Question about GE JTP27 Electric Double Oven
GE JTP27WW Broiler Element won't shut off
I have a GE double Electric Over. The Boiler element is staying on and the only way to shut it off it at the house power breaker box. Whenever I switch the breaker on, the broiler element comes back on. When the first happened it resulted in an F2 error on the control panel. I installed a new control panel about 2 years ago when we were consistently getting an F2 error. However this issue with the broiler element staying on in a new problem. Could it also be related to the control panel or is there a relay somewhere that could be stuck that I need to replace?
  • bgilmore219 Feb 02, 2009
    Thanks I will replace the control board again. I also appreciate your indication that the area in which the control board is located is problematic in this model. It does certainly get hot in that location which I suppose contributes to its failure faster than otherwise would be the case if the system had been better designed.
  • 6,784 Answers
This can be a relay problem. the control panel that you replaced may have problems communicating with the original relay that was installed by the manufacturer. the relay may be frozen due to the conflict with the after market control panel. replacing this relay will fix your problem.
Posted on Feb 01, 2009
    President:
  • 2,559 Answers
Yes it is the control board again.(this is a common problem and is due to the mounting location of the control board.)
  • 11,896 Answers
YES there is a relay in these that do have a tendency of getting stuck.
  • 1 more comment
  • Nate Stansfield
    Nate Stansfield Feb 01, 2009
    You should test the relay with ohmeter to make sure it is working. Or just replace it
    According to the manual"
    F2 Error = Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor
    1. Replace oven temperature sensor.
  • Nate Stansfield
    The temp sensor won't make a difference of shuting of or staying on. IT IS YOUR RELAY CAUSING THIS PROBLEM!!! 100% POSITIVE
  • Nate Stansfield
    TO PROVE MY SOLUTION:
    .a burnt contact in the closed position on your clock/timer assembly.
    You would not get any codes because the clock is in the off position.
    If you would turn the unit on and set the controls to a bake position
    and 350 degrees, a code would appear very shortly after. The
    temperature would rise and the sensor, active now, would be sending
    signal to the control board and an error code would come up
My top broiler won't turn on. Everything else works fine. I have exchanged the top broiler element with the bottom. So I know it isn't the element.
Could be wiring. Did it work before? Maybe, never connected? Could be demand of two oven's and or broilers at the same time exceeded the wire and circuit breaker capacity when installed and therefore were never connected.
Otherwise thermostat. Probably need appliance Tec or Electrician.
Mar 04, 2015 | GE JTP27 Electric Double Oven
Will the oven work without the broiler attached
You could use the oven without the broiler. It is customary that the oven will use the broil element to even out the heat in the oven for better baking but you could use if. it just may not bake evenly. There could be two things that is causing the broil element to stay energized. the control is not shutting down or there is a short to ground in the broil element. Have the broil element tested, it could just need replacing. If it is in the control that is a bigger problem.
Mar 19, 2014 | Ovens
Whirlpool Range model RF386PXGQ2 broiler won't shut off
Hi.
If the element does not turn off, possible faults are:
Shorted temperature probe.
Test temperature probe reading impedance. If impedance is zero or lower than 0.500 Ohms, the the probe is shorted. A good probe reads about 1KOhms.
Contact at element. A contact in element wiring harness may cause the element to stay on. Do continuity test between ground and element and on wiring harness.
Defective control module.
If problem is none of the above, then it is the oven electronic control(ERC). The ERC can be tested reading voltages.
Testing must be done by a trained technician.
Dec 13, 2011 | Whirlpool RBS305PD Electric Single Oven
My ge jtp56woa1ww double electric oven will not bake in the top oven. broiler in the top oven seam fine. Lower oven functions great in both features. What to do?
Sounds like the bottom element, or element wire in the top oven is burned out, Check to see if the element is broken, or swollen. Two signs of a burned element.
Oct 08, 2010 | GE Profile JTP56 Electric Double Oven
Broiler element does not heat on ge jkp15bow2bb
ck the element and witing to control / then go to the control . elements are very common .. mm
Jul 14, 2010 | GE JKP15 Electric Single Oven
GE Double oven flashing F2
The f2 code means that the oven temp sencer needs to be replaced.
Sep 10, 2009 | GE Profile JTP56 Electric Double Oven
Broiler element comes on when "bake" is pressed
does the bake element come on at all?
if so, try the oven out. do a bake @ 350 allow it to pre-heat, and see if once the pre-heat is comlete, id the broil shuts off.
on many ovens at the beginning of the cycle during pre-heat both bake and broil elements are powered.
other than that it may be a control board, or a burnt and crossed wire in the harness.
May 28, 2009 | GE JTP15 Electric Single Oven
GE JTP27 Electric Double Oven Logo
184 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
