Question about X2Gen MG19MY 19" LCD Monitor
LCD Shuts down
I have a LCD monitor that shuts down after just a few seconds of showing the display. This just started to happen recently and the computer is working fine with another monitor. It will not come back on until I unplug the monitor and hook up again resulting in above again. I suspect that the monitor is fine because it does show the display albeit briefly. I've also tried with another plug and it is the same problem. Any help would be appreciated. Thanks
  • derekdixon Feb 02, 2009
    Thanks Smith, it is the same problem on another computer, shop or new monitor it is.
    President:
  • 2,692 Answers
The monitor screen may be OK, but the monitor electronics are not. YOu state that the comuter works fine with a different monitor. That leaves out the video card. If you reall ywant confirmation of a bad  monitor, Try it on another computer ansdI am willing to bet that it  will again shut off.  Take it to a shop for repair or replace it.
Posted on Feb 02, 2009
  • Thomas F. Schneider Feb 02, 2009
    Your welcome. I am sorry it went out. Most shops around here charge almost the cost of a new one. Don't pay more that half of what a new one would cost to have it repaired.
Display Shutdown After Few Seconds To Few Minutes
Hook a spare monitor to the computer to rule out the video graphics card in the computer, and sub another video cord from the computer to the monitor if possible to check your LG monitor, If the display shuts down and power light changes colour or goes out it is a power supply board, one or more capacitors open causing the power to fail, sometimes the top developes a bulge making it easy to spot.
Apr 14, 2012 | LG L192WS LCD Monitor
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Sep 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
When i turn on my monitor it shows my desktop then shuts off after 10 seconds...never stays on
elainenemeth, Hi, Tell me more! How old is this LCD monitor? Is it out of warranty? Did the "SHUT-DOWN-IMMEDIATE" problem occur without warning? Did the BenQ display a "perfect" image the day before? Did you actually count----1001, 1002----1010 and then it shut down, after pushing the monitor on button. Did you do the "flashlight" test? With monitor connected to a "known-good", fully booted pc with Win Desktop displayed, TURN ON the monitor! Did it display the desktop for 1-2-10 seconds ? What did you see or not see when you pointed the flashlight at different angles about 1-2" inches from the now dark (black) screen? Get back to me with your results. I will offer the best advice possible to you as a consumer/user of LCD/FPD monitor. I'm louie12fix on fixya or lmistyrel @ aol.com Bye for now.
Apr 17, 2009 | BenQ FP71G 17" LCD Monitor
LCD monitor shuts down every after 2-3 seconds
dustcore025, Need a little more info here. Do you know age of monitor? Was it or did it display a "perfect' image on it the day before? Is it under warranty? How far are you willing to go to try and repair this thing? Do you know how to "part" the snap together plastic back cover from the bezel, after removing the pedestal? This sounds to me like a Switch-mode-power-supply or Inverter problem that occurs when some Electrolytic Filter Capacitors get a little bit TIRED of being constantly subjected to high temperatures near heatsinks that are used to keep semiconductors within operating limits. You can determine how bad this may be if you can do a test and remember what happens. Here is what to do. Make sure PC is fully booted displaying WIN desktop or some other screen. Next, with someone to keep hitting the CTRL or SP bar key every 20-40 seconds while you reconnect both cables of your MM17 back to the PC video port and ac outlet. Now try to turn on the monitor and note exactly what you see and for how long. Did it have a sharp clear image, even for 1-2 seconds? did the screen go black? OK! Next thing is to shine a bright flashlight onto the screen 2 inches away from where you know there was something a few seconds ago. Try it at different angles and not if you see anything. get back to me with results of test. I'm louie12fix on fixya or lmistyrel @ aol.com BYE for now.
Apr 05, 2009 | ASUS MM17T (Silver) 17 inch LCD Monitor
Shuts down after a few seconds
hi there, check your power supply on cpu if theres a tripping off , so if theres then replace power supply. then switch it on again. then let me know what happen nexr..
reagards rated me... thanks
Mar 31, 2009 | Acer AL1715 17" LCD Monitor
My new 21' flatscreen monitor keeps shutting off :(
Usually when an LCD display shuts off on it's own this can be a power supply issue. I would say if you checked all the connections you may want to contact the manufacturer. If it is only a few months old then you should be able to get it replaced under warranty.
Also, you may have an auto shut off feature enabled on the display itself. You may want to go through the display's menu to very that this is not the case.
Mar 08, 2009 | HP Pavilion F1703 17" LCD Monitor
Sony SDM HS74P Screen Stays on for approx 15 seconds then shuts off but power light is still on?
PWI17LS285A, ACTUALLY THE CAPACITORS DOES NOT KEEP ENOUGH CHARGE TO KEEP THE LCD WORK...
so the big capicitor needs to replaced? 100µF 450V
Jul 07, 2008 | Sony SDM-HS74P/S 17" LCD Monitor
Dell 2407 a04 Turns on (for 2 seconds) then off
your pc may be set to a resolution that is out of range for the monitor. Boot into "Safe mode" reset the Display settings to 640 x 480. reboot into normal mode then change the screen settings to your desired resolution.
Sep 07, 2007 | Dell UltraSharp 2407WFP 24" LCD Monitor
X2Gen MG19MY 19" LCD Monitor Logo
175 people viewed this question
Top X2Gen Computers & Internet Experts
jason
Sandy Moore
Sandy Moore
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
