Question about Polaroid I533P Digital Camera
I turn my i733 camera on and when i go to take a picture it says that the card is locked and wont let me take pictures, how do i fix this?
  • pglisson Mar 20, 2009
    I just went to take a picture and its says card locked. Anyone else have this problem and able to fix it.
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 27, 2010
Download camera driver polaroid i733
You don't need a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Dec 10, 2013 | Polaroid i733LP Digital Camera
I had lost my software and cant convert pictures
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Jul 11, 2010 | Polaroid i733LP Digital Camera
I loaded all the software for my polariod i733
Consider NOT connecting your camera to your computer.
Apr 11, 2010 | Polaroid i733LP Digital Camera
We just purchased an i733 Polaroid camera. The
Jan 19, 2010 | Polaroid i733LP Digital Camera
Why would my camera say card locked and wont take pictures
Check your memory card, See if ther is small lock on card, and set this unlock. so you can take the pictures.
If This is not to issue. Remove the card, remove the battery.
Install card , install battery, turn on see if worked. Not Your memory card could be faulty. Check on computer card readers and after you upload the pictures from the card, Format the card.
JMC
Aug 16, 2009 | Polaroid i737 Digital Camera
My polaroid i733 says card locked whenever I try and take the picture, how can I fix this?!?!
on your memory card there should be a really tiny switch thing on the side, push it the other way and it should work :)
hope i helped.
Jul 10, 2009 | Polaroid i1035 Digital Camera
I733 Memory Full after 1 picture?
you need to buy an sd card that holds memory. most cameras don't have a lot of internal memory.
Oct 16, 2008 | Polaroid i532 Digital Camera
My batteries died in my pink i733 and when it shut down the "zoom lense" did not recede. i put fresh batteries in it but all that happens is that the green light flashes. it wont come on or...
This can sometimes be fixed if you remove the batteries over night and allow the camera to sit and discharge it should correct this problem. hope this helps.
Mar 28, 2008 | Polaroid i733LP Digital Camera
Polaroid I533P Digital Camera Logo
59 people viewed this question
Top Polaroid Cameras Experts
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
