Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
Getting an e4 5403900 error
I have a philips digital disc recorder with digital tuner: model DVDR3506/37. I have had about 9 or 10 months. I have had error problems such as: This progran is not allowed to be recorded or This program is not recordable in +VR mode and a few times E4 5403900--Can not record on this disc. I have tried Memorix, maxwell, fuji and imination. So I went to the manual and brought a brand the manual said was compatible with this recorder. It was sony +rw 4x. When I put the blank disk in the recorder it loaded it and began to format it then I go the error e4 5403900. Please can you help me?????????
SOURCE: dvd/vcr recorder/magnavox
I'm on my second Magnavox MWR20V6 recorder in less than a year. I've made close to 1,000 DVDs, mostly dubbing from homemade videos of TV shows, but it's not been easy. They have some finicky quirks that aren't mentioned in the manual.
The second Magnavox I got worked far better than the first, and really has been pretty satisfactory. The first one (which finally just died) never had decent tracking, even when I was copying a video tape I'd made on the same machine to DVD!
I got the error e4 54043e02 on both machines. I'd be using the exact same brand and type of DVD that I'd used for hundreds of other times, but I'd get a new spindle of DVDs and few or none of them could be formatted, and were unusable.
I think the problem might be with the DVDs. I have tried all the brands I could find. I first tried Maxell, as recommended in the manual. They worked fine (both -RW and +RW) until one day they just quit working for me. The worst were the ones that had CPRM printed on the DVDs around the inner hub, but I couldn't find any way to tell (before buying them and opening the package) which disks were this type because the label on the package was identical to the Maxell DVDs that worked. I contacted the company and sent them all the DVD numbers and error codes but they didn't tell me anything. It seems to be some kind of company secret.
Then I tried Memorex DVD+RW 4x and they worked very reliably-- until the last pack I got. I'm getting the e4 54043e02 error again!!! I emailed the company but haven't heard back yet, due to the holiday weekend.
So my big complaint is that I can't find ANY DVDs to use for recording. What I've seen so far on the internet gives me the idea that blank DVDs are kinda junky or unreliable in general, also that it's a VERY good idea to keep those old video tapes, which might end up lasting far longer that DVDs anyway. I'd hoped to get rid of the old VHS tapes due to the storage space needed for them, but it looks like I won't be. Unless I can find good DVDs, I'll just go back to VHS recording.
Incidentally, Memorex gives me the impression that they'll refund my purchase price, while Maxell had no interest in making a refund!!
Also I think the DVD-R give fewer problems, but I use +RW for nearly all my recording because I like to edit them. I'd suggest trying a DVD-R if you get desperate.
Posted on Jan 01, 2008
SOURCE: Error message: Can not record on this disk???
In many devices, DVD-R and/or DVD-RW discs do not work. You must use DVD+R or DVD+RW discs. Good luck!
Posted on Jun 05, 2008
SOURCE: Philips Magnavox MWR10D6 DVD Recorder Cannot record in +VR mode
check to see if the U-verse box is in HD mode. If it is, change it to standard definition and the problem should be solved.
Menu -> Options -> System Settings -> Aspect Ratio
Posted on Sep 29, 2008
SOURCE: Magnavox ZV450MW8A can't record
Just set the channel to a non-premium channel (ABC, CBS, PBS, etc.) before starting the dubbing process.
Posted on Jul 04, 2009
SOURCE: E-4 54040990 Cannot record on this disc
I had this problem with my Toshiba DVR16 recorder; I was unable to format new DVD-RW discs even though old ones worked fine.
Initially I thought the laser lens was dirty, but no amount of lens cleaning helped. Then I thought the rated disk speed must be to blame, since it was some 4x disks that first presented the problem. But then I tried 2x disks and the problem persisted. So some aspect of the manufacture of these disks must have changed in recent months.
Anyway, the solution I discovered was to perform an 'erase' operation on each disk using a program on my PC called ImgBurn. This is a free program, which can be downloaded from imgburn.com. Just select Tools > Drive > Erase > Quick. Once that's done (it only takes seconds), take the disk out of your PC and pop it in your DVD writer, whereupon it should start its own format routine.
This has worked for me on 3 different brands of disk (Sony, Memorex, Datawrite). Which is just as well, as I was on the verge of throwing the DVD recorder out of the window. Hope it works for you.
<Neil G.>
Posted on Oct 06, 2009
WILL RCA DVD/RECORDER, RECORD MOVIES FROM TV TO DVD DISC
It depends on the model and the source. The DRC212N is not a recorder, so it won't.
