Question about Conair HCT-426 Hair Trimmer
HOW TO CHANGE BLADES ON CONAIR HCT 426 HAIR TRIMMER
LOST INSTRUCTIONS, NEED TO KNOW HOW TO CHANGE BLADES ON HAIR TRIMMER
  • Anonymous Mar 15, 2014
    Replacing blade instructions
  • Anonymous Mar 19, 2014
    how do you change the battery in a gmt 400 hair trimmer
Digram on how to replace my blade in my hair trimmer conair hc3180v
Posted on Jul 27, 2009
Two metal prongs that slide into tiny holes on the first blade, and the blade has a slot where the base dowel rotates causing the blade to move back and forth. the second fixed blade then is screwed onto the base.
Damian
Posted on Mar 31, 2009
Repalace blades for conair hct426
Posted on Feb 11, 2012
HOW TO CHANGE THE ELECTRIC CABLE?
suggested that you NOT try and fix yourself. Take to a repair center. If quite old then recycle
Jun 09, 2014 | Conair HCT-426 Hair Trimmer
Need replacement blades for hair trimmer
Hi. Order them from Conair: customer service representatives will be happy to help you. Please call 1-800-326-6247 for a Conair appliance.
Mar 23, 2010 | Conair HC117 Hair Trimmer
I just plugged the new trimmer and I heard a "tup" sound and after that it is not working. I suspect this is because of overload of current. How to get it repaired?? - Raj.
I am not sure if this will work but have you tryed changing the fuse
Or taking it apart and puting it back together just the parts that are removable
Mar 03, 2010 | Conair HCT-426 Hair Trimmer
Why does the head of the shaver get so warm/hot - so much so that people will tell me it is too hot to use?
The way a shaver cuts your hair is because there are smaller blades inside the head moving back and forth and causes friction...
Jan 17, 2010 | Conair HCT-426 Hair Trimmer
How do I change my blades?
unscrew the blades and replace with new ones, alternatively oil the blades that are already on the clipper each time it is used. You will be surprised at the amount of hair clogged up on the inner blade when you take them off
Aug 05, 2009 | Conair HCT-426 Hair Trimmer
I had a one hook up on it and the whole blade popped off how do i put it back on
place the short blade on the bottom over the oblong piece then place the larger blade on top and screw back together, if there is a piece of foam inside make sure that is under both the blades and around the oblong piece (refered to earlier) which is sticking out of the top of the unit
Jul 28, 2009 | Conair HCT-426 Hair Trimmer
I bought a 19 piece and i can't cut my hair
It soulds like the blades are too far back. There is an adjustmebt piece to the right or left of the blade that is about 1 1/2-2" long and it slides forward and backwards.
Ths will adjust the blade depth. It sounds like the blades may be set too far back to cut your hair, this has to bring the 2 blades together so you have much less free edge on one side, so what you do is slide ths blade by adjusting the handle and bring the blades to just where one side is slightly shorter than the other less than 1 cm. Then make sure the guard is off and slde the adjustment head is set and then try it agan. Unusually it is the problem if it does not cut or the blades have come loose. Hope that helps.
Apr 05, 2009 | Conair HCT-426 Hair Trimmer
Conair HCT-426 Hair Trimmer Logo
4,697 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
 Mikey
Mikey
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
