Question about Wurlitzer Jukebox CD Player
Rowe CD 100 that will not play all Tracks
I have a Rowe CD 100 Jukebox plays Great. However it will not play all Tracks on longer CD's. Example if a CS has 20 Tracks it will only play 17. Any Suggestions?
  • Anonymous Mar 24, 2014
    My rowe jukebox does not play the right CD, if you put it in service mode and spin CDs try again its plays, but you have to do this every few CDs?
  • John Fisher Oct 17, 2014
    If you get the same results on many discs the player may be on it's way out. You can try cleaning the lens with a cue tip and a drop of isopropyl alcohol. The next step would be to change the player if you can find one, If that's impossible you could get an MP3 conversion which will replace the entire mechanism with a hard drive or compact flash. The rest of the machine works the same.
    Scholar:
  • 195 Answers
Are you initalizing the CD's in your jukebox after you install them?
If so it should play all of the tracks.
Regards
Alan Hood
ami-man
UK
Posted on Mar 03, 2009
How do I set free play on my rowe laser100
Hi you put on service , then you enter 84 then you put the number of credit you want by example 9999 and you press popular and you put back to normal mode
Jul 03, 2014 | Wurlitzer Jukebox CD Player
I've had my jukebox for 6 years and the free play ran out. I forgot the code its a rowe cd 100 commerical
it should have a free credit button on thecircuit board they usually black or
red just press several times
Aug 21, 2011 | Wurlitzer Jukebox CD Player
Rowe Nostalgia jukebox will only play a few of the numbers of the 100 cd;s. Is there anyway to reset it so it will play all numbers?
You will need to go into the programming section on the menu.
I suggest that if you do not have a manual that you obtain one from Rowe Ami, Victory Glass or distribution.
Have you initalised all of the CD's on your jukebox? Every time you replace a CD you have to initalise it.
Regards
Alan Hood
ami-man
UK
Jan 31, 2010 | Wurlitzer Jukebox 1015 One More Time...
How do I slow the speed of the 45s on my rowe r-92 jukebox .The records are playing a little too fast
The turntable motor on the jukebox range of R-84 to R-93 is none adjustable.
If you are in the USA then the motor operates on 60hz but in Europe it would have to be on 50hz to do this a different pulley is used.
The Rowe Ami part numbers are as followes:-
30791907 Turntable Motor Assembly 60hz
30791908 Turntable Motor Assembly 50hz
21817801 Motor Pulley 60hz
21817802 Motor Pulley 50hz
These can be ordered from a Rowe Ami dealer or you could try www.victoryglass.com
Regards
Alan Hood
ami-man
UK
Oct 28, 2009 | Wurlitzer Jukebox 1015 One More Time...
Rowe Jukebox CD-100E. When I turn it on the
AT THIS TIME YOU ARE NOT SURE IF THE PROBLEM IS IN THE LASER ASSEMBLY, OR THE AMPLIFIER?
BORROW OR RENT, AN AMPLIFIER HOOK IT UP TO THE OUT PUT ON THE LASER OUT PUT ON THE LASER CD OUT PUT. LOOK AT LASER UNIT IT HAS A MARKING ON IT THAT SAYS AUDIO OUT PUT. PUT CABLE TO A SECOND AMPLIFIER.
THAT WAY IF IT STILL FADES. THEN THE CD LASER IS THE PROBLEM . IF THE SOUND IS GOOD THEN THE AMPLIFIER IS AT FAULT
DOCTOR FIX IT
Oct 23, 2009 | Wurlitzer Jukebox 1015 One More Time...
My rowe cd 100 sometimes doesnt play the cd and it spins it back
Clean the laser eye with a cotton bud. Otherwise it is probably a laser unit problem.
Oct 21, 2009 | Wurlitzer Jukebox CD Player
CD palyer will not play all Songs
It sounds like the CD has to be initialized, so the jukebox knows how many songs are on the specific CD.
To initialize a CD, go into service mode, input code 31, then index the cd number (two digits), then hit "popular". return the jukebox to play mode.
The carousel should scan and load the CD you initialized, and then return it to it's slot.
It should now be able to play any song on the CD you select.
Mar 05, 2009 | Wurlitzer Jukebox CD Player
Song Programming
With regards to your problem with the Rowe Ami 100 cd jukebox.
Do you have a manual, if not I suggest you buy a printer manual or one on CD and refer to the Programming and Installation section.
In order for the jukebox to know about the cd's that are installed in the jukebox it has to initialize all or the changed cd's that have been replaced within the jukebox.
Put the jukebox into the Service Mode (the service mode should appear on the display)
Type 3 to select the Initialize sub menu
Type 0 and full initialize will appear on the display
Press Popular to start the initialization
Place the jukebox service switch into the normal mode
Initiazation will take around 30 minutes to complete.
Regards
Alan Hood
ami-man
Jan 05, 2009 | Wurlitzer Jukebox CD Player
Open Questions:
See all Wurlitzer Jukebox CD Player Questions
Wurlitzer Jukebox CD Player Logo
722 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
