If you have fuses on your electric panel it normally uses 2 fuses, 1 for electric power 1 for heat. The same may be true on the circuit board panel check this to eliminate this possibility
Thank you, I just had my box rewired. I will have the electrician check this out
Electrician just left. There is 249 at the outlet, the cord and breakers are good
From this point I would check the harness wire going to the heating element also remove the element and lolk for broken cokls in the element. good luck
The element is new as well.. Could it be the timer?
There are thre setting that would have heat on yhe timer Normal permanent press and delicate check each seting to rule out timer
None of the settings produce heat.
SOURCE: wiring
You are missing over $150 in parts. You can buy a working unit out of the newspaper for that or less.
All of the wires on those models have letters and numbers on them near the connectors at each end.
Go to the Sears Parts Direct website with your Model Number and you may be able to print out a wiring diagram, because that is what you will need.
SOURCE: dryer won't heat. I have
timer motor, here is a website that should help, Tim:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Hello, Before you replaced all those parts did you check each with a multimeter by performing an ohms test or measuring for continuity? By doing this it would tell if any of the parts that you had replaced were at fault. You can also conduct the same test on the heater as well. when performing any ohms or continuity test make sure the unit is unplugged and that you also unplug the part as well from the wires that are connected to it. I await your reply if you have any other questions. Thank you
Rick
you canchecj continuity on the timer.
