Question about Oreck XL2600 Vacuum
I put a new belt on my oreck xl and it is burning through why?
I put a new one on it and it burnt through and then I put another new one on and it has that same stinky burning smell. I did not buy these belts from oreck-could that be one of the problems? Why is it burning belts?
  • alh720 Feb 02, 2009
    I have the same problem, but the roller is spinning well. I turn the vac on while upside down and check to make sure it is. Sometimes stuff gets hung under the belt and makes it burn. That happened and I changed the belt and smelled worse and then burned completely in half. I have checked the roller and the entire air flow to make sure it is not jammed and nothing is under the belt. Can the roller be put back in wrong? Contrary to what I have read under the belt changing directions, I have NEVER been able to change the belt without removing the roller. I have used Orecks for about 30 years and never had this problem before.
  • alh720 May 11, 2010
    you said: roller is not spinning freely when the belt is not on.
    the roller won't spin without the belt to turn it, will it?
    anyway, it is spinning quite freely while upside down. it vacs the floor very well, but smells like the new belt is burning as well and there is nothing stuck to make it burn.
  • 294 Answers
The problem you are having is that the brush roller is not spinning freely when the belt is not on. if the end caps of the roller can be removed, clean the dirt & carpet fiber out and test. if it can not you just may need to replace the roller
Posted on Feb 02, 2009
Just replaced the roller on my oreck XL, and it is smelling like burnt rubber
If the roller bearings are starting to seize the the belt may be slipping
Oct 25, 2012 | Oreck XL Ultra Bagged Upright Vacuum
Oreck xl won't start
This could be for various reasons. Check the power cord and try a different outlet first. See if the power cord is loose or damaged. Next check the brushroll and belt that those are in working order. If you smelt burning or electrical fire or your vacuum made an odd noise before stopping it may be the motor going bad. If your power cord is good and the brushroll and belt good, it is probably your motor going bad.
Replacement Oreck Vacuum Cleaner Motor
GoodVac
800-775-6586
Jun 20, 2012 | Oreck Vacuums
My Oreck XL 9100HA started smoking (white smoke) when I vacuumed. There is a burning rubber smell. How do I check/change (if appropriate) the belt? I have no User manual, nor can I locate one on the Oreck...
It sounds like the belt has been damaged. You can get another belt from yoru local Oreck store. You can even take it in to the store to show them what happened. Purchase another belt and replace it. (It was very easy when I did this, so hopefully the belt is all you'll need too.)
Best of luck!
Apr 18, 2010 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL intellashield smells hot and smoky when operating. New bag and belt and no clogs. About a year old.
If it smells like burning rubber with white smoke its the belt make sure the brush spins freely. If its a electrical burning it will smell real bad you WILL be able to tell which then its a motor issue you can remove the bottom plate 5 phillips head screws opposite the motor youll see 1 screw remove it pry the duct out and look to see if there's anything stuck in the fan if not its the motor its self
Dec 17, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL hard to push
yes. it might be broken. you will need to remove the 5 screw on the bottom and see if the belt is burned. it more that likly is.
Oct 16, 2009 | Oreck XL Ultra Bagged Upright Vacuum
My Oreck Vacuum cleaner keeps burning up belts. I
I am having the same trouble. I bought the vacuum new in October 2007 when my wife and I purchased a newly constructed home. Since it is only two of us, she only has to vacuum once a month. I have taken it in three different times and get the same story. It needed a new belt. Mine has white smoke coming out of it and smells like burning rubber. I contacted Oreck and got no results. They refused to let me discuss this with Dave Oreck, stating that he nevers talks with customers! Gary Neeble
Jun 05, 2009 | Oreck XL2000 Bagged Upright Vacuum
My Oreck XL was working fine, then when I vacuumed a shag rug is started smoking and smelled like something is burning. (I changed the bag, checked for clogs--none found, and roller brush is turning. It...
Even though the brush is spinning, the belt is probably worn out and stretched. when you vacuum the shag carpet, it puts more drag on the brush. try running it on a shorter carpet or hard floor for a few minutes. if it doesn't smoke, then you know it's your belt. if it does smoke, then it's probably the motor burning up.
Jim
Jun 02, 2009 | Oreck XL2000 Bagged Upright Vacuum
The belt on my oreck xl keep breaking
the brush roller is siezing up on you.try to take the brush roller out and clean it real good .pull the ends off and clean them to things get caught up and wrapped around them and keep them from turning.before you put the new belt on clean the motor shaft .usually when a belt breaks it leaves burnt rubber on the shaft .if you don't clean it the new belt won't last long.please leave feedback.i hope i was some help to you...pete
Dec 26, 2008 | Oreck XL2200 Bagged Upright Vacuum
Oreck XL Classic
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19810&thid=703827
Oreck XL Classic
posted by balis on Jun 24, 2008
The belt is on properly, however the brush will spin, then stop.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck XL Classic. It sounds like the belt may be stretched out and my needs replacing. The average belt change is every 4 to 6 months and to store the extra belts in a Ziploc bag in the refrigerator. Also check the brushroll, the gray bearing ends with say on either side the words NEW or OLD and both ends need to be identical – new/new and old/old NOT new/old, if the belt and the brushroll are OK then it may be the motor but I don’t think so. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 24, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL2600 Vacuum Logo
410 people viewed this question
Top Oreck Vacuums Experts
xalint1
xalint1
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
