Question about Symphonic ST419E TV
TV Will Not Turn Off With Digital Cable Control
I recently went digital with Comcast Cable. I followed the directions to set up the cable box and program the remote. The setup codes that Comcast gave me for Symphonic TV's are 10180 and 10171. When I programmed in 10180, the remote did not control the TV at all. When I programmed in 10171, something strange began. When I push the "All On" button on the cable remote to turn on the cable and the TV, both come on as expected. When I push "All On" (or use the "sleep" timer on the remote), power to the TV does not go off. The TV APPEARS to be off but there is still a faint light emanating from the screen and a buzz can be heard. If I push the power button on the TV or on the TV remote, the TV turns off. If I try to turn on the cable and the TV when the TV is in this "sleep" mode, the cable comes on and the TV turns off! So then I have to power up the TV separately.
I asked Comcast for help and they were NO help whatsoever. Can you advise me.
  • pittman32 May 24, 2009
    I have the same problem with my syponic tv and comcast. If anyone knows what code to use, please help!!!!
  • 27 Answers
The remotes you get from the cable company are universal and kinda cheap. ive ran across this multiple times but since i dont know what model remote you have the only advice i can give is that the code you used is not the right code if it doesnt do all basic functions (on,off for the tv,volume)its just the wrong code if the codes you stated are the only ones available the book you got with the remote should explain how to run an auto scan.hope i was some help
Posted on Aug 23, 2009
I have a 2007 Philips 32" TV. Recently, our cable co. changed to "digital" and added a box to route the service through to the TV. We are now going to give this TV to my mother-in-law who...
If the facility is using just standard analog cable, it should be fine. Just turn the TV on and go through the setup menu and let the TV autoprogram itself to find and program into memory all active channels
Jul 19, 2011 | Philips Televison & Video
I have a Panasonic PV-V4525S VCR and I'm trying to program it to work with the Comcast cable. Right now it will only record the same channel that the TV is on and I have to tell the VCR to record channel...
If your using digital cable it will only record channel 3 or 4 depending on what your cable box is set to...In order for it to record different channels it needs a cable source plugged directly into it. You will only be able to record standard cable channels 1-125. If it's digital cable forget about... you can only record it with channel 3/4 a solution to this would be using a 2nd digital box.. "auto-programming" may be limited even with a 2nd cable box. If your only using standard cable 1-125... you can use the TV/VCR button it will switch between the tuner of the TV & VCR allowing you to record while you watch a different show... keep in mind this won't work for digital channels which if I'm not mistaken comcast has already converted all channels to digital even basic.
Feb 13, 2011 | Panasonic PV-V4522 VHS VCR
Recently comcast converted all of its cable station to digital, and I am wondering if my RCA television is compatible. We are not getting channels. Model F316335B from 1995
If you connect your TV antenna input directly to the wall, you will need an on-demand box or a converter box from Comcast.
Sep 13, 2009 | RCA Televison & Video
We recently purchase 2 TB1 10MW9 DTV Digital Analog Converters to connect to 2 of our Ananlog TV's. Our TV reception is from Comcast Cable & we had then set-up our Main TV with their converter. Our...
U have paid cable, u don't need the converter box.Not even the analog tv require the coverter box, if u have paid cable or satalite tv or telicom signal.All ur tvs is hook up to the Comcast Cable correct?That all u need not, require the converter box.
Sep 03, 2009 | Televison & Video
Significant volume decrease when using Comcast cable box
This low audio problem happened to me suddenly yesterday. I powered off over night - no change. I plugged the A/V cables into a second TV - no change. I called Comcast - problem solved.
Tap these buttons on the remote;
May 16, 2009 | Panasonic Viera TC-L37X1 37 in. LCD HDTV
I think I may have the "answer".
I am in Atlanta and have a Panasonic DVR that was working fine and sometime during the past month or so we lost the channel listings. I've tried many resets as well with negative results.
I called Comcast tonight. The agent helping me took a long time to research the issue and gave me this answer (which sounds reasonable). By the way, this is for the Atlanta area and may not be applicable to other areas of the country.
Due to delays in the conversion to broadcast digital and the fact that Comcast is experiencing bandwidth issues, they have digitized the "channel listing" signal. By mid-June Comcast's signal will be all digital and you won't be able to watch a TV connected directly to Comcast cable - regardless of whether it has digital or analog tuner (or both). This is contrary to what I'd heard before.
After mid-June, you'll either need to use a cable box OR what she called a "Digital Transmitter Adapter" (let's call it a DTA). Prior to being converted to "full" digital, you'll get notification from Comcast. She said I'd be able to get 2 DTAs at no charge (I currently have one Comcast HD DVR box). Additional DTAs would be $1.99 a month. DTAs will only provide access to the "basic" cable channels, but the good news is that the Panasonic DVR should be able to obtain its channel lineup through this DTA box.
If you have any questions, please feel free to contact me directly at
Good Luck!
Mar 30, 2009 | Panasonic DMR-EH50 DVD Recorder
FLM3232 will not receive channels directly from Comcast Cable
Use the TV/Cable rf jack and auto program the TV.
Mar 16, 2009 | Polaroid FLM-3232 Television
Sylvania lc370ss9 remote problem, comcast
you have to turn off the power save setting
Mar 01, 2009 | RCA RCR450 Remote Control
Jumbo Universal Remote
I have a Motorola DVR from Comcast. Code 051 will make all the cable functions work. Haven't figured out how to do anything with the DVR bits,
Dec 26, 2007 | Universal Remote Control NspireGear MP3...
Symphonic ST419E TV Logo
410 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
