Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
The cooling fan wines. How big a job is it to replace?
It looks like a 3 in. box fan. Does the back cover come off and allow access to the fan?
Thank You
Steve
  • 2 more comments
  • goldensatell Feb 06, 2009
    The fan makes a lot of noise, it makes your ears ring after a short time. The tv is great other than the sound of the fan. I would like to replace the fan, but our local repair shop can't give me a price they want me authorize them to spend up to $600.00. At that price I'll just go buy a new TV.
  • petermsong Feb 26, 2009
    Same problem I have.
    This noise stay all the time... How much does it cost to replace or repair?
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Let me know exact model number of TV.
    Sony TV has 4 fans inside, can you point out what fan is making noise?
    May I know what you want to do and what is actual problem in TV?
    Problem Solver:
  • 8 Answers
It's probably not actually the fan it may be the color wheel.
Posted on Jul 14, 2009
How do I replace the exhaust fan on a KDS-R60XBR1
Posted on Feb 13, 2009
The fans in my cooler stopped working. how can I fix, or replace them ? I have an DCW283BLS Model
There are 3 fans in this unit. One high up in the back panel for defrost (which should seldom run), and two inside the box with the LED's that divide the compartment into upper and lower areas. All are interchangeable. Replacement parts are available through Sears Parts Direct.
If you intend to do the repairs yourself, make sure the cooler is unplugged when working on it. To gain access to the two fans in the divider box, remove the wine racks to give you more room, and just remove the four screws holding the top of the divider box on and lift it off. One of the fans is directly behind the PC board and the other is inside the 8x10 foam box to the rear of it. Be careful with this foam box, it is delicate. To gain access to the fan inside, use a thin bladed knife or razor blade to delicately separate the top from the sides.
Before replacing fans, try tracing the leads from the fans to the PC board and swapping the plugs for the fans on the PC board and plugging the cooler back in to see if any of the fans are working. Make sure you restore the plugs to their original positions. If all three fans are not working, the problem may be the PC board or the thermocouples.
Mar 15, 2014 | Danby DWC283BLS Wine Cooler
Wine fridge is always running but never cools below room temperature.
the processor cooling fans for the CPU and case fans are 3 PINS.. you can use them but remember that these are 12V fans. once its the same power it will work. Ps if needed you can cut the connects from your old fan and connect it to the new ones to get it to fit properly..
Dec 30, 2012 | Haier HVTS18DBVS 18 Bottle Dual Zone Wine...
Kenmore wine cooler 13485 spill wine in the top not cooling
if suction line is warm and pressure line hot . sounds like comp is trying to do its job / ck the fans and they may be slow or not going . spilling of the wine did not cause problem . .. but now is the time to correct the problem .. mm / ps if unit is running like you state the you might look at the ref charge . as it may be low . mm . hope this hs helped . feed back pls .. mm
Jul 22, 2010 | Kenmore 13485 Wine Cooler
NOT COOLING (Franklin FWC35)
Sound like maybe the Compressor may have packed it in. Sometimes they overheat and that is what melts the plastic liner of the refridgerator. You need to call a service repair person or simply take the small frideg to them at the repair center. Most manufactureres have a repair cneter locator. Go to their web site and find the autorized repair center near you. If it is still under warranty you will in most cases need to find the receipt. ( TIP I put a copy of the receipt on the back in a ziplock bag on all appliances) This makes it easier to find them when things go wrong.
Cheers
Allen
Sep 11, 2009 | Franklin Industries FWC35 Compact Wine...
Wine cooler makes noise and runs hot
The price looks fine for my area its about a 3 hour job done properly. you should consider a new wine cooler and cut your losses because if their only replacing the compressor they should be replacing the cap tube and liquid drier if the cap tube is not replaced could be a waste of money
Tom
Jun 17, 2009 | Danby DWC283BLS Wine Cooler
Vinotemp VT-16TEDS has light on but doesn't cool
First check the grating over the fan in the back. If it is covered with dust, there won't be enough air flow and the unit won't cool. Clean the dust off and see if it cools back down. It may take a long time to cool down if it is full of wine, so I recommend taking the wine out to test if it works.
Jan 17, 2009 | VinoTemp VT24-G 24 Bottle Wine Cooler
Wine Cooler Temperture Regulation
Replace the circuit board . Please Rate This !!!! Thank You!!
Jun 08, 2008 | Haier HVF042 Wine Cooler
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
327 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
