Question about Frigidaire Electric Dryer
I think I need a new belt for my Frigidaire Gallery FDE847GES0 dryer but need help getting the back off of the dryer. Do I need to take the screws out from the inside to get the dryer apart to access the belt?
  • 547 Answers
Try taking front off dryer you may find it easyer
Posted on Feb 19, 2009
My Frigidaire dryer model # FDE847GES0 spins and heats. When it stops to change direction, often it wont start back up. Some times it does, sometimes it wont. What is the cause of this?
Good Afternoon Friend,
I understand that your Frigidaire dryer, model# FDE847GES0, spins and heats. I also see that when it stops to change direction, it is intermittently starting back up. There are numerous possibilities that can be causing this. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your dryer as well as determine what the cause of your appliance not starting back up after it changes direction. I hope this is helpful.
-Best Regards-
WP
Jun 18, 2014 | Frigidaire Dryers
Frigidaire gallery heavy duty dryer
Good Afternoon Friend, thank you for your question!
I understand you are seeking a replacement dryer belt for your Frigidaire laundry center, GLET1031FS. The replacement dryer belt part number that you would need to order is 137292700.Most parts can be purchased directly from the manufacturer or through a parts distributor in your area (part numbers may vary based on distributor). Hope this helps! - Z
May 19, 2014 | Washing Machines
Frigidaire Gallery 5.8 Cu. Ft. Gas Dryer GLGQ2152ES There are two issues. One, is that clothes are getting caught and ripped by the dryer. Only once was I able to see where it was caught. Usually...
Yes it us the drum. I am thinking that it is one of the rollers/coasters that keep the drum up against the back of the dryer. In order to actually see if this is the problem we will need to take apart the dryer.
1) unplug dryer
2) open dryer door remove all screws
3) with a flat tip screwdriver gently pry on the two top corners(clips inside) until it pops
4) pull panel forward as we will need to disconnect the door switch
5) set panel aside (oh remember to put screws into a container)
6) lift up on the top panel til a 90, it is hinged won't fall
7) take careful notes of the routing of the belt, draw it out, take a picture etc.
8) remove belt(notice it was centered)
9) lift up and out on the drum
10) the rollers/coasters are bolted or should be to the back wall of dryer, and of circle shape. More then likely they are not.
11) Call an appliance parts store tell them what you need, remove bad rollers if need be take them with you.
12) replace rollers
13) re-insert drum making sure lip is behind new rollers
14) consult drawing/pictures of belt routing
15) route belt
16) notice belt is in middle of drum and drum can be turned by hand
17) find front panel, re-attach door switch
18) let top lid done and push it should click back
19) find screws
20) plug in dryer
Good Luck Tim
Sep 22, 2010 | Frigidaire FEQ1442ES Electric Dryer
Thermal Limiter
The belt on the drum my be broke
Aug 04, 2009 | Frigidaire Electric Dryer
FWT445GES1 Washer makes loud banging noises like it's going to explode.
Washer- you need a complete tub and bearring kit. this is a common problem for people who have well water. (also just happens) the rear yoke has become corroded and broken. its a costly repair.
dryer - you would need a new front slider seal. very simple to install.
May 28, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
How to open up Frigidaire GLE0332CAS2???
Try this link, the first one the maytag one has the actual instructions, all dryers a pretty similar you just have to route the belt according to the diagram!! Good luck,, ps a good rating would be nice! thanks
http://fixitnow.com/wp/2004/08/19/appliance-repair-revelation-how-does-that-dryer-belt-go-back-on/
May 07, 2009 | Frigidaire GLEQ332A Electric Dryer
Frigidaire combo washer/dryer screws inside come off
The drum shaft came loose from drum. You can YouTube it for procedure of disassembly of dryer. Remount shaft, if screws are bad may need new shaft with screws, make sure it is tight to drum. While you have it apart you can clean out lint.
Sep 27, 2017 | Frigidaire GLER331A Electric Dryer
Need to know how to reattach the dryer drum
ouch budddie...happy new year ...looking in the dryer are you taking about those there center mass,,,if that attactes the back bearing surport to the drum...,,if that the two parts which i think your talking about ..you have to take the drum all the way out,,because those three screws are shape like a piece of pizza....it will never line up with drum in...
Jan 01, 2009 | Frigidaire Dryers
Dryer belt replacement
Take the top panel off by slideing a putty knife about 2 inches in at the front and releasing the tabs. remove screws from top of front panel after top removed. also remove 2 screws from inside of front panel on both sides about 4 inches down screwing back into front panel. pull front off and slip belt through opening. Feed belt around drum and put tension on the idler spring release onto belt. reassemble unit.
Aug 09, 2008 | Frigidaire AEQ7000ES Dryer
Frigidaire  Electric Dryer Logo
188 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
