Question about Star Logic 17" LCD Monitor
Starlogic 20 inch widescreen monitor screen keeps going black
When I turn my monitor on, it will stay on for a moment, and then go black. I can turn my screen off, it will come back on, and then go black again HELP
  • 558 Answers
Bad capacitors you will need to replace the "blown caps" and resolder new ones in.
Posted on Mar 21, 2009
I install window 7 but my benq 15" lcd monitar's screen rosuation not competible. pls guide me how i increase the rosulation thnx
As for your 15" LCD BENQ Monitor, "1024 x 768" pixels is the Maximum Resolution
If you increase your screen higher than the Maximum resolution you get a black screen! because the monitor cannot support the resolution higher than "1024x768" pixels.
How to change your screen resolution Win 7-> Link
FYI
Here are typical resolutions for some popular screen sizes
19-inch screen (standard ratio): 1280 x 1024 pixels
20-inch screen (standard ratio): 1600 x 1200 pixels
22-inch screen (widescreen): 1680 x 1050 pixels
24-inch screen (widescreen): 1900 x 1200 pixels
Hope it helps.
Nov 22, 2010 | Computers & Internet
Acer Monitor Not Staying On
It sounds like there's a problem with the monitor itself. It may be that the lamp in the computer is dying, which would explain why it keeps going out. Other possibility is that the monitor isn't receiving power properly either through the cable or inside the monitor itself.
If your're not the kind of person who wouldn't mind opening the monitor up and hopping in there, then I recommend you take it somewhere it can be diagnosed like Best Buy.
Hope I helped :)
Nov 28, 2009 | Acer X223WB 22" WIDESCREEN LCD Monitor
Monitor will not stay on
I am having the same issue. Stays on for 2 seconds then goes black. If I find a solution I'll let you know.
Apr 07, 2009 | Westinghouse 19" Widescreen Flat Panel LCD...
This is probably a back light problem. Take a bright flashlight and while the monitor is on, point it at the LCD and try different angles, etc. If you can see an image, it is the back light, probably the back light voltage converter unit in the lcd. It could also be the back light bulbs.
If you don't see an image with the flash light, then it could be the main logic board.
ort11
Mar 08, 2009 | Computers & Internet
Black flickering line vertickally through monitor screen
It could be either of these:
You're monitor is dying and you need a replacement (Starlogic brand is notorious for dying early and giving poor performance)
You're graphics card is going out. If you have an extra monitor laying around, take out the Starlogic one and plug in the other to see if the same results occur, if not, it's the Starlogic monitor, if the problem still persists, you need a new graphics card or need to update your current drivers.
Dec 15, 2008 | Star Logic (11004998) (Black) 15 inch LCD...
17'' monitor whte screen power light on
have a 17'' starlogic flatscreen monitor and i opened a game and it went to white screen and stayed there.
Jun 19, 2008 | Star Logic 17" LCD Monitor
Starlogic LCD Computer Monitor
I can't find a website for StarLogic anywhere, so either they have gone out of business (not likely as there should be some reference to them somewhere) or they are imported from a foreign manufacturer and rebranded with the StarLogic name.
May 13, 2008 | Star Logic 17" LCD Monitor
17 in Widescreen Mag Innovision
Dear tfollis
Have you checked the HZ that you are using the monitor in windows ? If set at a very high level (for example 100hz) it may damage the monitor as it is not supporting it. (and maybe this explains the reason for the shutoff as a means to protect the circuitry)
17 inch TFT/LCD Widescreens monitors are ussualy optimal at 1280x800@60Hz.
Right click on Desktop-->Properties-->Settings-->Advanced-->Monitor--> At this point check the Monitor Refresh Frequency.
Check this first and if this does not solve it then we can proceed to more serious hardware troubleshooting.
Regards
EngineerGR
Apr 30, 2008 | Mag Innovision LT776s 17" LCD Monitor
Star Logic 17" LCD Monitor Logo
333 people viewed this question
Top Star Logic Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
Jerry Umali
ray gallant
Are you a Star Logic Computer and Internet Expert? Answer questions, earn points and help others
