Question about Epson H6000II Thermal Printer
Epson TM-200 w/ cut can't lock the cash drawer automatically. Can only lock the drawer with key
2 Suggested Answers
SOURCE: Cash Drawer Command
The cashdrawer is SERIAL, you'll need to connect it to a COM port. The
software you're using has to be capable of sending data to the COM port
the cashdrawer is connected to when the cashdrawer needs to be opened.
From the site you mentioned:
Be sure drawer lock is not engaged.
Exit your system to a DOS prompt. Type the following commands (substitute
the correct com port for com1):
c:\>mode com1:300,n,8,1
c:\>echo "000000000000000000000">com1
The cash drawer should open.
About the cashdrawer RJ11 connection on the printer: You can connect any
solenoid driven cashdrawer to this port. The port uses pin 2 and 4 for
the voltage output, which is normally 24V on Epson receipt printers.
Sending a specific ESC character (every POS software should be capable of
doing this) to the printer will be recognized by the printer and the
printer puts 24V on the 2 pins mentioned for 300ms and voila, the drawer
opens.
Posted on Jul 31, 2008
Cant get cash drawer to open with epson tm t88iv
If you just need to get in the drawer until you can figure out why the button is not working there is a small tab on the bottom of the register. push it and it will release the drawer manually.
Oct 04, 2012 | Apg Cash Drawer VB320-BL1616-B10 - Apg,...
I have reinstalled an Epson TM-T88II in a POS system that does not have a parallel connector. There is a D-Link fast ethernet print server model DP-301P+ connected to the parallel port of the printer. An...
The cash drawer is loking for a signal from the printer to fire the drawer. It is usually on one of the pins of the cable comming from the printer. You will probably have to contact the cash drawer manufacture for that information.
You can contact Southeast Digital Networks, Inc. for more info.
Tel 850-681-9528
Hours of operation Mon - Fri 8:00am - 5:00pm EST
Mar 06, 2011 | Epson TM-T88III (C420863)
I have an epson tm t81 usb receipt printer and want to connect a cash drawer with the printer for my windows application in vb.net. The cash drawer wont open after the kick there may be some problem with...
Hi!
Are you using the Epson TM-T90 driver? When you go to printer settings through Printers and Faxes there is an option to Open Drawer after or at the Beginning of the transaction.
One other way to check if you have the correct commands for it is by checking on printers Manual and Technical documents of it where you can get online. Click HERE. Register and wait for an Email for Username and password.
Hope this helps.
Jan 05, 2011 | Epson TM T90 Printer
I can't get my cash drawer to work is there a secret. I have enabled the cash drawer in digital dining but it won't open
You must be sure the voltage to the cash drawer and the printer are correct. A 24 volt RJ12 printre connection to the solenoid of a 12 volt cash drawer will cause damage. If the drawer was working and stopped, it is possible the solenoid may be the problem.
May 21, 2010 | Epson TM-T88III Thermal Printer
How to open cash drawer epson tm-t88ii printer
You need to have the correct cable to connect your cash drawer to that printer. What model of cash drawer do you have?
Apr 20, 2010 | Epson TM-T88III (C420863)
I have a epson tm t8iiip printer when trying to
Store OPs require OPOS software be installed and the printer and drawer setup within it.
Jan 23, 2010 | Epson TM-T88III (C420863)
How do I get the cash drawer to pop using the Epson TM-T88III and windows driver? I am currently using RMS as our point of sale system but do not want to use OPOS drivers as this printer and cash drawer is...
You can set this up under printer settings - Under Windows XP - At the control panel, click printers, right click the tm-t88iii printer and select properties. Click the 'Device Settings' tab and there *should* be a option to open the cash drawer after printing.
Nov 06, 2009 | Epson TM-T88III (C420863)
Cash Drawer Command
opens.
Jul 12, 2008 | Epson TM-U220 Matrix Printer
Cash drawer
Greetings,
From the computer (application to be exact), you send a signal to the printer to kick the drawer open but is there a confirmation signal from the printer going back to the computer that it successfully opened the drawer (not just successfully carried-out the command) ?
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
May 06, 2008 | Epson TM-T88III Thermal Printer
How to eject cash drawer pos
Open the Cash Drawer
Hex code
<1B><70><30><40><50>
Apr 03, 2008 | Epson TM-U220 Matrix Printer
Epson H6000II Thermal Printer Logo
772 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
