Question about Frigidaire GLEQ2152ES Electric Dryer
Scraping sounds and electrical sparks inside my dryer.
I purchased a Frigidaire GLEQ2152es Electric dryerfour months ago. Today while using it, I can hear a scraping sound from within. I looked through the glass door and noticed sparks inside as the dryer tumbled. Can you help me with a solution?
TheMobilian
  • 8205 Answers
SOURCE: Wire Scraping sound and sparks inside rear dryer drum area.
Probably the rear bearing has failed and caused the drum to rub against the heating element. Hey, is this the guy that said he heard a noise last month? LOL
Posted on Feb 04, 2009
Drum sparking
Hi Keith, I am happy to assist you!
From what you have described it sounds like the heater on your Frigidaire dryer may possibly be loose. Regrettably, this is not a simple DIY job. I would strongly recommend connecting with a professional to proceed further.
Dec 14, 2013 | Frigidaire GLEQ2152ES Electric Dryer
I have a frigidaire gleq2152es1 that keeps blowing heating elements, what is the cause?
Are you re-stringing the element? if so you need to make sure you have no gaps in the element.
Jan 02, 2013 | Frigidaire GLEQ2152ES Electric Dryer
My dryer is ten years old. A few months ago, some of the clothes would come out with rust stains on them. Some of the clothes would get caught in the seams which would cause staining, tearing and...
I would suggest replacing the front drum bearing. Sounds like the gap is now excessive, obviously allowing clothes to get caught up in there. Drum must be removed from the dryer to do this.
Good luck, hope this helps.
Aug 19, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Overheating?
The glow is normal, but the sparking may indicate lint back in the heater element compartment, you can check your owners manual for trouble shooting tips.
Apr 22, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Drum makes scraping and bumping sound with out
the roller of the belt tensioner has a bad bearing which will cause the roller to burn up riding on the belt giving it a flat spot creating your horrifing noise
Feb 14, 2010 | Frigidaire GLEQ2152ES Electric Dryer
LEQ2152ES 2005 dryer shuts off when start us pushed
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 14, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Feb 01, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire electric dryer....
venting porbelm. do you have the vent going outside of the house or it is just indoor???
make sure there is nothing in the vent pipe.
Oct 16, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire GLEQ2152ES Electric will not turn on
Check the terminal block where the cord attaches to the dryer. Sometimes a bad connecion can cause the terminal block and/ or cord to burn up.
Jul 21, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
333 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Electrolux
Electrolux
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
