Question about GE Wireless Optical Mouse
GE Optical mouse will not work - no pointer on screen
I have downloaded and installed the iWare v3.2 device driver, successfully installed and re-booted and still no luck. Maybe I am not linking the pointer and usb port device? They both have link buttons. Thanks for any help!
  • Anonymous Apr 29, 2009
    ge optical mouse will not move the curser on the screen. New batteries are in the mouse and the red light is lite on the mouse. Would I have this problem if I shut the computer off before removing the mouse?
    Genius:
  • GE Master
  • 1,102 Answers
Have you checked your mouse settings in control panel
and is the mouse compatible with your operating system
you can also update driver through device manager
and if you have a reset button on usb press it
Posted on Feb 01, 2009
My GE laptop retractable mouse now works only sporadically. The optical light flickers and it seems like there is a problem with the cord but nothing can be traced. It has been working fine till today. ...
click start control panel administration tool computer managenent device manager scroll to mice and other pointing devices you might see a yellow question mark? right click to update drivers
make sure the lead from the mouse has a secure seating and the lead is not bad/faulty
(if applicable)
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
hope this helps
May 25, 2011 | GE Televison & Video
My USB and windows vista does not recognize my new optical mouse from GE SKU# is 98543, my motherboard is an ASUS M2N-MX SE, my other optical mouse works fine but when i plug the RF receiver into the usb...
first check the battery inside the mouse make sure it is fully charged and well seated
make sure you have the right mouse selected click start control panel mouse hardware you will see which mouse is selected
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
also click start control panel administrive tools computer management device manager scroll to mice and other pointing devices you might see a yellow exclamation mark !or question mark ? or a red x right you will have options to update driver software,disable,uninstall,scan for hardware changes and properties hope this helps
Apr 01, 2011 | ASUS M2N-MX Motherboard
Got this at a pawn shop it lights up but will not control the pointer.
Install the driver, set mouse in Control panel > Hardware and device.
Feb 10, 2011 | GE Optical Mini Wireless Mouse 98793
Wont connect
in xp
hope this helps
Jan 22, 2011 | GE Wireless Optical Mouse
My ge wireless mouse is not working...it has good battiers the red light is on at the bottom and the stick is in the usb cable spot. not sure why it's not working. it just stopped working
control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot or select properties under driver you can update driver,rollback driver or uninstall
hope this helps
Nov 07, 2010 | GE Wireless Optical Mouse
I puchased a GE Optical Mouse with a USB connection (98529). After I plugged it in, I got the new hardware detected message, but it said "unknown device". The cursor would not move to allow any other...
You need to install the drivers that came with this GE optical mouse so that windows can properly install and identify the new mouse. Pop the driver cd that came with the new mouse into the cd drive and follow the instructions. If you need more help, let me know ok?
Aug 09, 2010 | GE Optical 98802 Mouse
Ps2 port doesn't recognize Microsoft Optical mouse
You might think about a USB hub for all your USB devices. ps2 port is more or less dedicated for mouse, which is why your mouse pointer is stuck in the middle of the screen. Go ahead and get an externally powered USB Hub to power other USB devices. To answer, ps2 for mouse needs just a mouse, not USB device.
Sep 28, 2009 | Microsoft Windows XP Professional
Logitech mouse - pointer moves but left clicking doesn't work
Download the latest drivers from this logitech site:
http://www.logitech.com/index.cfm/support_downloads/&cl=us,en
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 14, 2009 | Logitech 967461-0403-PK Keyboard/Mouse
MY GE WIRELESS OPTICAL MINI MOUSE POINTER MOVES ON ITS OWN
I get the same thing from a optical with cord.
Change the pointer speed. Look in Start > Control Panel > Mouse > Pointer Options.
Nov 24, 2008 | GE Wireless Optical Mini Mouse 3087897985
Frozen mouse pointer
I had same problem. While I have only recently "fixed" it, I'm not sure how long-term the solution is, yet. From control panel, double-click mouse, select the "Hardware" tab and choose "Properties" button. Select the "Advanced Settings" tab, and lower the "Sample Rate" to 60 reports/second. Mine was set at 100 r/s. I also increased the input buffer to 120 (having no idea of what a normal buffer size might be). Anyway, on reboot, it worked (which is significant progress, since every reboot before, I had to uninstall drivers, remove mouse cord, scan for changes, plug in mouse, then scan for changes again, /sigh). Good luck.
Oct 09, 2006 | GE ho97986 Mouse
GE Wireless Optical Mouse Logo
252 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
