Question about Hitachi 50V500 50 in. HD-Ready LCD Television
My Hitichi tv will not turn on. When the power button is pushed, the lights come on as if it was going to turn on. Then, the lights begin to flash as if the tv was turned off. After the lights stop flashing, the lamp light stays lit.
  • 11,896 Answers
This is known to happen. You could let it cool down for an hour. If it still persists, then it will need to be fixed.
You can also try unplugging the tv set for at least 4 hours to do a "hard reset"
Posted on Feb 01, 2009
  • Nate Stansfield
    Nate Stansfield Feb 01, 2009
    Sorry, we some how got disconnected from live chat, but we can communicate through here.
    Try letting cool down, or unplugging for 4 hours to reset.
    I am sure you will have to have the power supply replaced.
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
I need the code to set up my tv using at&t uverse remote, and the tv has no power button
  • Make sure that you have turned on the tv before you begin programing your Uverse remote control.
  • Hold down the TV button on the Uverse remote. (If you are trying to program a different device, hold down the button that names that device). As you are holding the TV button, press and release the OK button. You know you have done this right when all the mode keys flash twice.
  • Find the 4 digit code for your device
  • At this point, the TV mode button should flash three times. Try to turn the TV off by pushing the power button. If it does not turn off, try a different code. The manufacturer of your TV has many codes.
  • If none of the codes for your device work, try manually searching for a code. Go back and repeat steps 1 and 2. Then enter 922. Hold play as the remote cycles through various codes. When your TV turns off, push enter.
    ---------------------------------------------- Sharp TV codes for at&t remote: 1004, 1009, 1011, 1025, 1064, 1077, 1078, 1081, 1097, 1099, 1153, 1157, 1274, 1298, 1311, 1312, 1362, 1375, 1378
    Jan 24, 2011 | Sharp 27R-S50 27" TV
    MY Sharp LC46D62U wont turn on
    Power and OPC LED lights flashes?Common on Sharp LCD tv.Tv is still useable.Tv have Tuner signal board problems.Every times Power and OPC LED lights flashes.Just push the remote power button again and wait.Sometimes Power and OPC LED light will flashes require push power again wait again Power and OPC will flashes two or three time push power button and wait.Must do this two or three time before the backlight will light up and tv work.
    Jan 07, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
    Tv wont turn on used it for two months and one day it turns on then the power led light flashes and the opc led light ...
    This tv still under warrenty?Yes take ur warrenty repair.This problems very common on Sharp LCD tvs.I have one too.This tv have a Tuner signal board problems.But this tv still use able.Just push power button again after the POWER and OPC flashes.POWER and OPC some will flashes again and wait just push the power button again and wait.Sometimes have to push power buttons and wait power button push out of three or four times power button push POWER and OPC flashes.Than tv will work again.
    Jan 06, 2011 | Sharp LC-52D64U 52 in. LCD HDTV
    Turning on the monitor
    Could the batteries in the remote be dying. Did you try changing them?
    May 31, 2009 | Soyo DYLT032D 32 in. LCD Television
    Reprogramming to my symphonic tv
    What is the brand name of the Remote? You might be able to download or print off a manual from the manufacture's website, if they have one. but try this first, turn the TV on and push the code search button (If there is one) and press the TV button and aim it towards your TV, this should make the remote begin searching for the codes. If that doesn't work, try this, push and hold the code search button, usually the light above or below the button flashes 3-4 times then stays on, then push the TV button, it should flash once and then also stay steady, next input the code for symphonic, they are:
    0906, 0520, 0324,0247, and 0004. Enter each 4 digit code and wait for a response. Usually the TV will trun off after the correct code is pushed. Sometimes you have to push the TV button again to complete the programming.
    May 01, 2009 | Televison & Video
    Light flashing and tv won't turn on
    you might want to have the power transformer checked to make sure its working correctly.sometimes when they go bad all you get is the flashing light
    Oct 22, 2008 | Mitsubishi WS-55513 55" Rear Projection...
    Hi there, I have a Mitsubishi HDTV 1080 and when I tried to turn it on the tv this morning it wouldn't turn on and the power light is flashing green. I pushed in the reset button but it just keeps flashing and still won't turn on.
    Oct 05, 2008 | Mitsubishi WS-55513 55" Rear Projection...
    Timer light is flashing but tv wont turn on!
    When the timer light stoped flashing the remote control would not turn on the TV. The next time the light quit flashing I held the power button in on the TV for about 5 seconds and it came on and has had no problems since then with the remote or the local TV power button.
    Greg Allen
    Aug 29, 2008 | Mitsubishi Televison & Video
    Hitachi 50V500 50 in. HD-Ready LCD Television Logo
    146 people viewed this question
    Top Hitachi Televison & Video Experts
    Jaime Hernandez
    Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
