After sitting in power save mode for a long period of time the printer might not function properly. This happens when the printer is plugged into a surge protector. Unplug from the surge protector and plug directly into the wall power socket.
Step 1:
Please try to print Self test Print from the Printer (without PC ie. remove the USB cable from the PC)
Step 2:
If the Self test Print is Ok, try to connect your printer to PC
and Print Test Page
Go to Start >> Printers and Faxes >> Select your Printer F380
then Right click Properties and Click on "Print Test Page"
If this prints Ok then all the connections you have made are correct
In case, it does not print then please check your USB cable try to change it
Step 3:
You can uninstall your Driver
and install the new driver, to download the driver for F380 All in One Printer Please click the below link
Choose appropriate Operating System
HP F380 All in One Printer Driver
I hope this will resolve your problem
all the best
I have new HP printer cartridge already installed and aligned
