Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Lap top will not boot correctly when not connected to ext hard dr
I recently installed a WD 750 G ext. harddrive to my lap top. I transfered "My Documents" to the hard drive but no systems files. It works fine when connected but if I boot the lap top without being connected to the hard drive it runs very, very, very slow and will freeze up if asked to do anything before it gets to the last task. Lap top is no longer portable - it is tethered to the ext. hard drive.
First u check the laptop Display
if it has display, thn it might be problem ur windows
instead of it.
if computer does not give display thn u check the power adopter of ur laptop.
after all gonig through these steps.even u find all these above steps perfect.
it will mean,
it might be problem of ur hardware.
lets check out it by ur computer vendor.
Danish khan
Posted on Feb 02, 2009
How to download photos from phone to lap top ?
If the phone is recognised as a usb drive on the laptop (you may have to enable usb mode on the phone) then usually most pictures are located under a folder named "DCIM"
what model LG phone?
Aug 04, 2014 | LG Cell Phones
I have a Toshiba Desktop Ext Hard Drive PH3100U-1EXB ... i unplugged it from my desktop to plug into my laptop like i have done before but this time it wouldnt load so i tried to eject it but it wouldnt...
but does it still work on the desk top.
if yes, then you have lap top issues, ONLY.
easy ,huh?
try all lap top USB ports no ext. hubs allowed.
what is wrong in the LAP top OS, unstated)
are you using the correct external power adaptor for both Desk and lap top usage,
have you tried a diff. usb cable.
Laptops can not power the hdd via the USB at all, and in fact
should be avoided at all times. no matter.
the laptop can be infected.
the laptop might have USB issues, with drivers.
do a USB driver update. (no 0S stated)
does the HDD show up in Disk manager, as DISK2
can you set the drive letter?
can you set the volume label on this disk via DM?
if yes, you then can read and write the drive.
as stated on all pages for USB
disconnect all other USB devices, and now try this HDD.
do a full virus scan, and malware scan
do wInDoZ update.
I think i hit them all.
Oct 01, 2013 | Computers & Internet
Lap top can't find hard drive
Here are some steps that you can try.
- Check if the harddrive is recognized in the BIOS (Basic Input Output System). Normally you will see values beside "Drive 0" at the first page if the harddrive is detected. If it says none or blank, then it is not detected. Reload BIOS default settings and try to boot up the unit to see if it will pick up the harddrive.
- If the harddrive is not detected in the BIOS, you need to unscrew the harddrive compartment at the bottom of the laptop.
- Reinsert the harddrive and check harddrive cable. Also try to use a good known harddrive if yours is defective.
Hope this helps.
May 27, 2011 | Samsung Notebooks 14.1 W P460 Professional...
WD essential 1tb I cannot open the software on my laptop. A window pops up saying WD has encountered a problem & must close program, send or don't send option is all. How can I access my Passport? It...
Hi: That portable hard drive is USB 2.0 is the port on the laptop USB 2.0 can you use a memory stick to transfer files from the one lap top to the other lap top then on to the external drive.
Mar 16, 2011 | Western Digital WD My Passport Essential...
Got wd elements 1.5 tb plug n play hard drive n errh it wont plug n play ??? used on playstation 3 always worked used on my lap top and other peoples neva had any problems lent to a m8 he removed with out...
PlayStation 3 has a Unix like operating system. It is proprietary.
The below is how the WD was reformatted to accept P3 content. Even if the PC reads the Fat format, the file types are native to the Unix like system, not Windows. But the above link may be of some help.
Jun 14, 2017 | Western Digital MY BOOK HOME 1TB EXT...
My Portable hard drive will only work on 1 computer
First make sure usb cable connected to harddrive is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
And remove upper filter and lower filter.Then restart computer then check.
If your harddrive still not recognized then you need to repair your harddrive.Try your harddrive in different computer if it is not recognized on another computer then your harddrive has internal issue.
Let me know if you need further assistance.
Thanks for using FixYa
Jun 03, 2010 | LaCie Computers & Internet
Pc hard drive
Yes, that correct you can just need to take the hard drive from your desktop and get a external hard drive ecnlosure where you need to put the hard drive and connect it to your laptop via USB cable, check this link for the sampole of the hard drive enclosure that you need to buy
Hope that helps.........
Sep 08, 2008 | IO Magic Corporation GigaBank (I250HD35)...
I am trying to install a WD 250GB Passort V2 External USB 2.0 - 2-50" Portable Hard Drive but unfortunately my Windows XP doesn't want to know it. I have had it just over a week now and when I first...
Did you try a different usb port? is the cable plugged in correctly? check device manager and monitor it once the ext. hdd is plugged and report back with the result plz.
Jun 16, 2008 | Computers & Internet
Sierra wireless aircard 750
I lost my sierra wireless aircard 750 installation cd how can I re-instal it once again on a new lap top
Dec 18, 2007 | Sierra Wireless (03R0017)
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
112 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
