Question about Bernina Artista 180
How do i use the zigzag stitch on my bernina 830
I know it's user error that I can't make the zigzag stitch work since I've used it before but now I can't remember what settings everything needs to be at.
  • Anonymous Mar 14, 2014
    bERNINA 730 CRACKED STITCH LENGTH SHIFTING LEVER ZIGZAG KNOB
  • 202 Answers
Hi, open the top cover and if you watch what goes on inside from the top when you move the top change lever you will see part of it goes through a fork or U-shape part. This part is probably stuck and needs some oil. After oiling and working it back and forth a bunch eventually it will start snapping into the notches its supposed to. I beleive then you will have your zigzag back.
Either that or you have the stitch width set on zero.
Posted on Feb 07, 2009
    New Friend:
I purchased an 830 Record and my top was stuck shut too. I youtubed the problem and found the cure which worked perfect. The top door catch is located dead center at the front, under the stitch pattern lever. Slide a thin stainless steel spatchula from the right edge of the machine through that thin gap between the top and the body of the machine to just stop to the right of the stitch pattern. Then pry with it. It will pop open. Don't use a screw driver or anything narrow like that or you can chip the paint or deform the metal itself. After it pops open your next problem is freeing up that catch. It takes oil and force to get it to start moving front to back, back to front. Once its freed up, it will open and close perfectly again. If you don't understand these instructions, go to you tube and type in "my Bernina 830 top door is stuck shut" and you will find the 5 minute tutorial on this fix. Good luck!
Posted on May 25, 2015
  • Bernina Master
  • 11,200 Answers
To open the top of an 830 Record, open the side cover where the light is located (left side opens like a door--right to left). The gently pull up on the top lid (opens front to back).
If your machine has not been professional serviced recently or you have not cleaned and oiled it lately, then you might refer to your owner's manual instructions for oiling. I would suspect that perhaps the oil has hardened and is preventing the machine from operating properly--perhaps some of the selector lever/dial mechanics are not moving internally. Use liquid Tri-Flow Synthetic Oil (usually available at the hardware store) and put a drop or two every place that the manual recommends. Direct a hot hair-dryer into the internal works of the machine. (I usually let it get pretty warm to the touch - but make sure to stop periodically because your hair dryer may overheat.) Test your machine. If you can determine that the selector lever/dial mechanics are not moving, you can try putting a drop or two of oil in its metal joints and working it gently back and forth to loosen. Depending on how hardened the oil has become, you may have to repeat oil/hair-dryer process several times before things loosen up. Once it is working again, be sure to clean and oil regularly. (I recommend a good quality oil, ie Bernina oil for mechanical machines. It may seem expensive but it lasts a long time if you use only one or two drops each spot and, IMHO, is worth it in the long run. I do NOT recommend 3-in-1, WD-40, cooking oil, or the cheap sewing machine oil from fabric departments.) You have a wonderful machine and it will continue to serve you well if you treat it well. Suggest cleaning/oiling every time you change a bobbin, every 8 hours of continuous use, or every six months if it is not in regular use.
Posted on Mar 25, 2015
I have the same problem with a bernina 830 record that won't ziqg zag, but I just can't open the top cover, it is locked!
Is there a trick to open it?
Posted on Jul 24, 2011
Bernina 830: When making a buttonhole... the zigzag #1 stitch on left side looks nice... then the #2 bottom bar tack looks good...
Please tell us which Bernina 830 you have--old mechanical Record or new computerized?
Here's a recommendation from a Bernina owner (Ellen Rosenthal on Yahoo Group "BonosBerninas":
I agree about the buttonholer. The reverse stitching never looks as good as the left or forward side. I “hack” this by pivoting my fabric and only
going forward-avoiding the reverse stitch. Also helps to do the whole process twice and to use some tear away or wash away interfacing.
There is another Yahoo group called "BerninaThirtySomethings" that is a great resource.
Jan 25, 2018 | Bernina Sewing Machines
Tip
Sewing Machines How do I make a zigzag stitch
When it comes time to do your actual project, you'll want to use thread that matches the color of your fabric.
  1. Step 1 Zigzag Stitch. ...
  2. Insert your fabric into the sewing machine and depress the presser foot. ...
  3. Guide the fabric through the machine to keep the stitch straight
Zigzag Stitch iFixit
How to Make Zigzag Stitch Sewing Machine
Bernina 550 40 Triple Straight Stitch Zig Zag
Zigzag foot 0
https://blog.bernina.com/en/2017/01/useful-stitches-are-also-decorative-stitches
Bernina Sewing Machines How do make zigzag stitch Google Search
on Dec 13, 2017 | Sewing Machines
The zigzag on my Bernina record 830 bought in the '80s does not work properly. What can I do to get it to stitch wider than 1/8?
