Question about Microsoft Windows XP Media Center Edition 2005 for PC
When i turn on my computer it starts to beep
When i turn my cpu on it starts to beep and it wont stop until i turn it off
on the monitor screen: NO SYNC
my cpu is an e machine
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    Hi there
    Are the beeps long or short? Also how may beeps are there?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 23 Answers
Ram error reinstall ram
Posted on Feb 04, 2009
My Dell Inspiron 545 desktop computer beeps upon start up. It beeps 4 times pause and repeat over and over again. Also the monitor screen is black and won't turn on.
Try to open the CPU
when you open the cpu remove the ram clean it with eraser carefully
or if you have IP solution try to clean the ram with it and again install the ram
Apr 13, 2016 | Dell Computers & Internet
Dell e178wfpc monitor shows power on light but no display.
You should check if the vga cable is tightly connected from monitor to cpu. If the cable is connected properly,then the problem must be with your monitor. Check with any other monitor. If you hear a beep beep sound, when you start the computer then your RAM has been damaged or not properly connected.
Apr 11, 2014 | Dell E178WFP Black 17 inch LCD Monitor
I have an hp pavillion a6500f that soon as it is turned on has a constant alarm and is not sending a signal to the monitor. Screen says no signal and then remains black.
If you mean a constant beeping, open the case and see if the CPU fan is running, check also that the heatsink is firmly attached to the board, this noise usually points to a n overheating CPU, if you get no activity on screen,it is because there is no signal being sent to the monitor. Do not operate the computer until you have checked the fan is working, you need to establish if there is power getting to the fan by testing with a multimeter on the motherboard cpu fan pins. If you are getting power, replace the fan, worthwhile removing and regreasing the CPU and making sure it is firmly in place.
If there still is no signal, replace CPU, but also try a different graphics card (faulty video will give 9 beeps).
After that, check the ram is firmly in place.
Jul 28, 2011 | HP Computers & Internet
My computer turns on but my screen wont HELP NOW
please check on cables connecting the monitor to your tower/cpu. make sure both ends are plugged in tight. check on the monitor power light aswell, if its blinking or not, if the monitor has been more than 5years old too, its possible thats already dead computers have a life time too especially the old models.
Apr 06, 2011 | Computers & Internet
When pluged into outlet fans spins and doesnt stop, wont boot
Fan spinning hard is usually a CPU issue.
If you've made any hardware changes to your computer, undo them. This happened to me when I was trying to upgrade my Processor (CPU) and I had the wrong kind.
Mar 09, 2010 | HP Pavilion m7560n PC Desktop
No input signal
that is the problem of cpu not a monitor to confirm disconnect signal cable and power on. monitor will show "no signal check signal cable" it means that monitor is ok and fault lies in cpu .then open the cpu and disconnect ram and listen the beep. contineus beep should be heard then ram is faulty replace it. if no beep heard then motherboard is faulty .
Mar 08, 2010 | HP vs17
My screen does not come on when computer is turned on.I have a samsung syncmaster 2253lw as my main screen and have had both operating in the past at the same time.
Please check your plug if it is plug in properly or firmly. Locate the switch and turn it on again. If stil persist, try to inspect whether cpu is beeping while turning on. If its beeping something is wrong in your cpu or monitor depending upon the beeps.
Jan 27, 2010 | Samsung SyncMaster 731B 17" LCD Monitor
Cpu no up, monitor shows
could be the whole pc is fried :(
Jul 10, 2009 | Computers & Internet
Going to Sleep Displayed
I turned on my computer and the monitor displayed this message on the screen "going to sleep no input received". I checked the power cord and unplugged it, nothing. No lights are flashing or beeping sounds. The CPU is working just fine, anyone have any idea what to do
Aug 02, 2008 | HP vs19 (Silver) 19" LCD Monitor
No dispaly
The 2 extra wires will most probably be temperature sensors.
If your using the onboard video, then make sure you have memory in the first DIMM slot (it will say DIMM1 beside it)
If that dosn't solve the problem then try these:
  • Remove the memory and reseat it. Make sure to put it back in the correct way. There is a notch towards one end that will match the notch of the memory slot. Press it in until the 2 clips lock fully, then give it a gentle wiggle side to side while pushing down still.
  • Listen to the beeps your computer makes when starting up. A single short beep is what you want to hear. If you hear. If you hear something else then post back what it does. There are long and short beeps that could be involved.
  • Disconnect all the IDE cables from the back of the drives. You can leave the power cables connected. When they go back in they also have a notch and can only go in one way.
Try those for a start and post any progress you make. Also just double check the video cable is correctly attached at both ends to the computer and to the monitor.
Apr 10, 2008 | ASUS P4S800-MX Motherboard
Microsoft Windows XP Media Center Edition 2005 for PC Logo
373 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
