Question about Denon AVR588 Receiver
Speaker crackle Denon 688. red/white audio cable from the direct tv box to the Denon. HDMI from the direct tv box to the Denon. HDMI cable for the out to monitor on the Denon to the TV. Speaker wires are connected properly, but I get no sound through any of the sources Dolby pro logic II etc. lot's of speaker crackle. what gives??
  • Anonymous May 04, 2009
    Denon 688. Cooxial cable connect from Sony DVD to the Denon Coaxial 1. Yellow cable from Sony DVD connected to my TV for Video.
    gives??
    Problem Solver:
  • 6 Answers
HDMI is a High Definition Multimedia Interface and has the capability to transmit both AUDIO and VIDEO all in one cable. Your setup right now is transmitting 2 audio frequecys (L/R stereo RCA and HDMI) into the Denon inputs. Not necessary! I would recommend eliminating the red/white audio cable from the direct tv box to the Denon.
After doing such, your receiver should be able to process audio/video signals appropriately. REMEMBER to unplug all POWER CORDS before reconnecting any speaker/audio/video cable, as it may cause a small electrical surge and fry a micro component in your system!
Posted on Feb 17, 2009
  • Paul spoli
    Paul spoli Sep 12, 2014
    Well I have the AVR-588 and same idea here but the HDMI alnoe does not produce sound and from the computer I turned it off so that I am using the speaker jack from the laptop alone. still crackle sound from only the left source speaker. It is not wires etc or cpeaker that is making that noise. any help would be appreciated.
No video on Denon avr 688
After days of frustration the real problem was with the cable box. It needed a firmware update. Following forum advice I disconnected the cable box power cord for a few minutes, reconnected it, allowed the cable box to reinitialize. Turned off receiver and TV. Turned TV back on and set it to HDMI connection, turned on receiver and all worked fine. Great picture and sound.( Needed to buy an optical cable to go from the cable box to the receiver to get sound from the speaker system. )--the dirtybird
Apr 14, 2009 | Denon AVR-3300 Receiver
Reciever problem
How do I connect direct tv to denon and then get sound
If the RCA TV has HDMI input connect as follows:
1. Connect an HDMI cable from the Directv box to an HDMI input on the Denon.
2. Connect an HDMI cable from the HDMI out-put on the Denon to the RCA TV
3. Select input the DirecTV is connected to at the Denon, at TV select HDMI input Denon is connected to TV.
4. On front of denon press the input mode button to select auto
If the RCA TV has Component input (Green,Red,Blue) connect as follows:
5. Connect Component Video and Audio cables from the Directv box to a Component Video and Audio input on the Denon (TV, DBS,VCR).
6. Connect a Component Video cable from the Denon to the RCA TV Component Video input.
7. Select input the DirecTV is connected to at the Denon, at TV select component input Denon is connected to TV.
8. On front of denon press the input mode button to select aut
If the RCA TV has Composite input (Yellow) connect as follows:
9. Connect Composite Video and Audio cables from the Directv box to a Composite Video and Audio input on the Denon (TV, DBS,VCR).
10. Connect a Composite Video cable from the Denon to the RCA TV Compositet Video input.
11. Select input the DirecTV is connected to at the Denon, at TV select composite input Denon is connected to TV.
Feb 25, 2009 | Audio Players & Recorders
Connection problem with Denon 589 and direct tv
Feb 08, 2009 | Denon AVR588 Receiver
Denon AVR-488 , problems routing cable box through receiver to tv
If you don't have one, the manual is available online: http://static.highspeedbackbone.net/pdf/AVR-488-OM-E_101.pdf
Suggestions:
1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
Now select the TV/CBL input and turn on the STB. You should have both audio & video.
Mar 08, 2017 | Electronics - Others
Speaker interference
you should be able to disconnect the analog audio cables from the cable box and Denon, with the HDMI connected, press the input mode button on the front left of the reciever to select auto and that should fix the issue
Feb 01, 2009 | Denon AVR588 Receiver
I have the denon avr-688 - when i use the mic to auto setup, i have sound from each of my speakers, but when trying to watch tv or a blu ray movie there's no sound at all
Check your blu-ray connection. Is the HDMI cable going from the player to the receiver, then another HDMI cable going from the receiver to the television? What about your TV input? Is there a cable going from the cable converter box to the receiver's input?
Dec 29, 2008 | Denon AVR688
No audio thru receiver with xbox360
Get some audio cables from radio shack or gamestop and use the regular audio jacks on the xbox to connect to your receiver.  Your video will be HD, but your audio won't.
Dec 22, 2008 | Denon AVR-1603 Receiver
Denon AVR 588 7.1-- Sound setup questions
This reciever does not decode the audio through HDMI, the HDMI ports are simply a pass-through. To get audio you need to connect an optical audio cable from the PS3 to the reciever also. I figured this out after 2 hours of trying to get audio from the HDMI cable. Here is a link that shows the different audio formats supported through HDMI by the different Denon models. It looks like the AVR-788 is the lowest model that supports audio through HDMI. Hope that helps.
Apr 03, 2008 | Denon AVR588 Receiver
I have a new Denon 688 7.1 CH reciever. I did a sound test on all speakers and they all worked. I hooked up Satelite rec HDMI and PS3 HDMI to reciever and then an HDMI from reciever to TV. I have Picture...
The Denon 688 does not process sound via HDMI, you have to run a seperate cable to get sound. Choices are analog audio jacks (red and white) or either a toslink (optical) cable or an rca digital audio cable.
Cheers!
Mar 15, 2008 | Audio Players & Recorders
Denon AVR587 Setup
red/white/yellow = composite
red/green/blue= component video cables + audio cables needed
the red/white= stereo audio
the denon 587 has 2 optical (toslink) inputs and 2 digital coax. These are surround sound cables basically, it's the only way to get true 5.1 dolby or dts.
connect cable box, and the samsung to the sony using hdmi. then connect the cable box and the samsung to the denon receiver with optical cable. And that's it.
Jan 15, 2008 | Denon AVR588 Receiver
Denon AVR588 Receiver Logo
280 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
