Question about Mitsubishi WD-52525 52" Rear Projection HDTV
No picture tv shuts off ,when turn back on there is no picture only sound.
  • 11,896 Answers
Could be a couple things:
The lamp is blown out,
capacitors on ballast or hyperboard, may be shot
or the door to the light bulb isn't close all the way.
do you get any flashing lights?
Posted on Feb 01, 2009
  • Nate Stansfield
    Nate Stansfield Feb 01, 2009
    If I were looking at it I would first suspect the flyback system. The
    HV is often the first to go, and especially so if the audio is still
    working as it should.
    You can listen when the set is has been off for several hours; then
    turn it on and listen for high voltage crackle or sizzle. If you donot
    hear any you can assume the high voltage is not coming up. If you DO
    hear the sizzle it means the high voltage is coming up; but if there is
    still no video you can assume it is in the picture tube drivers or the
    video processing areas.
    I don't recommend you try to fix it by yourself unless you are handy, inquisitive, brave and lucky in finding the problem!
My tv won't work after I shut it off using the remote throught the cable box
You need to turn on the cable box again. Make sure to select the right source again for your tv.
Jan 11, 2014 | Seiki 32" LED HDTV SE322FS - CAM CONSUMER...
Samsung ln46c530 lost picture, now won't turn on. Indicator light turns on solid red when on, flashes five times when shut off
The fault is with its main board itself. Troubleshooting to this board is not an easy work to a user can do. It will be best to contact any service technician. google.com/+GopakumarGopalan
Nov 24, 2013 | Samsung LN46C530 TV
TAKES 45 MINUTES TO COME ON
Evidently there is an internal power supply problem.
Nov 12, 2013 | Televison & Video
73" Mitsubishi DLP. turned on the tv and got only sound, no picture. after a minute it would shut down and red light would pop on the front. replaced bulb and hooked it back up. now it turns on but af
Try cleaning the little fans that keep the bulb cool, the temp sensor will shut it off so not to damage the bulb , the winning sound may be the fan going bad or not working like it should.
Mar 07, 2013 | Televison & Video
42'' lcd turns on no picture/menu
Your tv is being attacked by electrical surges which seem very violent and has already damaged some logic controls. Please invest in a AC filter which will protect your tv from such spikes....... but first you need to get your tv serviced from the electrical damaged it has already suffered.
Nov 02, 2009 | Philips Televison & Video
My tv is working with sound and was fine. I shut
Your picture is missing- after 5 days call 911
Mar 18, 2009 | Panasonic CT-36HL43 36" TV
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Mits 62525
take the lamp back out and reset the lamp
Dec 27, 2007 | Mitsubishi WD-62525 62" Rear Projection...
SAMSUNG PICTURE FREEZE (LOOKS BLACK&WHITE)
I have the same problem... It turns B&W
I can still hear the sound... however I can still turn the tv off when that happens
Aug 28, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
50 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
