Question about Maytag Neptune MAH5500B Front Load Washer
How do I open my maytag Neptune MAH9700AWW front load washer?
How do I open my maytag Neptune MAH9700AWW front load washer so that I can get to the motor?
  • 398 Answers
First get access to the back of it. find the screws that hold the accsess panel on unscrew and look underneath. its on the bottom.
Posted on Feb 19, 2009
Neptune MAH9700AWW
I can only assume it's because you have no water connected to it. Some washers have a pressure switch that won't allow the machine to turn on without it being connected...try it and see what happens.
Jun 08, 2012 | Maytag Neptune MAH6500A Front Load Washer
Maytag mah9700aww,will not spin(laundry soaking wet)
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
,.,./l;
Mar 05, 2011 | Maytag Neptune MAH9700 Front Load Washer
My mah9700aww door stays locked and when i try to start it in any cycke i just hear a humming coming from the assy pump drain.
my mah9700aww door stays locked and when i try to start it in any cycke i just hear a humming coming from the assy pump drain.
Aug 01, 2010 | Maytag Neptune MAH9700 Front Load Washer
Maytag Neptune MAH9700AWW - no power to pump.
Check water level switch, pump motor relay that activates the pump.
Apr 06, 2010 | Maytag Neptune MAH9700 Front Load Washer
Maytag neptune mah9700aww error code nd
Remove water pump, check for thongs, baby socks and sometimes hair pins or even screws can obstruct the water pump.
Simply remove the pump and remove the obstruction that is keeping it from draining.
This will fix your problem.
Apr 01, 2010 | Maytag Neptune MAH5500B Front Load Washer
Front load washer not spinning correctly
I had the same problem, once I remove the shipping bolts on the back of the machine it worked fine.
Feb 01, 2009 | Maytag Neptune MAH9700 Front Load Washer
Mah9700AWW maytag washer dooer is locked
unsrew the lid to soap dispenser and search for the cord , you probably have a bad wax motor(lock motor)
May 15, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
974 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
