Memory Hello, what is the easiest way for me to find out if my computer uses 168 pin, or 184 pin memory? Thank you
  • 67 Answers
Go to Kingston.com and search your computer. Will tell you what type you need.
Posted on Feb 01, 2009
How many pins in the hyundai ddr 512mb?
SO- DIMM 512 MB 333 Mhz / 200 PIN PC2700 64Mx8
DDR SDRAM memory has 184 pins, where as SDRAM has 168 pins. DDR SDRAM Memory is a new type of SDRAM that is able to double the read / write speed of the previous generation of SDRAM memory. There are currently, PC2100 (DDR266), PC2700 (DDR333), PC3200 (DDR400), PC4200 (DDR533) These DIMMs are 184 Pin in size and are not interchangeable with older SDRAM modules.
Dec 29, 2010 | Dell Inspiron 1525 Notebook
Hi. I'm trying to get ahold of a manual for the pcchips m810dlu motherboard. I need to know what capacity of rams can be stored on the board; 2700, 3200, etc. Thank you
• 2 SDRAM DIMM Sockets
- Two 184-pin 2.5V DDR SDRAM (DDR200/266) or
- Two 168-pin DIMM Socket for SDRAM memory module
• Maximum: 1GB
Aug 07, 2010 | PC Chips M810DLU (M810DLUV75C) Motherboard
I am looking to upgrade memory on an MSI N1996 Mother Board which has 2x 168 pin slots and 2x 184 pin slots. I wish to know if I can go to 2GB and which memory is best to use, i.e. ECC,...
If your motherboard supports ECC, and you can afford the much-higher cost of ECC RAM, then buying/using ECC is "best".
Note that "buffered" memory is much slower than "unbuffered" memory.
Nov 05, 2009 | Intel Motherboard
Ddr ram sdr ram i am same time input that tw0 thats not show two ram capacities just show one ram'' asus p4s533 model please help me
Hi safran0785,
The Asus motherboard, P4S533-MX can run two different types of memory.
(Just not at the same time & in different slots).
You can use 2, 184-pin memory, PC2700/PC2100 MHz or PC1600 up to 2GB. (1GB DIMMs) inserted in the two memory slots closest to the CPU.
Or you can run SDR memory, 168-pin PC133 or PC100MHz DIMMs up to 1GB of memory in the last two slots farthest from the CPU.
You can not run both types of memory at the same time.
The 184-pin DDR PC2700MHz memory is much faster then SDR memory.
The maximum amount of system memory supported is 2GB.
Need more information/questions, just post here.
Good luck safran0785!
Mike
Mar 22, 2009 | ASUS P4S533-MX Motherboard
Compatible ddr memory for K7AMA Motherboard
2 DDR DIMM Sockets and 2 DIMM sockets support (can not be used simultaneously)
Two 184-pin 2.5V DDR SDRAM (DDR266/DDR200) or
Two 168-pin 3.3V SDRAM (PC133/PC100)
Maximum: 2GB
Jan 03, 2009 | EliteGroup K7AMA Motherboard
MS9317e+ manual
CPUs Embedded 3D Ultra AGP VGA Support Socket 478 for Intel(R) Pentium(R) 4 1.5GHz~2.53GHz or faster Processor
400/533 MHz FSB Chipset SIS 651 + 961 MS9317E+
SIS 651 + 962 MS9317E+(USB)
MuTIOL® Delivering 533MB/s Bandwidth Memory Supports two 184-pin DDR DIMM maximum size up to 2GB
Supports two 168-pin SDRAM DIMM maximum size up to 2GB
Support DIMMs of DDR333/DDR266/PC133 CPUs Embedded 3D Ultra AGP VGA Support Socket 478 for Intel(R) Pentium(R) 4 1.5GHz~2.53GHz or faster Processor
Support DIMMs of DDR333/DDR266/PC133manual for this board is no longer available but above is your mobo info
Nov 01, 2008 | Matsonic MS9317E Motherboard
Jetway MoBo: 2 x 1GB Samsung PC2100 appearing as just 1GB (2 X512MB)
Your post indicating that you are moving up from SDRAM to DDRAM shows that your motherboard is capable of either type (having both type of slots) and therefore would have been a few years old. Having said this, then your MB would have the very early version/compatibility of DDRAMs where/when 512 then was the highest readily available memory.
As most Taiwan manufacturers, Jetway would be publishing specs that are a bit just over rated in terms of their product performance unlike Asus, ABit, AOpen. Additionally, most have been known to be using the same manual for several versions of the motherboard. A similar looking motherboard can come in several versions such as those with internal video while another is an AGP slot; one versions may or may not have built-in Ethernet port. In the same token, a version may have 2 X SDRAM slots + 2 DDRAM slots or 4 X SDRAMs or 4 X DDRAMs. Again, we are talking of the same model number of the motherboard but different versions/revisions.
2 G would be right for the 4 X memory slots versions (at 4 X 512) but since you have the 2 + 2 (2 SDRAM + 2 DDRAM), maximum would only be 1 Gb (2 X 512).
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 03, 2008 | Jetway V266B Motherboard
2 x 1GB Samsung PC2100 appearing as just 1GB (2 X 512MB)
Hi Patrick,
I see you're point. I know this, you can not run "more than" 512MB in any DIMM slot. That is shown at the bottom of page 10 & the top of page 11. You can not run both types of memory at the same time, even though the chart looks like you could. The description term on page 10, states; Users only can install either 168-pin SDRAM Module or 184-pin DDR DRAM Module at one time. (You can't run both). You can run 4x512MB in all banks using184-pin DDR SDRAM. Or you can run 4x512MB in all banks of 168-pin SDRAMs. Total of 2GB.
So you can not run 1GB of memory in any bank.
Mike
Jun 29, 2008 | Jetway V266B Motherboard
Memory installation
Check your manual pg. 11 section 2.5. The 168-pin RAM go in the black slots ONLY. The 184-pin RAM goes in the blue slots only. Worth a check! Luck.
Please vote.....
Jan 18, 2008 | Asrock M266A Motherboard
Computers & Internet Logo
298 people viewed this question
David Payne
David Payne
