Question about LG LS-K1830CL Cool Mini Split Air Conditioner
Airconditioner LG LSk181-N2 shutting off
On cool mode the aircon switches to what seems like fan then turns off after a few minutes. the outdoor fan speed is slow.
  • Anonymous Mar 04, 2009
    I got a repairer in and LG split systems have not been handling the 40-45 degree heat in Adelaide a few weeks ago. It was the capacitor that was gone. Same problem he said for 95% of his LG split system call outs!
  • Anonymous Mar 19, 2014
    Aircon trying to turn on to cool but soon turns off
  • 400 Answers
Sounds like your aircon is stuck on heating mode. Or. The outdoor fan speed is affected by ambient temperature, or low refrigerant. In heating mode the indoor fan will come on for a while to sense temperature and will then wait for the outdoor unit to pump up pressure and build up heat.
Posted on Mar 04, 2009
I have a Rover 75is it normal for my engine fan to come on high when i turn on my airconditioner
typical set up is two fans in engine bay
engine cooling fan is separate
air con fan runs flat out when air con is on to cool condenser
Apr 28, 2017 | Rover Cars & Trucks
Air conditioner fan wont start
change run capacirotor of outdoor fan motor.
Jan 07, 2014 | LG LSC121PMA Split System Air Conditioner
Not cooling and shutting off, indicator light flashes
the outdoor indictor light on my lg split comes on after some minutes on the one inside and the cooling has reduced please can any1 tell me what the problem is
Jan 18, 2013 | LG LSC121PMA Split System Air Conditioner
My air conditioner stops cooling. Occasionally, it will just function on fan mode even though I confirm that it is on cool mode. Warm air comes out even on the absolute coldest setting. I have to turn it...
If after reset the A/C cools then the fault seems related to the thermostat or the cut off pressure switch or load cut off.
However is there is no cooling at all the compressor and the gas pressure- check for leak if gas is absent.- must be checked .
If compressor is suspect you must check the estimate and decide whether it seems better to scrap and buy a new one.
May 18, 2011 | LG ZW6500R Air Conditioner
I addred coolant to the AC unit a few weeks ago and it has been running fine until last night. I went to check the pressure and make sure the line was not frozen this morning since the indoor air climbed...
It is just coincidental that the fan motor died now...
Replace the condenser fan motor and you will be good again...
Here is a tip about troubleshooting your airconditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Apr 20, 2011 | Carrier 38CKC036 Air Conditioner
Model #LG LWHD1500ER The fan to cool no longer runs on the low speed. It will just humm. On "energy saving mode" the unit does not always turn on to cool. On the "cool mode" when the fan is on high it...
www.appliancefactoryparts.com/content/.../118816.pdf - United States
Above is your service and repair manual, with this you will be able to troubleshoot and repair your Aircon.
I suspect, your thermostat may have a faulty sensor?
factoidz.com/troubleshooting-your-air-conditioning-thermostat/
http://www.inspectapedia.com/heat/Thermostats.htm
Below is a DIY AC, troubleshooting how to. http://www.repairclinic.com/Air-Conditioner-Troubleshooting
Jun 26, 2010 | LG LWHD1500ER Wall/Window Air Conditioner
LG 8008R compressor runs one minute then fan blows 3 minutes
You need to have an AC tech come out and do some preliminary testing on this.
May 12, 2017 | LG Heat cool Window Air Conditioner
Split unit, I get heat but no cold
I have run into this with the LG brand systems. try shutting power off to the outdoor unit to reset all units. If problem persists, it could have to do with a charge level of refrigerant (freon) or possibly a failed control board.
May 16, 2009 | Fujitsu 24R1 Air Conditioner
MY AIRCON OUTDOOR MODE IS ON...AND ITS NOT COOLING
Apparently the outdoor fan is on.
Verify that the compressor is on.
Could be a bad capacitor or a bad compressor or justb a bad wire.
Check the refrigerant charge.
Low refrigerant= no cooling.
If the compressor is running refrigerant pressure on the low side (suction side)should be at least 68 pounds of pressure.
Mar 03, 2009 | LG GL6000ER Air Conditioner
Sudden brownout
hi,
it has a small microcomputer which will shut off if /or error if the voltage parameters are too far out(brownout,surge) carriers are a higher end machine, better parts, should be fine..
jm
Jul 27, 2017 | Carrier Heating & Cooling
LG LS-K1830CL Cool Mini Split Air Conditioner Logo
447 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