Depending on the model, it may or may not have a tuner. (Most modern ones are sold without any tuner. Older models may only have an analog (NTSC) tuner.) I know of one Magnovox DVR/DVD recorder that has an ATSC (digital) tuner.
If you are going to record OTA signals, you will probably need a digital to analog converter. If you are recording from a cable or satellite system set-top box, you need to set the channel on the box and then record on Line In. (Analog cable should record directly.)
Please add a comment with more information about your DVD recorder. I'll be glad to provide more assistance. I hope this helps.
Feb 03, 2013 | RCA DRC212N DVD Player
Will not record and also keep geting error nodisk
Did you try a disc cleaner? Maybe the lens is just dirty.
Jan 03, 2008 | Televison & Video
It will not record. it is programed.
Is it the dvd or the vcr mode that will not record? What source are you recording from - ie are you trying to record a channel that the tuner can read or is it coming from a set top box? Is the clock properly set for timed recording? This unit only has an NTSC (analog) tuner. If you are recording OTA from a converter box, make sure the correct channel/input is selected for the unit to see the content from the converter box.
If it's the dvd, make sure that there is sufficient space on the disc. Also check that the disc is not finalized and is compatible. Try a different brand. Is the machine recognizing discs properly? If it isn't reading any disc, then the tracking might be off or the laser needs cleaning. Try a cleaning disc but the unit may need service. DRM issues may apply for content from a set top box and block the recording to DVD.
If it is the VCR, then make sure that the tape has sufficient space left and that the write protect tab has not been removed from the cassette. (If it has and you do want to overwrite it, put tape over the opening.)
For timed recordings, make sure you turned off the unit after programming the schedule. You disrupt the timer when the unit is on. Power failures will also clear the programming if they last more than 30 seconds.
The unit was manufactured by Funai for Philips. You can get the manual here: http://www.funai-corp.com/support/manuals.aspx . Search for the model number to get the PDF.
I hope these ideas help.
Jan 18, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Need to know if I can record from dvd to vcr on a magnavox ZV420MWB vcr/dvd combo
Magnavox ZV420MWB VCR/DVD Combo
The answer is YES YOU CAN! Take advantage of one-touch recording from videotapes to DVD+/-R and RW discs or from DVDs to VHS tapes. A variety of different inputs also let you record from compatible camcorders, external TV tuners or cable boxes.
CONSUMER ALERT: This model does not have a built-in tuner for recording TV programs and will not record copy-protected tapes or discs. For more information, call the Federal Communications Commission at 1-888-225-5322 (TTY: 1-888-835-5322) or visit the Commission's digital television website at: www.dtv.gov.
Feb 15, 2010 | Philips Magnavox DVD/VCR Dual Player
How may i hook the phillips dvdr3455h/37 to record from my fm tuner,i have it hooked up as follows audio out on philips to tape in on amp and audio in on phillips to tape out on amp,but when i press any of...
The dvd recorder uses the video signal to detect, thus it will not detect the audio as a signal. I believe there are "boxes" you link in somehow to "fool" the dvd into thinking it's recieving a video signal, but I don't know where to get them.
Jun 14, 2009 | Philips DVDR3455/37 DVD Recorder/HDD...
Get an error when i try to record
The strange thing about the Philips DVD players is that -R and -RW discs automatically record in +VR Mode. If the current discs you are using are -R/-RW's, then switch to +R/+RW, but usually you have to do the opposite - you are probably recording on +R discs - just switch to -R or -RW discs. All the Philips recorders do this to one extent or another. Good luck!
-Tha Mp3 Doctor
Jan 10, 2009 | Philips DVDR3545V/37
I have 10 year old tv Phillips model ts3258c101.Yesterday I purchased a digital video disk player & video cassette recorder. It will play a dvd. I now have found that I cannot record a video cassette...
Check if your disc player is a twin tuner model which will allow you to do what you want. It might just need configuring properly. Otherwise there are devices on sale that will allow you to achieve your goal. Good luck.
Sep 26, 2008 | Philips Televison & Video
External Tuner Device for VCR/DVD player
Just pick up an old used VCR that has a tuner built in. Only the very new ones don't have them (due to the DTV switch coming up in February).
Sep 09, 2008 | Philips Televison & Video
Dvd recorder problem - model CMWR10D6
Might be the PCA aka power calibration area portion of the lens that reads that might not be reading it. Here is a little bit more info on PCA.  Power Calibration Area of a recordable or rewritable disc that precedes lead-in and the PMA, where the optimum laser power level for writing can be determined by a recording drive
Nov 07, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
172 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
