Question about Acer Aspire 5570-2758 Notebook
DAV-DZ111 - Region 1 DVDs not in focus
Region 1 DVDs were playing fine, but now out of focus (still in colour and sound good).....any ideas?
Dav-hdx665 only plays certain DVDs, why.
Check the region code. Or the laser beamer is dying.
May 07, 2014 | Sony Dvd Home Theater Remote Control...
Tip
Sony DAV-C700, DAV-S400, DAV-S500, DAV-S800, CMT-S9D region free unlock code
Introduction
The DVD Upgrade is an advanced modification to your DVD player, which adds extra features and enables you to get more from your machine. The upgrade supplements the DVD player and in no way harms the playback quality or removes any performance features of the machine.
Players Supported
The following DVD players are supported by this version of the DVD Upgrade:
 Sony DAV-C700
 Sony DAV-S400
 Sony DAV-S500
 Sony DAV-S800
 Sony CMT-S9D
Macrovision & CGMS disable
All DVD players have a system called Macrovision built in to the player, which is designed to stop the copying of DVD discs to video. However, this system can have adverse affects on some projectors. For this reason the DVD MOD Upgrade disables Macrovision to solve any problems.
User manual
Put your player into „Standby“ Mode and enter one of the following commands if necessary:
Remote control command Function
[0] [ENTER] Default Default region code on the player
[1] [ENTER] Region 1
[2] [ENTER] Region 2
[3] [ENTER] Region 3
[4] [ENTER] Region 4
[5] [ENTER] Region 5
[6] [ENTER] Region 6
[7] [ENTER] Region 7
[8] [ENTER] Region 8
[Arrow down] [ENTER] Only play DVDs with the selected region; auto switching OFF
[Arrow up] [ENTER] Default Auto switching ON
[PREV I<<] [ENTER] Enable video interference impulses (Macrovision ON)
[NEXT >>I] [ENTER] Default Disable video interference impulses (Macrovision OFF)
[Arrow left] [ENTER] Enable user operation prohibitions* and access restrictions
[Arrow right] [ENTER] Default Disable user operation prohibitions* and access restrictions
* The DVD can no longer prohibit you from using the fast-forward, chapter change or Audio-/Subtitle-/Angle switch. You can no longer be forced to watch intros. Just press [TITLE] or [DVD MENU] and select PLAY.
on Mar 02, 2010 | Electronics - Others
How do you convert a Sony dav-sb100 hone theatre system to be multi regional so it can play region 1 dvds?
It's a good idea to replace the remote batteries, so you can eliminate low battery power as a cause of the problem.
Feb 13, 2013 | Televison & Video
Won't play Region 2 PAL dvds
Here is the code..
1. Power on
2. Tray open
3. Push MENU
4. Push 8888
5. Push Display
6. Push in desired region 0-6, (0 is ALL REGION )
7. POWER OFF
8. REGIONFREE!!
Jay
May 20, 2009 | Coby DVD-257
WILL MY DVD PLAY AREA 1 AND AREAV4 DVD'S?
Hi camonk2004,
It's interesting that your DVD player was purchased in Russia but plays Region 1 DVDs. Region 1 is North America. Does your Player also play Russian DVDs (region 5)? If so, then it has probably been modified to play DVDs from multiple regions.
Check the back side of the DVD player - the rear panel should have a Region number on it. If the region number is 1, then try playing a Region 5 DVD. If it reads the DVD, then the modification that was done in Russia will probably allow it to read any DVD. IF the Region 5 DVD won't play (or if it is ejected automatically), then your player's region control os still intact, and it will only play DVDs from the same region as the one listed on the rear panel of the player (or DVDs marked "ALL").
I hope this helps - please let me know if I can be of any further assistance.
Kind Regards,
H2H
Dec 15, 2008 | Pioneer DV-U7 DVD Player
Sony DAV-HDX275
Region Free DVD can be playback on all Sony DVD Players.
Jul 24, 2008 | Audio Players & Recorders
'PLAYBACK PROHIBITED DUE TO AREA LIMITATIONS'
Check area code at your unit and usualy its printed at back side. If your unit belongs to code 1, it will play only region code 1 dvds and so on other codes.
Jul 23, 2008 | Sony DAV-IS10 System
SONY Model No: DAV-D150G DVD play problem!!
dav-dz100 a disc cannot be ejected and locked
Oct 06, 2007 | Sony DAV-DZ100 System
Acer Aspire 5570-2758 Notebook Logo
60 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
