Question about Nintendo DS Console
I can't find my charger is there another way to charge it
Not a cell phone charger
  • 1 more comment
  • Anonymous Apr 08, 2009
    My pet pie ran away from me.
    But the next day it came out of the other half of meand i was so hapy i retrieved it!
  • Anonymous Apr 19, 2009
    i can't find my charger and was wondering if i could charge it another way.
  • Anonymous May 05, 2009
    i cant find it i looked everywhere
You can buy new chargers at game shops they aren't very expensive and if you happen to find your other one you'll always have a spare.... i have 5 thanks to my son lol
Posted on Feb 02, 2009
My switch to turn on my DS is broken like it slides up and down when you shake by itself have an solution.
Posted on Mar 27, 2009
I cant find my charger !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! no one can get hold of me !
Posted on Aug 25, 2010
Look i cant find my danm charger i neeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeed my phone because it already died
Posted on Apr 01, 2010
I can't find my charger idk where i put it the last time i can remembered is that it was on my bed but then up till today idk where i put it :c my dad even tried to look for one at Target but couldnt find one xc
Posted on Jul 31, 2012
How to charge it
Hi Stacey
How to charge "what model" Cell Phone
iPhone & others usually charge from the USB cable that it comes with.
Plug into any USB port (5v DC)
Some chargers supply more current which can give a faster charge. iPad chargers supply 2A where as iPhone chargers are 1A
Sep 13, 2015 | Cell Phones
HOW DO I CHARGE THE PHONE
Mobile/cell phones are supplied with an adapter charger that is used to charge the phone. The charger is specific for your cell phone.
You can purchace chargers for your model cell phone on the Internet or the mobile phone shop.
Mar 05, 2012 | Cell Phones
My phone wont charge
The phone is not charging because:
1. The charger of the phone maybe bad. Test the phone with another charger or test the charger with another phone to confirm if the charger is defective or not.
2. The charging port of the phone maybe defective. In this case, the charging port needs to be replaced.
Good luck.
Jan 10, 2012 | Motorola Mobility Droid (2 GB) Cell Phone
My Xperia 10i is not getting charged though my charger is working properly. Once charger is pluged charge light indicated gets on but no any battery charging indication can be found on the screen. My I...
when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Jun 13, 2011 | Sony Ericsson XPERIA X10 Cell Phone
Nokia 3110c Charger not supported
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Dec 29, 2010 | Nokia 3110 Cellular Phone
Phone won't charge, usb music sync on screen when charger is plugged in!
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Take care.
Sep 25, 2010 | AT&T Nokia 6555 Cell Phone - Black
When I plug in the charger it wont charge Im not getting like unauthorized charger message it just wont charge
I advice you try get a similar charger to charge your phone, if the similar charges your phone, it means your charger is bad and will need to get another charger or the phone.
But if it did not charge and you still get the same message, it means the charging port on your phone is the problem, the charging port on your phone is bad and can not read the charger, so you will need to replace or change the charging port on your phone. Doing thi will solve the problem on your phone.
Take care.
Jul 19, 2010 | Motorola Mobility Hint QA30 Cell Phone
I just bought a motorola E815 cell phone and it will not charge
Remove battery, clean contacts between battery and phone, also be sure to use an original Motorola charger instead of one of those "universal" type chargers.Hope this helps!
May 08, 2010 | Motorola Mobility E815
My motorola rival cell phone wont charge what should i do
Hi,to really know where the problem is from,i will suggest you use your present charger to charge another phone of its kind,if charges the other phone,it means the problem is not from the charger but rather the charging port of your phone is bad and needs to be replaced,
however,if it doesn't charge the other phone it means the problem is from your charger,and you have to purchase another charger for your phone.
Thanks and take care
May 04, 2010 | Motorola Mobility Rival A455 Cell Phone
Bad contact charger
The charging port is bad, so you have to take it to a technician or get a universal or desktop charger to charge you battery.
Nov 03, 2009 | Cell Phones
Nintendo DS Console Logo
2,040 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