Your machine is seizing due to lack of regular oiling.
Here is a diagram of the oil ports for your 830 Record:
http://www.fixya.com/support/r25625872-bernina_930_record_oil_diagram
Following is the process I used to "save" a few older Berninas:
Wheel on right side that controls the needle up and down is very tight...
Apr 29, 2017 | Bernina Sewing Machines
My Bernina 830 will not switch stitches. It says the number but shows straight stitch and sews straight stitch
Is it a new 830 computerized model or the older 830 Record mechanical?
If it is the 830 Record, it needs oiling--1-2 drops of good quality sewing machine oil (specifically concentrate on the stitch selector lever and oil the metal parts that move against other metal parts) Do NOT oil the cams, plastic gears, any rubber parts, ie belts, bobbin winder wheel.
Bernina 530 through 830 Record Oiling Diagram
Oct 19, 2015 | Bernina Sewing Machines
My Bernina 830 sewing machine will not do a zigzag stich
We are assuming that the zigzag width dial is at the widest position but the needle will not move laterally for zigzag... The following logic should be applied for Bernina machines 530, 730, 830, 930 machines with a guided motion zigzag cam.
1. The switching pawl (lever on the top cover that switches from zigzag to cam patterns) may be engaged in the cam or automatic pattern side. Check that first.
For zigzag application, the lever must be engaged in the zigzag side (lever pulled back toward the operator). The stitch width dial is then used to provide your choice of width.
2. It is common, due to oil varnishes, that the switching pawl that is actuated by this lever is stuck between the zigzag and the automatic position, thus preventing the transmission of power to either the zigzag cam or the automatic pattern cams and to the needle.
The best way to detect this is to remove the top cover. You can then switch the lever back and forth to observe if the switching pawl engages firmly into either of the receiving forks. If the switching pawl is sticking, a few drops of certain solvents are applied by a technician on the switching pawl support. The switch lever can be rapidly switched back and forth until you see the switching pawl engage into the receiving forks and you hear a crisp clicking during each engagement. This repair can be permanent or it may create only a temporary fix due to the amount of oil varnishes on the parts.
If the machine is heavily varnished, it suggested that the parts be disassembled and cleaned for flawless performance. If the machine had been sprayed with WD-40, petroleum based solvents like mineral spirits will not break down these varnishes.
A caution regarding solvents...DO NOT USE (WD-40) as your solvent. WD-40 is a marvelous product for its intended application as a water displacement device. It is not to be used for lubricating a sewing machine. Note: "Bernina Technical Information bulletin #1" issued in 1982, forbade the use of such spray lubricants and solvents. SewTechnical Home
Sep 28, 2014 | Bernina Sewing Machines
Supply of new stitch cog for Bernina 830 Record
I don't know what a stitch cog is by your definition but I suspect that you may be referring to the cam stack worm gear, part # 310 007 03. These gears are available, however those produced and sold as after market parts online have ranged from bad to very bad. I would suggest that you find an OEM part (not a reproduction) that are still available from time to time on EBAY etc.
Changing the gear is not as straight forward as it may look. The proper replacement requires: 1. removal of the cam stack without damaging the machine parts, 2. removal and installation of the new gear with the correct alignment of the individual cams, 3. installation of the cam stack and pattern indicator without axial play, 4. correct parabola timing of the main-shaft worm wheel and cam stack gear, 5. synchronization of the zigzag and automatic cam parabolas, 6. pattern indicator timing, 7. checking and adjusting the automatic needle position. SewTechnical Home
Jun 14, 2014 | Bernina Sewing Machines
Can't do zigzag on 830
You need a repair shop - sounds like a part is worn out.
Jun 09, 2017 | Bernina Sewing Machines
Bernina 830
The 830 is a fantastic machine. It is completely mechanical internally for the stitch selections. A good cleaning and oiling should get you back on track.
Although it has not been used much, some of the original oil or grease can become sticky or pasty in time especially if it has not been used that much. Again a good cleaning and oiling should solve your problem.
Good luck, bushvideo
Sep 05, 2008 | Bernina Artista 180
Sewing Machines Logo
868 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
