Question about Dell Inspiron 1501 Notebook
How to replace a laptop screen cover?
I have a burn in my laptop lid cover and have purchased a replacement part. How do I swap it. I have a Philips freevent x56
  • Dell Master
  • 32,281 Answers
The laptop screen is secured to the laptop with screws at the hinges.
There are usually two screws per hinge. The LCD screen has one ribbon cable and possibly a power connector for the back lighting attached to the motherboard near the hinges. Disconnect these before you lift the LCD off the base, they are under the plastic panel above the function keys next to the hinges.
Posted on Feb 01, 2009
  • 2,229 Answers
Here's the link to the Dell page where you can download the manual. You need the service manual--it tells you what you need to know.
http://support.dell.com/support/edocs/systems/ins1501/en/index.htm
ASUS U46E broken hinge
Replacing a hinge, or both of them, isn't very tough. Check out this WEB site.
http://www.insidemylaptop.com/replace-br... Replacing Display hinges for your laptop maybe available from thia WEB site.
http://www.laptopparts101.com/display-screen-hinges/
Aug 27, 2012 | ASUS Computers & Internet
Tip
HOW TO REPLACE ACER LAPTOP LCD SCREENS
READ CAREFULLY FIRST BEFORE STARTING
Removing the screens bezels will void warantee
In Saying that ,
Heres how I would do a screen replacement,
You will need a small philips screwdriver for this ...
Remove the power and battery
To Remove the bezel from the front of the screen
There should be 4 or 6 screws holding the cover on,
Screws may be covered by rubber buttons,
then remove the screws holding the LCD to the hinges' frame.
Tilt forward your LCD and lie screen on your keyboard
LCD panels have a row of IC chips at the top that produce the images on your LCD so do not touch or flex this area because it may produce lines on the LCD or kill it completely.
botom of screen is inverter power and plug to screen
top rear of LCD is video feed from motherboard,
(above that are those important IC Chips-
DONT TOUCH THE CHIPS)
LCD wiil have tape fastening plug to the socket,
Remove tape and this will expose the plug.
Un plug from screens socket,
Reseat plug back into socket,
Put Tape back on to stop any unwanted movements,
Next step is to power up the LCD to test.
Rest LCD in back of lid and lie lid on table with base at 90 degrees for access to plug in AC power.
do not use battery for this test.
Turn ON power,
If it starts up, then you have a running machine again,
Shut down , unplug power and reassemble,
If LCD does not start then you need to replace the LCD panel and thats about all you can do,
Hope this helps.......
Cheers MisterdJ
on Apr 12, 2010 | Computers & Internet
Hi, i am trying to find instructions (or link)on how to open (no screws) the a philips pronto TSU9600 and replace the screen. Also can you recommend the best place to purchase a screen?
The remote is lid locked and so you need to use a sharp device to SLIDE and open. The best place to buy a DISPLAY with warranty will be the PHILIPS SERVICE SUPPORT.
Check your nearest dealer but sometimes it is best to get this replaced by the service center as the cost might involve replacement cost.
Sep 26, 2011 | Philips pronto TSU9600
How can I access Satellite A215-S4747 hard drive to replace it?
Turn the laptop off, remove the battery and shut the lid.
Turn the unit upside down with the back of the laptop face away from you.
On the front left of the underside of the laptop you should see a panel with 2 philips screws, unscrew these 2 screws and remove the cover.
There you will able to access the hard drive for removal and replacement.
Regards.
Jun 29, 2010 | Toshiba Satellite A215-S4747 Notebook
How do you replace the screen on a Sony VGN-FW290
What you need is a copy of your service manual. This has the details on repairing , disassemble and full instructions to do so.
unfortunately the only one i could find is one you have to pay for
http://www.user-guides.co.uk/download/sony/sonyvaio/sony-vaio-vgn-cs215j-laptop-drive-loud.html
i dont have any pictures but the steps are outlined as follows.
1.) remove laptop hinges cover (the plastic thing that covers the hinges between the computer and the screen, the screen lifts on it).
2.) remove the screw hiders ( small circular plugs covering the screws holding the shield over the display unit)
3.) unscrew and unjack display screen.
.4) replace screen
5.) screw screen in place, replace lid, screw in place, replace screw plugs, replace hinge covers.
Thats it in a nut shell.
Mar 01, 2010 | Sony VAIO VGN-CS215J/W Notebook
My laptop was dropped & now the screen looks like it has been shattered. When it's off, you can't see it but turn it on & looks shattered with different colors.
You will just have to search for a new screen. They are not that difficult to change out. The people that said under warranty send it back. Well unless you purchased accident insurance on it, a cracked lcd is not covered. LCD just doesn’t crack from sitting and they will not cover them in most cases. It is considered miss-use or abuse. Replace the screen. If you are past your warranty, check eBay. Sometimes you can get a used screen for cheap. If you do that try to get it in the whole lid assembly, they are easier to replace that way. Check out the website for screens: http://www.screentekinc.com/
Thanks for contacting fixya.com
Nov 25, 2009 | Compaq Computers & Internet
Acer aspire 3620 lid broke and screen needs to be replaced
If a 'qualified' tech damaged the screen, then it is up to them to replace the screen at their cost.
You could try finding screws slightly bigger and see if they will realign and stop it from being floppy.
Personally I would go back to the tech and complain untill they repair it properly.
Hope this helps a little.
Nov 27, 2008 | Acer Aspire 3623WXMi Notebook
Shattered LCD screen on Dell laptop
yes you can replace the screen yourself but it can be quite difficult, you have to remove the panel accross the top of the keyboard, remove the keyboard and unplugg the monitor plug and wireless ariel wires locate the screws that holds the lid to the base and unscrew, remove lid.
Now you have to unscrew the bezel (front plastic cover) the screws are located under the rubber screw covers, take care when splitting the bezel from the lid, (use a small flat head screwdriver if you have to), this will exspose the screen itself, disconnect the power plug, behind the screen you will find a ribbon cable remove this cable with great care................ job done! now you can replace the screen and put it all back together
If you think that this could be difficult for you, them i suggest a repair engineer to do the job for you but it will cost
Nov 14, 2008 | Toshiba Satellite A15-S127 Notebook
Acer Aspire 5100 Series
You can buy parts for your laptop here. Scroll down to plastic casing for the lid and a bit below it is the LCD.
Jan 20, 2008 | Computers & Internet
How do I swap screens in Gateway 9300 Solo computer?
Before opening the laptops try easy things like swapping the memory. Also remove all cards underneath the panels you can get to (wifi. modem, etc) The machine will boot with just RAM inside it. This includes swapping batteries wich can cause failure. If you tried swapping basic parts. Video card and screens are the next step.
Replace the video card and the screen in the machine that  runs:
First, you want to get the two apart, the screen can be removed by locating the covers inside the lid where the screen is. Usually rubber feet or disc shaped plastic that matches bezel texture. slowly remove screws, also the hinges must be removed. The covers for the hinges usually pop off or are held be a screw in the rear of the laptop. The ribbon cable follows all the way down to the motherboard through one of the hinges, there is a way to guid it out of the hinge area. If you get lucky the screen cable connects to a
removable mini card which is your video card. The one with the
white screen may have a bad video card.
Jan 06, 2008 | Gateway Solo 9300 Notebook
Dell Inspiron 1501 Notebook Logo
463 people viewed this question
Alun Cox
