Question about Bissell 6594 PowerForce Bagless Upright Vacuum
Bissell won't turn on
Bissell vacuum suddenly won't turn on as if their is no power getting to the motor. Tried several different outlets, but no luck. Thanks for any suggestions you can provide.
  • Anonymous Apr 26, 2009
    Bought this thin in Dec...I have the same problem over and over...having a party and the thing won't turn on...I hate this vacuum!
  • 76 Answers
The motor could be ceased up. do you hear a buzzing noise? if you dont hear a buzzing noise, turn it on for about 1 minute, unless it starts smelling hot or starts smoking. if nothing happens after that, try replacing the power cord.
Posted on Apr 19, 2009
When I turn it on the fuse box for the house keeps blowing
Have you tried a different area of the house? I would call an electrician and have your outlets checked.
Apr 06, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
Brush roller not spinning. belt, spindle okay. roller taken out and cleaned, no thread. replaced but no dice. ???
Use only BISSELL Style 10 Replacement Belts (#32074) in your BISSELL PowerForce Bagless.
  1. Unplug cleaner from electrical outlet.
  2. With Rotating Floor Brush removed from vacuum cleaner, grasp old Drive Belt and remove from Motor Pulley. Discard old Drive Belt.
  3. Place new Drive Belt over Motor Pulley and stretch other end over Rotating Floor Brush in the space between the bristles.
  4. Place ends of Rotating Floor Brush down into slots on sides as shown.
  5. Turn Rotating Floor Brush by hand several times in the direction of Motor Pulley. If properly installed, Drive Belt will center itself on Rotating Brush.
  6. Reposition Brush Cover and snap back into place. Check to be sure all three latches are secured.
  7. When you turn on the vacuum, do you see the motor that spins the belt spinning at the bottom? If not, it sounds like you may have a burned out motor.
If suggested solutions do not correct the problem, call:
BISSELL Consumer Services 1-800-237-7691
Monday - Friday 8 a.m. - 10 p.m. ET
Saturday 9 a.m. - 8 p.m. ET
Jun 01, 2011 | Bissell 6594 PowerForce Bagless Upright...
I was given a model 6591, plugged it in and it worked but didnt "****" and didnt sound right. I turned it off and removed the hose from the back found a badly plugged hose. Removed the hair...
The User Guide for the bissell Clearview Power Trak
http://canada.bissell.com/images/UserGuides/3590C.pdf
May not be your exact model but should be similar.
The Bissel vacuums include an internal thermal protector to protect it from overheating. When the thermal protector activates, the cleaner will stop running. Should this happen proceed as follows:
1. Turn the cleaner OFF and unplug from electrical outlet.
2. Check the Pre-Motor Filter and Post-Motor Filter for dirt accumulation.
3. Remove any clogs.
4. When the vacuum is unplugged and motor cools for approximately 30 minutes, the thermal protector should automatically resets and cleaning may continue.
5. If the thermal protector continues to activate after following the above steps, your cleaner may need servicing. Call Bissell Customer Service:
http://canada.bissell.com/Contact_Us.aspx
Mar 20, 2011 | Bissell 6591 Power Trak Revolution Bagless...
Bissell Powerf DJ68-00161C Upright Bag Vacuum will not power on. I did rinse out the bag compartment but it should be dry now. I use the Style 7 bag & belt. This is the first time it will not power on.
Hmm, you really should not ever rinse out your vacuum unless you have a model that specifically states it is called for. If you must, then use only a slightly damp sponge or cloth. There are so many ways water can have ruined your motor. Let the whole thing sit for several days (drying parts inside) and then plug it in and try to start it. It may not. For fun you can try a different outlet on the off chance it is not related to water damage. Good luck:) Farmerbear at FixYa.com
Sep 30, 2010 | Bissell 3522 PowerForce Bagged Upright...
I have a Bissell lift-off revolution. The power won't turn on at all. Tried different outlets. It doesn't work whether the lift-off canister is out of the frame or in the frame. The manual refers to a...
I have the same issue too. Brush motor is working and brush is turning on but the vaccum motor is not working. If I take the canister out of the frame then it wont turn on at all. Any help?
Jul 15, 2010 | Bissell Lift-Off(R) Revolution(R) Turbo...
While vaccuming it just stopped. Tried another outlet and checked power cord. Did find tube clogged with a dirt clog but no motor strain heard. Cleaned it out, Still not running
on the back of most vac's , u will find a red butten,use that to reset the vac. but even if that works u can avoid this usely buy ajusying the vac to a higher set . that helps reduse strian that the belt gets.
thanks
life's hand man
Mar 04, 2010 | Bissell 68001 Canister Vacuum
Bissell Proheat 2X Cleanshot won't turn on at all
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
fgfg
May 02, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell Spotlifter 1760 will not turn on
Unless you want to take it apart yourself and try to figure out the problem, I would buy a new one. This is obsolete and you can't get parts for it.
Mar 29, 2008 | Bissell SpotLifter 1716 Bagless Handheld...
Bissell Proheat
Things to check are the cord, switch, and the motor.
Mar 19, 2008 | Vacuums
Bissell 6594 PowerForce Bagless Upright Vacuum Logo
1,527 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
