Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
Am i able to still connect
I own a wireless NETGEAR(WPN824) router and i've lost the cd. i wanted to know if it is possible to connect something like a PSP wirelessly without the cd. i am able to give it the internet but the internet on my computer gets knocked off line. is there any way where i can get both systems to stay online?
No cd required - search on the internet for connection instructions
Posted on Apr 20, 2009
Lost netgear cd for installation. can i set up by cell phone using smart wizzard?
No, you need to connect via Ethernet cable to set up the router.
The router manual is here
http://kbserver.netgear.com/pdf/wpn824_ref_manual.pdf
so you can set it up manually
Jan 07, 2014 | NetGear RangeMax WPN824 Wireless Router...
My Netgear WPN824 wireless router stopped working. With the exception of the internet LED (which doesn't come on at all), all of the lights are blue and doing sort of a slow, pulsating blink. No m
The RESET button is for resetting the wireless section of the router and does not effect the Internet connection.
It looks like the wireless access is faulty especially when you cannot reset and configure the wireless settings.
Try powering off the Netgear for 10 mins the connect the power again.
If you still cannot RESET the Netgear then it is faulty and you need a new wireless router.
Mar 07, 2013 | NetGear RangeMax WPN824 Wireless Router...
I have a netgear wireless router wpn824 and in moving lost the software to be able to connect to another home computer (was on cable at other location) can you purchase just the software
There is a MANUEL way to get the router working. Find somebody that would know the login IP Address of the router (could be 192.168.1.1) and then you can set it up from within your Internet browser. Quite a tricky router to set up though but it can be done
Jul 06, 2009 | NetGear RangeMax WPN824 Wireless Router...
Netgear Wireless Router won't work with my Linksys wired router.
As asked above, why would you want the wired router and the wireless router on the same network?
The direct answer to your question(s) is found on Netgear's website. http://kb.netgear.com/app/answers/detail/a_id/965/kw/wpn824/r_id/166
The key is to turn off the Netgear DHCP, and give it an address that is unreachable by the Linksys DHCP ie if the Linksys gives out IP addresses starting at 100 or 101, you set your IP address to 99, turn off the DHCP, and plug it into the network NOT using the WAN port, ever. We tend to start at 251 or 221 just for clarity's sake.
The point is you answered your own question. The Netgear wired and wireless works fine. One piece of equipment and better reporting statistics....what are you missing?
Carl
Apr 25, 2009 | NetGear RangeMax WPN824 Wireless Router...
Lost setup DC
The router is compatible with any operating system. You don't need to use the CD that came with it to setup the internet connection. Just open the router's setup page by typing http://192.168.2.1 on your browser. There you can see the automatic setup.
Apr 02, 2009 | NetGear RangeMax WPN824 Router
Connect netgear wpn824 to DSL router using usb connection between DSL router and wireless router
call your ISP. Change the DSL modem from USB connect to ethernet connect. There is no possible way two match the two device
Dec 25, 2008 | NetGear RangeMax WPN824 Wireless Router...
How to add a laptop to netgear wpn824 router
access the router page and you will see the wireless settings. if your wireless network is password protected then you may have to enter the password in order for the wireless router to connect.
Oct 05, 2008 | NetGear RangeMax WPN824 Wireless Router...
Netgear rangemax wpn824
attach pc to router using the lan ethernet cable, switch on router, restart pc, then type 192.168.0.1 into your web browser, select admin as the admin and password as the password and then you should be in the routers menu.
Sep 02, 2008 | NetGear RangeMax WPN824 Wireless Router...
Lost all internet connections through NetGear Router
I'm thinking MAC accept/reject list, check to see if it's active or not.
Aug 26, 2008 | NetGear RangeMax WPN824 Wireless Router...
Netgear wireless wpn824
Sounds link you need to setup PPPoE on your router. Not knowing who your ISP is, Netgear has this website that lists a lot of ISPs support on setting PPPoE up. that is located here: Netgear
If you can't find the info there, basically what you need to do is on your router, typically the main page, you might see an area that lists: DHCP, Static, PPPoE (or something similar). What you need to do, is select the PPPoE option and put your ISP login information (that is on your DSL modem now) there should be a connect or login button once your finished. Once that is done, your router does the logging in, instead of the modem.
Feb 03, 2008 | NetGear RangeMax WPN824 Wireless Router...
NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
154 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
