Question about Sony KP-53HS10 TV
Hello, I have a Sony KP-53HS0 projection Tv. I plan to attach a HD receiver to it. What kind of cable do i need? Will I need some type of adapter?
    Problem Solver:
  • 6 Answers
You can just use any standard component cable Red/Green/Blue doesnt have to be anything fancy, I dont really buy into monster cables being that much better than just standard quality cables from Walmart/Kmart
Posted on Mar 01, 2009
  • tpala129 Feb 20, 2011
    anyone know where i can find a sony kp-53hs10 hd receiver for my old hd ready t.v?
    thanks
    tim
    tpala@comcast.net
Not getting HD from the set. I have an HD cable box. I bought an HDMI adapter, but still no HD.
The cable box output needs to be set to HD, 1080I, 720P, 1080P. If you call the cable company they should be able to set the box up to ouput a higher resolution. A way to check your hd would be to play a blu ray disk through a ps3 if you have friends with one or have one yourself. If it plays hd just fine you know for sure it's the cable box.
May 07, 2010 | Sony KP-57WS500 57" Rear Projection...
How do I get hd tv channels on a Sony KP-43HT2? The set is HD ready. What do I need to enable reception of HD?
hi
you will need a Hd input. In the uk there are 3 ways to obtain this
1 sat Box that will receive HD
2 Freebox that will receive HD
3 Blue ray Dvd Player
Note not all ditgal transmitters at the present time do not transmitte HD and will not do so untill the DSO is complete in2012.Hope this will be of help.
regards windyhouse
Apr 02, 2010 | Sony KP-43HT20 43" Rear Projection...
Will I be able to receive HDTV programming on my TV?
Your HDMI Cable or Component Cables will plug right into their receiver box. You won't need anything else and they should supply the cables too.
Jan 06, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Sony kp 51ws510 upgrade to HD - how to do this
There are inputs on the back of the set. If your tv is Sony 51ws510 then it is capable of HD, but you have to have component or DVI cables to connect the tv to the HD device (HD cable box or DVD player).
<br>
<br>
On your set the component inputs on the back of the tv are video5 and video6 in the middle located in a vertical line (red, green, blue rca video connections with red and white rca audio connections).
<br>
<br>
You also have a DVI input toward at the top of the input panel (white connector with red and white rca audio connectors).
Jan 03, 2010 | Sony KP-51WS510 51" Rear Projection...
Convert my Sony kp61hs10 HD Ready to receive HDTV
no need to convert ,,i have same tv,,hdready just means it has no built in converter. You just need a HD converter box or a cable box or dvr that is also an HD receiver.
Dec 14, 2008 | Sony KP-61HS10 61" Rear Projection...
Sony projection tv with dual tuners; only one tuner appears to be working now.
To verify that the tuner is the problem, move the cable from the second to the first. If you don't get a signal, the tuner is bad. The main tuner is part number 859843000 and is available for $47.38 from tritronicsinc.com
Dan
Oct 07, 2008 | Sony KP-51HW40 51" Rear Projection...
Screen goes black and resets during HD shows
I just posted this to another Sony owner:
Another point; HD Ready does not mean that it is HD compatible without the addition of an optional part.
The title only implies that it can be adapted to HD reception.
If you did not purchase it with the set, check your user guide to see what you need to make it whole.
You may have to seek this add-on on eBay since it is not guaranteed that Sony will still offer it.
You might want to check this:
Technical Details · 53-inch HD-ready rear-projection TV (doesn't include HD receiver); 48 x 57.5 x 25 inches (W x H x D)”
From: http://www.amazon.com/Sony-KP-53HS10-53-Inch-Projection-TV/dp/B000050FGB
Aug 31, 2008 | Sony KP-53HS10 TV
Progressive scan
progressive scan? does your tv support 720p, or 1080p HD? (the p actually stands for progressive scan).
Another alternative to that is: http://www.playerschoicevideogames.com/pd_psp.cfm
A bit more expensive, but i think it works on any tv.
Jan 06, 2008 | Sony KP-53HS30 53" Rear Projection...
Sony KP-57HW40 tv is what we have now and is this a high definition tv?
After the FEB 2009 cut over, your "OLD" tv will nolonger be able to receive OFF THE AIR signals as they will be broadcast over different frequencies. HOWEVER, as long as you subscribe to CABLE or SAT TV (Dish/Directv/etc) your old TVs will continue to work as they always have -- (because the signal is not OFF AIR) but you just won't have an HD picture.
Dec 21, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-53HS10 TV Logo
97 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
