One InkJet Printer Logo
186 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
