Hi im having a real problem with my washer, at first it would not drain, now it wont complete a cycle and i cant get the door to open help gem
    Problem Solver:
  • 16 Answers
Machine can t go on if water is not pumped out And as long as there is water innside you cant open the door(Built in safety)Check that pump is clean and runs.Regards jan.
Posted on Feb 13, 2009
Door will not close
Make sure you are allowing the washer to completely finish its cycle before opening the door. It is normal for the door to lock at the end of a cycle. The locking mechanism keeps owners from opening the door before all of the water has been drained. If the door on the washer is locked, select the "Drain" or "Spin" options on the front-load washer. This will completely drain the water from the system and unlock the door, allowing you to open it.
Thank you !!
Jul 09, 2010 | Frigidaire ATF6000ES Front Load Washer
Can't get the door open
Thank you !!
Jul 06, 2010 | Frigidaire ATF6000ES Front Load Washer
Door lock light is on door is not locked and
Thank you !!
Jun 19, 2010 | Frigidaire GLTF1040A Front Load Washer
Bosch washing machine does not do the complete cycle
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Jun 05, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Frigidaire affinity door will not lock when door is closed or register door is not closed when open
Apr 21, 2010 | Frigidaire ATF6700F Front Load Washer
Door wont open f21 alarm
F21 indicates that the washer is having problems draining. Check the drain hose to see if it is kinked or if there is an obstruction in the hose.
SUD comes on every time excessive suds are detected. Not using the proper detergent will set this off faithfully. The machine will run a cycle to remove the excessive suds before completing the wash cycle.
You need to clean the drain filter by removing the 3 screws in the bottom of the front panel. Then you will see a white twist cap. Remove the filter and clean it out.
Mar 09, 2010 | Kenmore Elite 45986 Front Load Washer
Cant drain and cant open the door
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
Jun 26, 2008 | Creda W100FW Front Load Washer
Hotpoint aquarius washer door wont open
I've got the same problem, the locked symbol is showing
Feb 17, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Door locked,wont spin or drain.
humming noise suggests a foreign object in the pump. crack open filter and drain water into a shallow tray. repeat till empty. remove filter completely and clean it. check if something stuck in pump impellor. this should be visible by looking into the filter hole
Jun 22, 2007 | Bosch WFMC 3200 Front Load Washer
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
