Question about Kenmore Elite 45986 Front Load Washer
Won't start no error message just beeps three times
  • 15,935 Answers
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
I have a Fisher and Paykel Smartdrive 9 washing machine that won't fill. It starts then stops and continues to do so, then stops altogether and beeps. Can anyone help??
The error code is displayed when its beeping.
I don't know the error code, so It can only be three things,
Out of balance switch,Lid magnetic reed switch,Or Rotor position sensor,Your error code would help me work out witch one of these are faulty. to work out your error code look at picture below.
Add up the lights that are on.
Jan 08, 2013 | Fisher and Paykel Washing Machines
LTF2140ES0 washer just beeps three times, wont start
Frigidaire engineers are so smart they programmed it to beep 3 times for door lock problem, draining problem and other problems in the internal electronics and didn't bother to give the users specific info to read off the machine.
Oct 30, 2008 | Frigidaire 14 Cycle Tumble Action Washer
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
I have a Dell XPS 600 desktop computer. I cannot get the power to stay on. None of the diagnostic lights light up. I have checked all of the connections and everything is secure.
Here's what to try: Disconnect everything from the motherboard except the CPU and memory. You may leave the video connected to see what, if any, error message you might get.
You didn't say if you got any beeps on startup. They can tell you what might be the problem.
If this doesn't work, remove the memory modules. The power should stay on but you'll probably get either a steady beep or a bunch of little beeps. (I don't have the Dell error codes close at hand at the moment).
If this doesn't work, you have narrowed the problem to one of three things: The CPU, the motherboard, or the power supply.
You didn't mention just what happens when you turn it on--just that it won't stay on. Error messages are helpful if you get any on the screen as are any beep tones.
Jul 21, 2011 | Dell XPS™ 600 PC Desktop
Insignia camera turns on beeps three times and turns back off
Three beeps indicates a low battery or other warning. It also indicates error messages, such as memory full or card error. You should try replacing the batteries, erasing files from the memory, or verifying that your memory card is in the correct format and/or not defective. Additional details can be found in the owner's manual.
Jan 30, 2010 | Insignia NSDSC10A Digital Camera
Won\t boot up and dont have start up disks
please give more details about the problem, like error messages, color of ecreen, beeps, etc.!
Jan 04, 2010 | Toshiba Satellite Pro L300 Notebook
Acer travelmate 290 beeping, starts with blue screen and then black and beeping
See if there is an error beep. If there is an erro beep, then change
main board.
Power off. Then check if RAM CPU BIOS are well-connected.
Press Fn+F5 three times slowly
LCD FPC
LCD inverter
LCD
USB does not work correctly USB device cable is firmly connected into the USB ports. Test
Oct 29, 2009 | Acer TravelMate 290 Notebook
At start up, before windows loads, a consistent series of annoying beeping occurs....
If they're occurring right as you turn the computer on, it's your Power On Self Test (aka POST) letting you know. Since I can't be more specific, here's a synopsis of POST beeps:
One single beep followed by three, four, or five beeps -- System-board problems, possibly with DMA, CMOS setup chip, timer, or system bus. The computer usually won't boot when this is the problem.
Two beeps -- The POST numeric code is displayed on the monitor, usually nothing to be concerned about, but you might google the code on another computer and see what you get.
Two beeps followed be three, four, or five beeps -- First 64K of RAM has errors. Solution is to replace RAM.
Three beeps followed by three, four, or five beeps -- Keyboard controller failed or video controller failed. Either you won't be able to see or type with this error.
Four beeps followed by three, four, or five beeps -- Problem with serial or parallel ports, system timer, or time of day. Check your BIOS settings (usually F2 at start up) to make sure everything is correct.
Continuous beeps - problem with power supply. Probably won't do much with this error. At the very best, your computer will boot and run very, very slowly.
Hope that helped.
Sep 01, 2009 | Compaq Computers & Internet
Computer beeps when I try to start up
No Beeps
No Power, Loose Card, or Short.
1 Short Beep
Normal POST, computer is ok.
2 Short Beep
POST error, review screen for error code.
Continuous Beep
Repeating Short Beep
One Long and one Short Beep
Motherboard issue.
One Long and Two Short Beeps
Video (Mono/CGA Display Circuitry) issue.
One Long and Three Short Beeps.
Video (EGA) Display Circuitry.
Three Long Beeps
Keyboard / Keyboard card error.
One Beep, Blank or Incorrect Display
Video Display Circuitry.
Jan 05, 2009 | HP Computers & Internet
Kenmore Elite 45986 Front Load Washer Logo
119 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
