I loaded the load and the water filled it but it will not start.
I have turned it on and off, unplugged it, switch the breaker on and off. When I turn the load size button you can hear a little water run letting me know it's on but it will not start washing the clothes.
  • cyahna24 Feb 02, 2009
    i have the same problem,funny and it happen today as well. The washer will not stop filling up and the water is flooded my laundry room. I trie to set the load on x-small, but the water filled up to the top and I have to turn the machine off.
  • 15,935 Answers
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Why dose water keeps filling wash when off oasis he 27082 top load
The timer turns the water on to fill, the pressure switch turns it off. If the water contacts are welded together (can happen over time) then the water solenoid will be on all the time. Easy way to check. Unplug the unit, then remove the electrical plug from the water valve (hot or cold depending which one is causing the issue) plug unit back in. If water stops filling the timer is bad. If the water does not fill then the timer is fine, but the water valve solenoid is bad.
Jul 29, 2014 | Kenmore Oasis HE 27082 Top Load Washer
No water is coming on at the start of the cycle
check hot & cold hose , take off hose from washer . Put in bucket open water coming or not .
Apr 18, 2017 | Amana ALW895 Top Load Washer
Water sensor not working. Started a load of Laundry and the water did not shut off therefore flooding my whole Laundry room. How can I fix this myself?
Their are 2 possibilites causing it to overflow
1) the water inlet valve that the hoses from the house plumbing attach to is sticking open,when it sticks it will stick open regardless if thier is power to the machine or not,so to determine if that is the problem,start the washer and quickly unplug or turn off circuit breaker ,if the water continues to fill, that valve is sticking,it is what to replaced
2) the water level switch is defective,do the same as far as starting it,if the fill stops when power disconected it's the water level switch that is in need of replacement
Good luck, i hope this helps
Gene
Jul 31, 2011 | GE Spacemaker Washer and Dryer Electric...
The washer will start a load of laundry then about 1/2 way through the cycle shuts off and LF show where the time is shown for the load to be finished, this does not matter what size or type of load is...
LF Error code: LF stands for long fill and occurs when the water level does not change for a period of time after the valves are turned on.
All washers are designed to operate with a water supply pressure of 20-100 PSI. When the pressure drops below 20 PSI the washer can have the following problems:
* Slow Fill- low water pressure reduces the speed at which water flows into the machine.
o Verify the pressure at all other water sources in the house (i.e. sinks, showers, etc..). If you find other places where the pressure is low, the problem is not with the machine but with the water supply.
* Continuous Fill- The valve may not fully seat under 20 PSI which would allow for a constant flow even when the machine is not supposed to be filling.
o Contact the water company to verify the pressure being supplied to the house.
* dispenser- Needs a minimum amount of pressure to function. May dispense constantly, at the wrong time, or not at all.
o A plumber may need to be consulted if the pressure is found to be too low.
Things you can check :
* Are the Hot and Cold water faucets turned on
* Are the water hoses kinked
o Make sure all the hose are straight and able to flow water
* Are the screen inside the water valve plugged
o Inlet valve should be free of debris and rust.
o Turn off water and remove the inlet hoses from washer.
o Remove any accumulated film or particles.
o Assure rubber washers are in the end of each inlet hose.
o Reinstall hoses, turn on water and check for leaks.
Error codes can be caused by a Power Surge or other electrical anomaly,attempt to return the washer to operation by following the Hard Reset procedure below.
1. Unplug or turn the circuit breaker off for 30 seconds.
2. Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
3. Press the Pause/Cancel/Stop button twice to clear the display.
4. Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts
Please rate my solution if it was at all helpful.
Thanks, Repairman45.
Dec 17, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Have Kenmore top loading washer stock #24771 and it won't fill with water. Checked water lines and not clogged. What else could be the problem?
Other than water lines being clear, faucets turned on, and the strainers are clear (strainers are located right were the hoses connect to the washer), you are looking at a load size switch or a water level sensor failure. A tripped GFI may also be the culprit, as can a tripped circuit breaker.
Both are easily accessible, since they are located in the top part of the washer, in the control panel area.
You might try cycling the load selector switch back and forth, "clean the contacts so to speak". If it starts to work then, you will need a load switch assy soon.
Sears can print you out a diagram of your washer for assembly, and parts. If you have the full model #, you can plug it in at searspartsdirect.com
Sep 21, 2010 | Kenmore Washing Machines
Whirlpool ultimate II water level problem
does it still fill when you unplug? if it does then the fill valve is no good.if it turns off the check your hose going to pressure switch.will be a small clear hose going from tub to your pressure switch.
Nov 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
GE Adora front load washer overloaded now won't start
Washers - Resetting Electronic Controls on a Washer
If there is a pause in the washer cycle, the controls will lock up. The pause can occur because of a power failure or it was put in the test mode at the factory.
Also, if the washer was stopped before the cycle was complete or the consumer has pushed the stop/pause button to temporarily stop the cycle and the cycle is not reset. Over a period of 24 hours, the washer will pump out and spin, but will stay in the final spin.
To correct the situation, shut off the circuit breaker for 30 seconds or unplug the washer, then turn the timer knob around and back to any position other than final spin. Verify the water is turned on and restore power. This should resolve the issue.
Apr 23, 2008 | GE WSXH208A Front Load Washer
Washer stops, won't fill, rinse or agitate
Check the lid switch. When you open and close the lid, you should hear a click. If you don't, then it's probably bad. You can test it for continuity with a multimeter. When the switch is activated, you should get a meter reading; if you don't it needs to be replaced.
Here is a picture of the switch assembly.
Mar 29, 2008 | Washing Machines
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
