Question about RCA HD52W59 HDTV Projection Television
Rca HD52W59YX36 Hello, My TV (RCA rear projection HD52W59YX36) will not bring anything up on its screen or have volume. When you turn it on, the green power light will come on, blink,(and you here a click like its going to power up). it will do that 3 times and then its done. I have tried unplugging it for 5 or more minutes and nothing changed. And help?
  • afreed33 Feb 02, 2009
    Thanks alot, I will get those parts ordered.
  • afreed33 Feb 12, 2009
    I have just got done installing the flyback and still the same problem. I went ahead and then installed the cp150 and the cp114 and the cp120. Still same problem. None of the things i changed were warped on top. Does anyone know what might be the problem? When you turn it on, the green light comes on, you hear a click from the back and then you hear a sound kinda like static electricity (like when some tvs turn on or off). then the green light goes off. It does this three times and that is all it does. Anyone have any advice?
  • RCA Master
  • 8,617 Answers
Thats the error for a bad flyback You will need to replace the flyback #259296 and also CP150 you can get replacement flyback and cp150 at the following link and they provide free installation instructions with pictures so you can easially do the repair yourself.
http://servicemanuals.vstore.ca/
Posted on Feb 02, 2009
  • Sonny Berry
    Sonny Berry Feb 02, 2009
    If you get them through the site I posted you will be extremely happy with the instructions and the tech support read the reviews on the flyback on the site
My tv starts scrolling through video modes,and the menu screen constantly flashes on and off and i turn up the volume and it goes back down by itself,any thoughts how to stop this would be very helpful...
Thats caused by the Small signal board. which is the green board on the right side with all the inputs on it. Thats a very famous issue for RCA rear projection models.
Nov 07, 2012 | RCA HD52W140 52" Rear Projection...
How do I adjust the convergence properties on an RCA rear projection tv?
Normally on the RCA rear projection TV's you would bring up your menu and choose the Setup menu, then press OK on the remote. That menu would then have Convergence as a choice. Once that was chosen the next menu would give you the choice of either letting the TV run it's own Autoconvergence program, or you would select either Red or Blue convergence.
Choosing Red Convergence would bring up a Yellow cross-hair in the middle of the screen. If the Convergence was not correct you would see separate Green and Red cross-hairs. Once they were perfectly aligned you would again see one Yellow cross-hair.
Choosing Blue Convergence would bring up a Blue cross-hair in the center of the screen. If the alignment was out you would see 2 Blue cross-hairs. Using the Up and Down and Left and Right cursor keys you would adjust the alignment until a single solid Blue cross-hair was in the center of the screen.
May 15, 2011 | RCA Televison & Video
TV does not power up
I have mits 35" CS 3505 will not turn on... just turned off and thats all she wrote,,, what is the estimate cost of the deflection circuit board
thanks
artie
Jul 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 52" rear projection tv (P52926) volume control LOCKED!!!
This can be a tricky one, I would check the 5 and 3.4 volt lines first with a DVM (analog meter will not due) then with a scope to see what the voltages are and what they look like. A bad cap on the rail for the e-prom can cause this or the eeprom may be bad, this also happens. It might be best to contact a scv. co. as you can a lot more problems in that area if your not familiar with it.
Feb 26, 2009 | RCA P52926 52" Rear Projection Television
RCA projection tv is blue and fuzzy
may be convegence try turning down the blue screen and see that that does see if the picture clears...
Feb 04, 2009 | RCA Televison & Video
Access Service menu
Hey there!
Its really easy to do, but write down any settings before you go changing them..
1. Turn off tv.
(use buttons on tv for this)
2. Push volume down and channel down both at the same time, and hold them for about 10 seconds, or until the tv turns on.
Jan 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Question
have convergence rebuilt........
Jun 01, 2008 | RCA HD52W56 52" Rear Projection HDTV
52" RCA Rear Projection.
This will require tech repair.. the processor is dectecting problem. does the green light flash?
Nov 17, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P61927 61 in Rear Projection Television
Hello, Replace U14501. (Maybe) Best regards, Arpi
Apr 22, 2007 | RCA P61927 61" Rear Projection Television
RCA HD52W59 HDTV Projection Television Logo
142 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
