Question about InFocus IN72 Multimedia Projector
Can't source or use any buttons on the unit or remote..
I can power the projector on but cannot source or even power off th projector from the reote and the unit itself. Tried to "hard reset it" didn't work. I think it has something to do with the board..
    Sergeant:
  • 319 Answers
Sounds like a hardware failure. Have a technician look at it.
Posted on Feb 27, 2009
All status lights lit and projector not projecting
Cycling power off and then on again after a few minutes may have allowed the unit to discharge its circuits and reset itself.
Jan 04, 2013 | Office Equipment & Supplies
Hi, how do I turn on the system without the remote (i dropped the remote in a blender by accident)
Go to the unit and press the Standby (Icon has the Power symbol) button to the left of the JVC logo. Use the Source button to switch from one source to another (the button is above and to the right of the JVC logo).
The manual for the JVC TH-A85 is available from JVC. The direct link is http://www.jvc.co.uk/files/instruction_manual/lvt1025-003a.pdf . See page 19 (22 of the pdf) for the details. See page 5 (8 of the pdf) for the layout of the controls on the center unit.
Unfortunately the original remote is no longer available. There may be universal remotes that will control the system. (The ones that can be programmed by a USB connection to a computer will be the easiest to program.)
I hope this helps.
Sep 17, 2011 | JVC TH-A85 System
After 8 years, my Gateway monitor is "shaking" or
I had this same issue with a monitor of mine one time. I tried different video cables, power cables, and even a different power source - but that didn't fix the issue. You could try the same. Another option might be to factory reset it or degauss it if its a CRT.
Otherwise, it is probably not worth it to be fixed professionally since a new LCD can be had for under $100. If you watch sales from Newegg.com, deals on Woot.com or Slickdeals.net.
Jun 13, 2011 | Gateway Computers & Internet
I my projector is new one used for 4 hrs, when i try to turn it on it just has a blinking green light. Please help Solve It! .
The blinking green light means the unit is either Powering On (Warming Up) or Powering Off (Cooling Down).
Powering On the Projector
1. Remove the lens cap.
2. Securely connect the power cord and signal cable. When connected, the ON/STANDBY LED will turn Amber.
3. Turn on the lamp by pressing " " button either on the top of the projector or on the remote. The ON/STANDBY LED will now turn Green. The startup screen will display in approximately 10 seconds. The first time you use the projector, you can select your preferred language from quick menu after the startup screen displays.
4. Turn on and connect the source that you want to display on the screen (computer, notebook, video player, etc). The projector will detect the source automatically. If not, push menu button and go to "SETUP". Make sure that the "Source Lock" has been set to "Off". If you connect multiple sources at the same time, press the "SOURCE" button on the control panel or direct source keys on the remote control to switch between inputs.
If you are still unable to get the unit to turn on, try unplugging it for 10 minutes and plugging it back in. If it still ceases to work, contact Optoma here: http://www.optomausa.com/rma_policy.asp
Their Technical Support line is 1-888-887-5001
Feb 25, 2011 | Optoma HD20 DLP Projector
How do you hook up cable tv to my epson powerlite 830p lcd video projector
To hook up cable tv, you will need to have the cable running into a vcr 1st, then run either your s-video cable or audio video cables into the projector. Press the Source Search button on the remote control or the projector repeatedly until you see the image you want to project on the screen. The projector has two Source buttons.
Use the Computer/Component button to switch between equipment
connected to the Computer/Component ports.
Use the Video/S-Video button to switch between equipment
connected to the Video and S-Video ports.
? The remote control has four Source buttons. Use them to switch
between devices connected to the ports identified on each button.
(The PowerLite 830p does not support EasyMP.TM)
You can preview all sources on one screen to help you select the
desired source. (Allow a few seconds for the projector to sync up
after pressing the button.)
Feb 01, 2011 | Epson PowerLite 830p Multimedia Projector
Projector screen displaying "Searching" message. Does not recognize computer. Worked with one of your associates (Guru?) and we tried a number of solutions but none worked. She asked that I come back to...
If you are connecting to a laptop then you may need to hold the function button down and press F1, F2, F3 etc. there should be a sign with the latop on there and a sign with an external device (monitor,PROJECOR)
hope this information was useful to you.
Jan 21, 2010 | InFocus Office Equipment & Supplies
Sp4805 turns on by itself, direct tv picture will run for a short while then dorps out. I can't seem to pick a source? I tried my dvd player and it seemed to work normally. menu options are not highlighted...
In the sources menu where you assign sources, the second selection from the bottom is where you enable/disable sources which can inhibit a source/input from working even if it is assigned. Also check mark the auto source enable box.
If the input you are trying to use is not assigned or enabled many of the menu items are grayed out.
A quick fix is selecting the "factory reset" in the menu as the default factory settings are such that all input's are set to work.
Good Luck!
SagerTronics
Nov 13, 2009 | InFocus ScreenPlay 4805 Multimedia...
I have a NEC mt1055 and the unit just had new bulb put in here and it has the power and standby light come on and the fan doesn't turn on here and the standby light is yellow and status is red
The NEC’s work on a reducing time basis, they count the hours that they have been operational and refer to this as the life of the bulb – 1600 hours. When the 1600 hours has been reached the projector shuts itself down into standby mode never to be restarted even after changing the bulb / filters. This is because the unit needs to be reset, which needs to be done as follows (not included in any of the bulb replacement instructions):-
  • Plug Projector in so it is in standby mode – Orange light lit, Red status light lit (not flashing)
  • Using the remote control, hold down the power off button for 30-45 seconds
  • This will reset the status button, removing the red light
  • Power up the projector and select Menu
  • Select Projector Options
  • Select Set-up – a number of tabs will appear called pages
  • Arrow across the pages (MT850 is Page 5) until an option called “RESET LAMP HOURS” is shown
  • Move onto this option and press enter on the projector itself, confirm that you want to reset the counter
  • Projector is now back to life
This works for all NEC projectors, the page number may be different though where the “RESET LAMP HOURS” option resides.
Oct 07, 2009 | NEC MT850, MT1050, MT1055, MT1056...
Projector wont turn on
reset the lamp hour counter by (after you plug it in) holding down the enter, down, and menu buttons then press the power button. if it comes on, replace the lamp, it's old. if not, make sure the lamp door is closed completely and there's nothing blocking the fans.
Jul 08, 2009 | Sharp PG-MP66X DLP Projector
Projector will not power up, confirmed 120vac to unit is good
this particular model will not come on if the bulb is burnt out. check the bulb. most common problem.
David
May 25, 2009 | Sanyo PLC-XP57 LCD Projector
InFocus IN72 Multimedia Projector Logo
119 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
