Question about Nikon D40x Digital Camera
Constant under exposure.....
The camera fell 3 feet onto concrete and ever since, when I take a picture you can barely see the image. It comes out near black. It's worst in auto mode. When I switch it to manual mode and lower my shutter speed way down I can almostget a normal picture. I don't know what it could be exactly. I took the lens off and it seems to be fine. I looked inside the camera and nothings loose. The only thing I figured is maybe the mirrow shifted inside? or The photo sensor is shot? Any suggestions?
  • thomtime
    thomtime May 11, 2010
    The problem could be with the camera or the lens. Do you have or can you borrow another lens to test with.
  • 88 Answers
I can tell you what your problem is. You dropped it on concrete and you are suffering from impact damage. You have a whole bunch of internal damage to your camera, Don't worry, like anything, it can be fixed. Because it was dropped, its not covered under warranty. I have a friend who can fix it for you.
http://www.cameradr.com/
He is my friend, tell him Nate sent you.
Posted on Feb 13, 2009
We had the same; it's damaged internal,and needs replacement.
That's gonna cost.
There's a temporal workaround (though the best and most professional solution would be to either replace the case, or get it repaired) which can help you for the time being.
1- Set the photo wheel (with green auto, M, A,S, P and icons) to 'P'; and set internally the ISO to 200 (the ISO will be neglected later on by manual overrule).
2- Use flash in darker environments if possible.
3- Set the exposure to +5
Pressing the Zoom In (+) button twice, use the 4-way pad (on the right of the TFT screen) to go 1x to the right ( [+/-]+0.0 ) and select by pressing the 'ok' knob.
This should give you 'exposure comp.'
Set value to +5.0
4- Set 'Flash Compensation' to +1.0 in that same menu (the twice zoom menu. The icon needed is similar only with a lightning sign, and is found on the right to exposure comp '[+/-]' knob ).
This should get your exposure maximized
Refrain from touching the ISO at this point, which is fairly useless and might trigger the 'shutter-error' message.
Be aware that in that state, your camera is like 'a car running on 3 cylinders' so to speak
Posted on Feb 23, 2009
Canon powershot a470 vertical lines, white picture, blurred
The image sensor is defective. There is no quick fix other than replacing the image sensor.
May 13, 2017 | Canon PowerShot A470 Digital Camera
I dropped my Nikon D90 (Lens clicking and Battery problem)
No. The warranty does not cover damage caused by dropping it. Maybe you have an insurrance that covers it?
Jun 30, 2010 | Nikon DSLR D90 Digital Camera
My lens is stuck half way out.
try Googling "E18" and read about this error signal and the many possible fixes. In your case sometimes gentle (really gentle) inward pressure on the lens tube while turning camera on (or off) will get it going again. Best wishes
Mar 04, 2009 | Canon PowerShot A530 Digital Camera
Kodak easyshare C530
Hey neilhowie,
I would make sure that your subject is within the range of the flash which for wide angle shots is 8 feet, and for telephoto shots is 9 feet. Another suggestion is to make sure auto exposure has been achieved by holding the shutter button halfway down until the green light appears and then take the image. Another thing you could try is to increase the exposure compensation. Nighttime photographs are difficult no matter what camera you are using so make sure your mode is set to nighttime, and of course your flash coverage would be the same as mentioned above.
Sincerely,
Allan
Go Ahead. Use Us.
May 14, 2008 | Kodak EasyShare CX7430 Digital Camera
Image Properties shown....You've been great!!!! Few more....
1: it just adds and copies existing pixels with the digi zoom. I never fooled with it for you can just take the image with a paint program and blow it up as big as you want.. with decreasing detail.just start with a nice high megapixel like 5M camera but you'll need a bigger memory card.
2: exposure bias at 0.0 is what the camera sets as standard. adjusting this in the "M" mode allows more exposure "+" or less "-". making the aperture bigger or smaller to allow more light or less at higher shutter speeds or low speeds. 1/100 is good.
3: yes but try it out and put it on automatic first.
4: focal length or f stop I'm confused. The aperture setting is known as the f-stop. The lowest number f-stop lets the most amount of light reach the image sensor. A high f-stop increases the depth of the field.witch is focal length. so I think I was wrong in the "feet" meaning f/2.8 for portrait or up close f'/16 for front and background or landscape. also set your ISO around 80 - 120 for the best exposures or pictures.
May 10, 2008 | Cameras
1: bias means voltage a neg or plus I assume the plus means more exposure.
2: focal length in feet ..if not using auto-focus
3: 4.6 feet
4: digital zoom is something I would never mess with but 3072/3072 sounds like a 3 megapixal square.
5: yes set the exposure to a fast shutter or bias in your case like - 3
6: why sure and quite a few pics in 1 minute with the right camera.
Nikon camera d40x image too dark.
The e fall dames the camera -evidently There is not user repair possible Contact Nikon for a repair quote.
Sep 01, 2007 | Nikon D40x Digital Camera
Blurry pictures
It is possible you were shooting in the NIGHT & PORTRAIT Scene mode. In this mode, the camera sets a slow shutter speed for the background exposure and fires the flash for the subject exposure. Since the shutter speed is slow, your subject should be still and the camera should be on a tripod - otherwise blur can result. Since this mode should only be used when the above conditions can be met, you should select PROGRAM AUTO mode for low light situations where you are taking images within six feet of your subject and the flash is required for proper exposure.
Sep 01, 2005 | Olympus D-630 Zoom Digital Camera
Blurry pictures
It is possible you were shooting in the Night Scene mode. In this mode the camera sets a slow shutter speed for the background exposure and fires the flash for the subject exposure. Since the shutter speed is slow, your subject should be still and the camera should be on a tripod otherwise blur can result. Since this mode should only be used when the above conditions can be met, you should select Auto or Program mode for low light situations where you are taking images within six feet of your subject and the flash is required for proper exposure.
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
Blurry pictures
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
Nikon D40x Digital Camera Logo
80 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
