Question about Tappan TGF320 Gas Kitchen Range
Tappan oven model tgf336bhwd oven doesn't always light
My tappan oven doesn't always light. The igniter gets red hot but the gas valve doesn't always open. Some times if I jar the oven or turn on a burner on the stove the valve will open and the oven will light. Once it lights it works fine until it sits for a while. Is it possible that the gas valve needs a good cleaning?
SolutionGuy
  • 331 Answers
SOURCE: Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Posted on Aug 15, 2007
  • 145 Answers
SOURCE: burners and oven not heating tappan range 560s111po1
You need to check the connection at the back of the unit that hooks to the house power. Turn off breakers or pull fuses before checking. It sounds like you only have half of the voltage you need. One of the wire connectors may be burnt or you may have a problem with the house wiring.
Posted on Apr 23, 2008
SOURCE: Tappan Millennia Stove/Oven
I have a delay when trying to turn on to use the over, then an exploding sound. What is this? Is the ignitor going bad?
Oak Park, IL
Posted on Jan 04, 2009
  • 1214 Answers
SOURCE: Hello, Can't find model/serial number.
Serial number labels are usually located in any one of a number of places -
Under the cooktop in one of the corners
Inside the oven door frame (not on the door)
Behind the bottom drawer pullout on the oven, left hand side
Oven back.
If this unit is anything less than 20 years old, there will be a label somewhere.
Reply back you findings and I can give you more information as to how to repair, and we can identify part numbers. You might also try www.repairclinic.com and see if you can drill down through parts when only knowing the manufacturer.
Posted on Jan 30, 2009
SOURCE: oven not coming on
I have a tappan gas stove the top comes on but the oven wont come on.
Posted on Mar 18, 2010
Tappan 32-1272-10/07056-8509-4080 gas range/oven pilot light works,main oven burner won't come on
You will need to look and see if the igniter is glowing a bright red. If it is weak, the oven will not light. Here is the igniter if you need to order it.
Also check and make sure your getting 3.2-3.6 volts AC to the valve.
Dec 01, 2012 | Tappan TGF320 Gas Kitchen Range
My tappan gas oven (Model # 30-4942-0005) doesn't light
yes the igniter is not calling for enough amps to open the control valve, the igniter needs to be repalced.
Feb 01, 2010 | Tappan Ovens
I'm trying to light my tappan oven...can't find the pilot
Your oven doesn't have a pilot,it has a flat surface igniter.If the igniter is bad or not getting the correct voltage,the safety will not allow the gas valve to open.This being said,I will say any repair involving gas is best left to a qualified tech.If its just the igniter its pretty easy to check it with a ohm meter.It should glow bright red when its calling for the oven to ignite.Hope this helps
Jan 07, 2010 | Tappan TGF320 Gas Kitchen Range
Gas oven won't light on Tappan Centenniel. First, the burners come on, so gas is getting to it. When oven thermistat is turned on, some sort of electric igniter element glows. How does this igniter...
The inside of igniter has a probe that is heated, When it is time to light, the solenoid opens gas valve and allows gas, then that heated probe ignites the flame. After temp is reached fuel is shut off.
Oct 29, 2009 | Kitchen Ranges
Tappan #tgf605wfw5: igniter gets hot but gas valve does not open up. Part of the igniter bad, or the valve bad. How to check to see which one is bad?
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
Aug 16, 2009 | Ovens
Tappan TGFS26C, Oven igniter not even
Lets take the oven problem first. Sounds like you have a Hot Surface Ignitor problem. This is the device that glows and lights the burner. You can buy a universal ignitor at most appliance or heating and air conditioning supply houses. Note carefully how the old one is mounted. You may have to make some adjustments to mount the new ignitor, but it MUST be close to the gas burner like the old one! You don't smell gas because the gas valve will not open until the ignitor is hot. All ignitors work with the same voltage, so simply connect the new wires to the old ones.
I'm not certain if you have a standing pilot for the stove top burners or electronic ignition. Remove the top panel to check. If you have a gas pilot, relight it. If electronic ignition, clean the ignitors. If that does not solve the problem you may have to call a technician, as these systems can be complex.
Hope this helps.
Ray
Nov 20, 2008 | Tappan TGF363 Gas Kitchen Range
Older Tappan range oven not lighting.
There is no way to light the oven manually. The gas valve will not open until the oven ignitor draws enough current. But replacing the ignitor will fix ya up.
Nov 19, 2008 | Tappan TGF320 Gas Kitchen Range
Tappan - Model 36-3052-23
I suspect you may have a bad igniter. They will still glow nice and hot, but if they are weak the gas valve will not open. This is actually a safety feature. Depending on which type you have, the glow bar igniter is supposed to draw a certain current potential before the gas valve will open. Here's the current readings for both types: Round Glow Bar: 2.7 to 3.2 amps Square Glow Bar: 3.2 to 3.7 amps I would try to to determine if the igniter is good or bad before proceeding with a gas valve replacement. Generally, the igniter is a common fail item. Let me know if this helps.
Sep 06, 2007 | Tappan MGF500PBW Gas Kitchen Range
Oven not always working
MOre than likely your igniter is getting weak. If it doesnt pull enough amperage. it shouldnt let gas into the oven. If it is letting in gas and not igniting, I would suggest a new igniter and a new safety valve. Hope this helps!
Nov 22, 2006 | Tappan TGF320 Gas Kitchen Range
Tappan TGF320 Gas Kitchen Range Logo
104 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
