Question about Seiko SXGL62 Wrist Watch
Battery replacement for seiko sxgl62
How does one remove case cover to replace the battery? And how is the cover replaced following battery replacement? Chuck
3 Suggested Answers
  • 12 Answers
SOURCE: how to remove back for battery replacement - 19
This is a little tricky, I think this has a screw on back. It takes a two or better a three prong tool to remove back. A new seal shoud be on hand to replace this. Watch should have a consumption test and a min run voltage test, if either of these fail a new circuit board or movement should be installed. Take it to a good watchmaker and they will clean the outside before opening and do a water resistance test after assembly.
Posted on Jun 14, 2009
SOURCE: early 90's SEIKO 7N43 8A39
The 7N43 movements are readily available for less than $25 and any jeweler can install them. I own the same watch myself and really like it but after 14 years the date wheel is slipping and its cheaper to replace the whole movement than fix it.
I'd try a different jeweler as obviously yours is trying to sell you a new watch!
Posted on Jan 04, 2010
Testimonial: "will try this asap tnx"
What exact battery do I need for Seiko SKA348?
  • Remove back
  • Find battery holder
  • Note battery type
  • Obtain replacement battery
  • Remove old battery and install new
  • Check operation
  • Reinstall back
  • Set time, etc.
OR,
Take your Seiko watch to a jeweler who, for a reasonable sum, will replace the battery
ORORO
Nov 22, 2016 | Seiko Watches
Need battery number for Seiko vivace ladies watch no 440180
  • Remove back
  • Locate battery and note installation details.
  • Identify type (number)
  • Install new battery
  • Check operation
  • Reinstall back
  • Set time, etc.
OR,
Pay a jeweler a few bucks to replace it
Oct 25, 2016 | Seiko Watches
How do you open the Seiko S149 to replace the battery
there are four screws on the back and three in the AA battery tray. then you remove three screws holding the battery down.
Jan 25, 2013 | Seiko S149 Stopwatch/Printer
How do I replace a battery on a kenneth cole watch and square fossil watch
Open watch case back, then release the metal contact covering the battery. Memorize battery's polarity (+ up and - down), then take the battery out. Memorize the combination of letters and numbers on battery (should be something like: CR 3216 or similar). Make does not matter - Seiko is as good as Maxell, Panasonic2_bing.gif and other reputable makes. Buy new battery with identical combination of letters and numbers and put in your watch. Replace back contact, gasket and case back. Set your watch and enjoy. Rate me, please.
Feb 28, 2010 | Kenneth Cole KC4232 Wrist Watch
Hi - is the battery on the Polar FS2C changable - and if so how can I do it?
Open watch case back, then release the metal contact covering the battery. Memorize battery's polarity (+ up and - down), then take the battery out. Memorize the combination of letters and numbers on battery (should be something like: CR 3216 or similar). Make does not matter - Seiko is as good as Maxell, Panasonic and other reputable makes. Buy new battery with identical combination of letters and numbers and put in your watch. Replace back contact, gasket and case back. Set your watch and enjoy. Rate me, please.
Feb 28, 2010 | Polar FS3 Heart Rate Monitor Watch
How to remove back cover and change batery. This is a Seiko watch, Stan Bixler sbixler@socal.rr.com
Not sure which Seiko this is. If it does not have a snap back case the it is a screw on case back. A special wrench is needed to unscrew it. If you don't have a case back wrench you will either need to buy one (the good ones that won't damage your watch are about $50 US) or take your watch in and have the battery changed.
Hope this helps.
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Oct 27, 2009 | Seiko 0512037FA Wrist Watch
The Seiko s149 will not display anything on the screen.
We had to change the internal battery on ours today. There are 4 screws on the back of the case and 3 inside the AA battery compartment. Careful pulling the front and back apart as there are some wires that attach between the two. Two of the three screws need to be removed to get the CR2430 battery out to replace it. We now have the watch screen...just need to remember how to operate it...need a new users manual.
Sep 25, 2009 | Seiko 300 Lap Memory Stopwatch
Need to remove winder on mens seiko titanium so i can remove the
Ensure crown is in neutral position i.e. pressed home (not in set hands posn.) Remove back and adjacent to the winding stem on the movement there should be a small button (may be indicated with an arrow) depress this gently whilst withdrawing the crown and stem from the watch. Ensure you don't engage to set hands position in the process. You might also find a couple of screws securing the movement into the case. P.S. Usually don't need to remove from case to replace battery.
Mar 30, 2009 | JCPenney Seiko Men's Titanium Watch
Pulsar NX14 Digital Display gone blank
Do not panic yet - all you need is the battery replacement.
Don't mind that the watch is less than a year old - it may laid in sellers store for a year or so and as the watches are not refitted with the brand new battery at the selling point, they may have underpwered battery much more quicker than you expected
Find your nearest watch repair shop and ask for battery replacement. Your watch will tick as brand new and will last much longer then before.
Do not forget to rate, please.
Jan 12, 2009 | Watches
Seiko watch mechanism replacement
nice day to you! your watch is need of general cleaning and recondition ,efter cleaned and condition the machin ! be sure that the case back gasket is good and apply a small amount of silicon greas to avoid water damage ! close it verry tight ! good luck !god bless !
Sep 02, 2008 | Seiko Watches
Seiko SXGL62 Wrist Watch Logo
118 people viewed this question
Top Seiko Watches Experts
Lawrence Oravetz
just-ice
Are you a Seiko Watch Expert? Answer questions, earn points and help others
