Flash card and F/W for Mita KM-2030
Hi guys,I posted a question recently for a Mita KM-2030 that was receiveing a Checksum Error F1. You gave me an answer of install new firmware via flash card. Which flash card do I need? Where do I get the flash card? How do I load the F/W onto that card so I can the follow your previous instruction of reloading onto the printer. I am a novice with this stuff, so please spell out all details. Thanks, Jerry
The flash card would be a usb drive flash card or a mini flash drive. I am not sure which one your copier needs if there is a usb drive you can just use a usb drive to plug it in or if not there might be a slot around the side or the back about 2 inches long where you can insert a mini flash drive which looks like a square drive about a quarter inch thick that will plug into that, you may need to buy an external slot to interface with your computer.
Posted on Feb 15, 2009
I hit duplex, then 2 sided and get a cannot combine error
Right, you can't use both at the same time. Try only one at a time.
May 10, 2015 | Kyocera Mita KM 1530/ 2030 Copier Machines...
Call for Service ...... C710
Hi there
I have found various documents which may help you with this problem and possible future problems. This page:
Error Codes Kyocera Mita KM1530 Code C710
can find any code connected with Kyocera mita machines by changing the machine and the error code in the appropriate drop down menus. C710 is identified as:
Description Toner sensor problem
• The sensor output voltage is outside the range of 0.5 to 4.5 V during toner control.
• The toner sensor control voltage cannot be set within the setting range when maintenance item U130 is run. Causes Defective toner sensor. Poor contact of the toner sensor connector terminals. Developer problem.
Another page showing error codes and their meanings is here;
Kyocera Mita Error Code Messages
and this confirms the above.
Also the link below takes you to a Kyocera web page where you can download various manuals for this machine (KM-1530). By changing the product in the drop down menu to KN-2030 you can get similar manuals for this machine.
Download Center
In your question you mention "Compatible KP23153 Black Toner Cartridge 106153" and that led me to wonder if the compatible cartridge is the cause of your C710 error since that is toner related.
Might be worth trying an original cartridge to see if the error goes away.
Hope this is helpful, if so would you please register that with Fixya
Nov 24, 2014 | Kyocera Mita KM 1530/ 2030 Copier Machines...
I Keep getting a j10 display when I try to print on the display
A J10 shows up if there is no feed from the upper paper tray. Check the operation of the paper feed clutch for the upper drawer.
Good luck,
Dec 18, 2013 | Kyocera Mita Mita Copier Toner Cartridge...
I have a Kyocera Mita KM 1530. User maintenance, the lights are now lit. Now I know I need to replace the drum, but someone can tell me later if you need to reset some or mute only the drum and is already...
press in sequence 10871087...
Go to U251 using cursor keys.
Check and clear PM count(copies since from last PM and PM reset).Press start to display six digit PM cycle. Select "Clear" w/ cursor up/down to clear count back to ..
Go back to U001 and press Start key to exit.
Sep 16, 2013 | Kyocera Mita Km 1530 2030 Copystar Cs 1530...
Km-2030 Checksum error f1
my copier is displaying error code 100, whats the problem km 2030
Jan 21, 2009 | Kyocera FS-2000D Laser Printer
Kyocera mita km-2030 call service error
open the left side door and push in the drum unit firmly. it's the part above the waste toner
Nov 03, 2008 | Kyocera FS-2000D Laser Printer
114 people viewed this question
