We just bought amana washer pulled the yellow shipping cord with one long cotter pin,,,,,,,,,filled washer and it will not spin has humming noise like something is holding it where is the location of other two cotter pins
  • 15,935 Answers
There should be 4 - 1 near each leg.... all with yellow tags. Don't discard the pins - as the unit should be re-secured if moved in the future.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 16, 2010
Nav5800aww
The motor sounds like it is overloading and kicking out. Most likely cause: binding brake pads.
Sep 13, 2013 | Amana NAV5800A Top Load Washer
Brand new amana washing machine NTW4500XQ0 unbalaced spin cycle how do I open to check springs
hi ,,if its brand new it most likely you have not removed shipping materail..its a yellow ******** back bottom of unit..pull it towards you that should release the legs along with tub...if unsure check the install book that came with unit...good luck [pull yellow strap all the way out ]
Sep 07, 2011 | Amana NTW4500XQ Washer
Vibrating on spin cycle.
If the machine is new there is a possibility that the shipping pin didn't come out completely. If you set the machine up yourself, there is a yellow plastic strap that holds in the electric plug. You need to pull, not cut this plastic strap as it has a pin that is about 8-10" long that goes through under the tub to secure the machine for shipping.
Jan 20, 2009 | Kenmore 23822 Top Load Washer
Bought a new whirlpool estate washer today. brought it home. pulled yellow strap and removed long straight metal pin. (evidently broke 2 shipping pins off because they fell into their little plastic cups...
this is poor delivery,,jostled unit,,,you just broughjt it so your under warranty ,,by the time i tell you what to look for,,the warranty tech will be out ,,its better to let them handle it,,,if you open unit it will void your warranty...
Jan 18, 2009 | Maytag PAV2300 Top Load Washer
Washplate problem Kenmore Elite Calypso washer
Hello genny2626
Welcome,
You said,your 6 year old Kenmore elite top loader's wash plate doesn't seem to go through its proper motions. When the lid is closed and the washer has filled and the agitating cycle begins, you can hear a vibrating noise as if the plate is trying to move on the gentle cycle, but when the lid is opened, nothing has moved at all. The drain and spin work fine, and the machine goes through an entire cycle without error messages, but the clothes aren't clean. You said, you have heard a lot of horror stories of how expensive these washers are to repair, so would like an idea of what's wrong beforehand.
Here are a list of common vibration noises
Noisy, vibrating, off-balance
 Is the washer level? Does the washer rock when pushed
against the corners?
The washer must be level. The front and rear feet must be in
firm contact with the floor. Check that the locknuts are
tightened. See “Level the Washer.”
 Is the floor flexing, sagging or not level?
Flooring that flexes or is uneven can contribute to noise and
vibration of the washer. A ³⁄₄" (1.9 cm) piece of plywood under
the washer will reduce the sounds. See “Location
Requirements.”
 Is the load balanced?
Evenly distribute the load in the washer basket and make
sure the height of the load does not exceed the top row of
basket holes. See “Starting Your Washer.”
 Do you hear clicking or other noises when the cycle
changes from washing to draining or spinning?
When the drive system shifts or the washer basket settles
between cycles you may hear noises that are different from
your previous washer. These are normal washer noises.
 Is the washer gurgling or humming?
Is the washer level? The wash load
should be balanced and not overloaded. The washer must be
level. The front feet should be properly installed and the nuts
tightened. Reset the rear leveling legs (if needed). See the
Installation Instructions.
Did you completely remove the yellow shipping strap with
cotter pins? See the Installation Instructions.
• Are the gears engaging after the drain and before spin, or
is the upper part of agitator clicking during wash? These
Let me know if any of these are the solution!
Huuum
Oct 13, 2008 | Kenmore Elite HE4 Electric Dryer
Frigidaire front load washer making a noise and jumping when going through the spin cycle. Why???
If this is a brand new washer, make sure the shipping materials are all removed, yellow shipping pins in back, styrofoam blocks etc. If this is an older machine, new problem, empty the machine, reach into the washer and give the basket a good hard spin, if you hear any type of grinding noise, or excessive rattling, your bearing and possibly the spin basket support are bad. I would also remove the top and front- bottom panel, and make sure the suspension springs and shocks are not broken before assuming the bearing, as this is a very lengthy and expensive job, (although the basket itself should have a lifetime warranty).
Sep 15, 2008 | Washing Machines
Kenmore 110.20904990 top load washer
ignore those cups with the pins those pins were the travel lock devices and the cotters were attached to the yellow lanyard that whoever first put the unit into service pulled off of the back of the unit per instuctions. this pulled the cotters out of the pins which then fell into those cups. the cotters came out with the lanyard and are long gone. the not spinning is due to something in the clutch not working properly. the moving to one side is caused by one of the pads that the suspension plate rides on being missing. you can look at the diagram on sears website at the parts look up and see were the pads go and find out what the suspension plate is and such good luck!
Jul 27, 2008 | Kenmore 22422 Top Load Washer
Brand new machine unbalanced (really unbalanced) during spin cycle. When unpacking there are two plastic "rip cords" that are supposed to remove a total of three cotter pins. Only one cotter pin came out...
oh yea sounds like there still in there alright!!!, tip the unit back if possible and give a look underneath, you see2 or 3( depending on model) plastic tubes approx 2in long mounted to the under carriage around the base. They are there for the sole purpose of "catching" the cotter pins after pulling the rip cord. there should be a cotter pin in each of the tubes. if you see any empty ones look directly above it and youll find the pin, you may have to manually grab the cotter pin to release it withe a set of needle nose pliers or something but the definitely need to be removed.
Mar 10, 2008 | Washing Machines
Moving a top load washer once used
if you have a wet dry shop vac you can pull all the water out through the drain hose till its dry don't think you would have any problems with the storage now shipping across country might be another thing when you got the washer new you had to pull the shipping pins a yellow tab with three cotter pins if you still had them you would need to replace them before shipping you would need to open the case and on the frame below the tub you will see three plastic cups with little pins in them you have to push them back up through the frame and replace the cotter pins to lock the lower frame to the upper tub frame or it wont ride good at all
Feb 12, 2008 | Kenmore 20172 Top Load Washer
UNBALANCED WASHER
Does it happen all the time, with no connection to laundry quantity? In case of a positive answer, it sound like a shock absorber issue. Could be that it's moved from its place or become malfunction and should be replaced. Good luck
Aug 07, 2007 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
