Question about Canon PIXMA MP600 all-In-One InkJet Printer
Won't Print Quicken Checks- Canon MP620
Just purchased a Canon MP620 printer - it won't print checks from Quicken. We tried an HP 6320 and it wouldn't print checks so we returned it and purchased the Canon MP620, the MP620 will print Quicken reports, just not the checks. We replaced a HP Photosmart C4280 because it wouldn't print anything from Quicken. Technical support with Quicken was of no help, they didn't seem to even be aware there was a problem.
  • Anonymous Mar 20, 2014
    colour
  • 741 Answers
Here is all I could find, as it is a compatiblity issue and not a repair issue. Hope this helps. You can also get on an online instant chat at www.hp.com and they may also have some answers for you.
HP has apparently released new printer drivers for some of their
> printers that will fix at least one print problem experienced by
> Quicken users.
> If you have an HP printer and are having problems printing from
> Quicken and you use 64 bit Vista, check this HP faq to see if there
> may be help for you.
> http://tinyurl.com/89ly3u
P.S. It appears that the fix will apply to more printers than are named in
the faq; The way I understand it, if there is a version 12 driver available
for your printer model, you probably should get it.
Apparently the list of printers to which the fix applies will be updated at
some point.
Don't forget to rate this 4 stars before you log out. If I can be of any help let me know.
Posted on Feb 01, 2009
I cannot get my HP 6500A Printer to print my Safeguard checks. I can print the checks on blank paper and then copy them onto my Safeguard checks, but I cannot print directly to the check. I can print to...
I had the same problem and a HP Tech finally found a solution and I hope it works for you...When you print, change your ink quality to "Draft". I tried EVERYTHING and could not believe this worked. Good luck.
Feb 03, 2011 | HP Officejet 6500 Wireless All-in-One...
Quicken reports won't print
Go to printer under control panel and right click on the printer - select printer properties...advanced tab...check print directly to printer. Checks should print now. Downside...everything prints directly to the printer (no spooling) which can be slow at times. Also I have found printing pdf's using this option won't print so you'll have to change it back. I'm using Windows 7
May 06, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Printing check error code 7224
Using Quicken Premier 2009 on Windows 7 x64 with HP OfficeJet 7310.
My check wouldn't print and was booted out of Quicken. Validated data (was OK), reinstalled Quicken Premier 2009 (per instructions above), checked printer and driver (was-OK), I still could not print checks (error code 7215 and quicken closed).
SOLUTION: I deleted the transaction I was trying to print, the re-entered it. It printed fine.
Feb 13, 2010 | Intuit Quicken Premier 2009 for PC
Can't prints checks from Quicken on wireless printer
I contacted HP and they told me it was a software incompatability issue between Quicken and their printer drivers. They provided me with additional drivers to solve the problem.
Dec 06, 2009 | HP Photosmart Premium C309A All-In-One...
HP Photosmart C4150 will not print in quicken
Have you selected this printer from within Quicken?
Select the File pulldown, select printer setup, select for graphs or checks - follow the instructions.
If I misunderstood your question or there is a differrent problem, please post a comment to this quesiton.
I hope this information helps you.
Thanks for using FixYa.com
please vote
a
Dec 06, 2009 | HP Photosmart C4150 All-In-One InkJet...
Quicken 2009 Deluxe will not print on Vista 64 system on HP 5610 All-in-one printer - ran all the usual suspects about drivers, rebooting, selecting right printer, etc. etc. no luck. Seems Quicken does...
Me too. None of my printers worked and each time I tried Quicken crashed. But only quicken had this problem. Then I read this super simple fix:
  • Click Edit from the menu bar, and choose Preferences > Quicken Program.
  • Go to Register > Notify, and remove the check mark from “Warn if a check number is re-used”
  • Click OK.
  • Print checks.
At this location: http://tinyurl.com/moehn3
Worked like a charm. Go figure. Wasn't even a duplicate check number.
Aug 18, 2009 | Computers & Internet
Printing check from Quicken 2009 Deluxe
All Printers have this issue printing from quicken you would need to download the older version of quicken from oldversion.com
Then uninstall the new version and install the old version.
all lexmark/canon/epson/brother/hp.....printers have this problem with the new quicken.
Or try calling in to us at 1800-474-6836 and provide us with a remote session with your computer we may be able to fix this issue with a basic driver.Let me know if you have connected the printer thru usb or ethernet and I will give you a resolution that works 70% of the time with the new quicken
Jun 16, 2009 | HP OfficeJet 6310 All-in-One Printer...
Won't print checks or anything from quicken but does for every other program. All I get is "spooling" and then nothing.
It won't print you have to save the file on the desktop or in documents or anywhere away from the original and then try to print.all printers have issues with quicken deluxe they will not print from quicken deluxe unless it so happens b fluke
May 29, 2009 | HP OfficeJet 6310 All-in-One Printer...
Basic Quicken on Windows Vista will not print to HP psc 2410
Symptoms:
This issue occurs after updating to Release (R6). Quicken is attempting to display a duplicate check number message, when the error occurs. We have identified this issue to be caused by one or more duplicate check numbers in the checking register.
Solution 1
  1. When clicking Print Checks, the next Check # to be printed is displayed. Take note of the check #, and then click Cancel.
  2. From the Checking register, click Find and search for the check number.
  3. Edit the transaction(s) to include the correct check number, or remove the check # from the transaction.
  4. Print checks.
Solution 2
  1. Click Edit from the menu bar, and choose Preferences > Quicken Program.
  2. Go to Register > Notify, and remove the check mark from “Warn if a check number is re-used”
  3. Click OK.
  4. Print checks.
May 01, 2009 | HP PSC 2410 All-In-One InkJet Printer
Check printing
Open HP Solution Center, Click Settings ---> Print Settings.
Click Features tab, select the Paper Type as Plain Paper.
Select appropriate Paper Size under Size. Click Ok.
Now Print Cheques from Quicken.
If the issue still persists, Navigate to Printers folder, right click on the printer icon and click Properties. click Advanced tab, enable Print directly to printer. Click Apply.
This should now Print the Cheques.
If the issue still persists, install alternate drivers in Vista.
Here are the steps:
Click Windows logo ---> Control Panel ---> Printers.
1) Click Add Printer
2) Select local printer
3) Choose Port as LPT1
4) Choose HP and then select HP Deskjet 6500
After the driver is installed, perform below steps:
1) Right click on HP Deskjet 6500 printer icon in Printers folder
2) Click on Properties
3) Click on Ports tab
4) Choose USB001
5) Click Apply and click Ok
Now try to print.
Mar 19, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
1,115 people viewed this question
old marine
old marine
