Question about HP OfficeJet k60 All-In-One InkJet Printer
Fax failure error # 551
Can't send fax keep getting fax failed and an error code
    Genius:
  • 2,120 Answers
Check the phone line with a regular phone.
Posted on Feb 02, 2009
Epson fax hooked to magic jack communication error
I had same problem when I used the dual jack. I had to change it. I had the dual jack which would make it easier to use when I was going to send a fax.
Good Luck
Feb 09, 2010 | Epson WorkForce 600 All-In-One InkJet...
Error message says fax failure
Check your phone line to make sure you are connected. If this is a newly installed fax machine, make sure the fax application is downloaded.
Sep 28, 2009 | HP OfficeJet t45 All-In-One InkJet Printer
Recieve error 334 when sending fax but i am able to recieve faxes
Error Codes: 332, 333, 334, 335, 336, 337, 338 ECM, 339 ECM, 340 ECM, 341 ECM, 342 ECM, 343 Definition
The remote fax machine might be defective.
Solutions
  • Try to verify this by sending the same fax to other fax machines. If these transmissions are successful, then notify the user of the remote machine to make them aware of the issue.
  • If the fax fails when sending to other machines, turn it off for 10 seconds, turn back on, and then try sending again.
Error Code: 334
Definition
Solutions
Sep 20, 2009 | HP PSC 2210 All-In-One InkJet Printer
Error codes 283 and 232 in received Faxes
basically error 232 indicates that a communication failure has occurred between the two machines
Following these steps may help resolving your issue
1. Make sure that the phone cord is plugged directly from the wall jack into the back port of the fax machine that is marked "Line" or "To Wall Jack", or that has a wall-jack symbol.
2. Verify that the line interface unit (LIU) (the box that the phone cord plugs into) is seated fully into the back of the fax.
3. Remove any other device from the line such as splitters, credit card machines, or telephone answering machines, and retry the fax communication.
4. Try sending and receiving faxes on a different fax line.
5.Try using a different telephone cord.
6. Have the phone company test your line for static or noise problems.
7. Disable Error Correction Mode (ECM) if the same error occurs repeatedly.
Hope this helps.
thx
Jun 02, 2009 | HP LaserJet M1522nf Multifunction Printer...
Receiving error 388. Can receive faxes but won't connect with other fax machines when trying to send
The reason for the error code:
4e5e48b.jpg Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Solution
Please Click here and follow the instructions to resolve the issue.
May 21, 2009 | HP Officejet 6310 All-In-One InkJet...
NEED ERROR CODE TRANSLATION
I do not know what the error code means but try this http://www.sharpusa.com/global/ContactUsProdSupp/1,1878,,00.html
They should be able to fix your problem
Jan 09, 2009 | Sharp UX-B750 Inkjet Fax
What is error 388
there is not error code for the OfficeJet 4315. however, there are similar code for other Hp printer.
error "388" is lised as unable to detect T30 frames. in other words, the machine fail to establish comparable connection. this can be the machine trying to send out fax in high speed, or the phone line problem.
consult the user manul how to set a lower transmission rate, or try to send the fax at a differnt time of the day . If that still give you problem, please call the phone company and have they look a the phone line.
Nov 10, 2008 | HP OfficeJet 4315 All-In-One InkJet...
Hp photosmart 2610 all in one series. I can receive faxes but can't send them
First, in the FAX mode, scroll to PRINT REPORTS on your HP's display. You can then print out all fax activity, including failed SENDS. There should be an error code associated with the failure, and this may help to point you in the right direction. Using the HOOK button on your fax, call your cell phone. If your cell rings, answer it, and listen for the FAX TONES. If your cell does not ring, press the MENU button on your HP, and scroll to either FAX SETTINGS, FAX SETUP, INITIAL SETUP, or FAX SEND MODE. Try changing , one-by-one, any settings related to sending faxes. Be sure to write down the original setting before you change it.
Sep 10, 2008 | HP Office Equipment & Supplies
Failure to Warm Up
Failure to warm would suggest the fuser unit is failing and the machine is failing to reach the temperature that toner melts and fuses to the paper. The machine should display error 76 or 77.
Try this ONCE only!! till the after 99 bit. Hit menu, *,2,8,6,4 quickly if all the button flash and maintenance is displayed enter 99. Now if the error reoccurs you need to replace your fuser unit as it failed as opposed to just malfunctioned.
It will melt if there is a problem and you keep repeating this process. So please only once. If it takes you a few goes to get into maintenance modes its ok but the reset of 99 do only once.
Mar 02, 2008 | Brother IntelliFax-2820 Laser Fax
Fax Error Codes
ERROR 346 The remote machine has failed to respond to a fax command from the local machine because the connection was interrupted. These errors can occur if the phone lines in the area are old or if noise is present (static on the phone line). Other reasons could be power outages and other power-related problems.
Sep 11, 2007 | HP Officejet 7210 All-In-One InkJet...
HP OfficeJet k60 All-In-One InkJet Printer Logo
50 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
