Question about Xantrex Technology Xantrex Charge Controller for DC Charging Sources 35 Amp (456010) Power Supply
No power through 35 amp charge conttroller
I have the 35 amp charge controller and on occasion there is no power passing from the solar panels to the batteries. By placing a meter on the input I find the problem is in the controller any reason why this would be an intermittent problem?
  • 714 Answers
Refer to the manual.
Do you have the correct setting for the Bulk load?
Open the cover and look.
Hope this tip helps.
r/
David
Posted on Jan 29, 2010
How long does it take to charge battery in solar fence charger?
    1. A solar powered electric fence energizer usually contains a battery for energy storage. The solar panel collects the energy from the sun and charges the battery. Lead acid batteries, which are used in solar fence chargers, typically last around 3 years, or around 1,000 days of charging.
      About Fence Chargers - Zareba Systems
      www.zarebasystems.com/learning-center/all-about/fence-chargers
    Feedback
  1. About Fence Chargers - Zareba Systems
    A solar powered electric fence energizer usually contains a battery for energy storage. The solar panel collects the energy from the sun and charges the battery. Lead acid batteries, which are used in solar fence chargers, typically last around 3 years, or around 1,000 days of charging.‎What can I do to prevent ... - ‎What factors should I consider ...
    [PDF]Fence Controller Installation - Zareba Systems
Jan 01, 2016 | Cars & Trucks
I have solar panels that put out a little more voltage then they are rated at,and they keep faulting out my grid tie inverter.I need a resister to knock down the voltage about 8 volts, got any ideas?
I like to ask, is the voltage from the solar panel messure with some load connected or is open circuit, normally solar panels produce high voltage than the working system, the reasson for that is to have Amperes in of to charge the batery, these is related to the size and power generated by the panel.
No need a resistor or in any case use a voltage regulator to prevent over charge.
Apr 14, 2015 | Inverter Electronics - Others
Would like to know more about the solar panels discussed and shown on 2nd October 2014 at 05:15+
Solar panels are typically rated at .3 volts per cell. These cells are connected in series until they add up to 12 volts,24 volts or 36 volts depending on the solar system. The more cells you have the higher the charge rate of the batteries connected to the system. The DC voltage from the cells are used to charge the batteries then the voltage from the batteries is used to drive a DC to AC- convertor which is the power used by your home. The more cells connected the quicker it will charge the batteries and the more batteries connected the more power the solar system can provide.
Oct 04, 2014 | Solar 200 Amp Murray Mda 2200 Main Circuit...
Why my SOL4UCN2 receives 18V but yields mere 12V for the charging?
Solar Panel Charge ControllerMCM Part 28 11138Velleman SA Part SOL4UCN2
This is a small charger mostly for small batteries and devices. It puts out max of 4 amps. What type of 12 v battery are you trying to charge?
Jun 07, 2014 | Velleman SA SOL4UCN2 Solar Panel Charge...
Unit does not light up
Check the input voltage terminals for power from your array. if there is no power at the input terminals, remove the wires from the controller and check for voltage again on the input wires. If there is still nothing, trace them back and keep checking each connection all the way to the panels. May be a bad connection or wiring. If you have input to the controller, it is being grounded for some reason or the circuit is open. Look for a fuse or reset on the controller. The controller its self may be bad.
Dec 22, 2013 | Morningstar ProStar PS-15M-48V, 15 Amp 48...
Solar Charge Controller should be giving 5amps but only getting 1.5 amps. Please assist
The charge controller is not designed to absorb power it is normally an on or off situation. (sometimes at high speed).
If it was absorbing 3.5A it would go on fire.
I would suggest checking the solar array by shorting it while out of circuit this will determine the mpp current of the array within about 3% at a given time, reconect the array back on to the charge regulator (assuming the sun has not suddenly been covered by a cloud).
If the current is dramaticaly lower than the short circuit current then the battery bank may be controlling the amperage volume, If this is the case there may be a number of reasons for this which would require further info.
Sep 19, 2013 | HQRP 10A Solar Charge Power Controller /...
Solar Charge controller Model 16-24 amp. The solar
Have a load test done on the battery as if there is dead cell it will not allow a charge because there is no circuit.in the battery
Sep 19, 2013 | Juicers
Having trouble with Solar charge control. Prostar.30. no light on and appears not to be charging batteries, light has flickered on and off twice, have checked the solar panel, Batteries are holding at...
That's an issue with the inexpensive charge controllers that is known. The internal voltage regulator and pulse width modulator isn't performing correctly and interpreting the power from the panel. I recommend you look at getting an AIMS Power charge controller. Their 30A model is flawless.
Apr 16, 2013 | Morningstar ProStar Charge Controller,...
SunForce 2500w pure sine wave converter add on
Mixing different AH rated batteries, different ages of even the same type battery is a bad idea. The new batteries will be effectively reduced to the equivalent of your worst battery.
Jun 24, 2010 | Sunforce 11260 Pure Sine Wave Inverter
Pls i need an answer
Solar panels come in different ranges of wattages.Add up the wattage of different solar panels you get e.g. Ten 100W solar panels will give you a 1Kw solar system.
Jul 11, 2008 | Sun (PEX75030) 15-Watt Power Supply
Xantrex Technology Xantrex Charge Controller for DC Charging Sources 35 Amp (456010) Power Supply Logo
170 people viewed this question
Top Xantrex Technology Computers & Internet Experts
Are you a Xantrex Technology Computer and Internet Expert? Answer questions, earn points and help others
