Question about York Yankees Bedding MLB Comforter
Condensation from small blower shorts out circuit board.
I have a York Stellar Plus High Efficiency Gas Furnace Model # P2UDD20N09501C. It has a FASCO Swirlwind High Performance Blower There is a 2" PVC pipe coming out of the top of the blower. There is some black plyable sealant around the joint where the PVC pipe joins the blower. Water drips out of that joint anyway, and runs down into a metal box with several computer chips or circuit boards in it. The metal box is below the blower. The computer chips eventually turn green and short out. At that point the furnace stops working. The York repair man has twice replaced the computer chips, but has not addressed the water which is the cause of the problem. Can I just add more sealant to prevent the leaking?
Thank you in advance for your reply.
Clifford Spencer
  • 3,238 Answers
Hi i would reseal it remove and re do joint should do it
Posted on Feb 01, 2010
  • 478 Answers
Put a plastic bag over the control board that will allow it to breath. you can add sealant to joint but you should clean the old off first. Then use some cork tape after sealant dries. You may also use pvc glue but it will never come out after that, but can be cut w/ saw if that becomes nessary.
Posted on Mar 12, 2009
Is there a high effecency furnace substitute?
small dual gas turbine and use electric heating and supplies your home also ....
Apr 19, 2015 | York Furnace Draft Inducer Blower Fasco #...
Gas central heater
The "mother board" or integrated control module is essentially the brain that controls the sequence of operation in your gas fired furnace. It is located, generally, in the blower compartment. That is the bottom of the two compartments of the in the furnace. It looks like a circuit board with all the wires of the furnace leading to it.
Feb 28, 2014 | York Furnace Draft Inducer Blower Fasco #...
York furnace 7 flashes
If the light flashes red 7 times, the furnace is not sensing flame. Check for a flame sensing rod (small steel rod in the path of the main burner flame). If you can see it, shut off the furnace, and clean the rod with a rag soaked in vinegar. Turn the furnace back on and see if this cures yyour fault. Make sure you turn the power off to the furnace and then back on as this will reset the circuit board.
Jan 05, 2013 | York Furnace Draft Inducer Blower Fasco #...
Just replaced inducer motor, runs great but furnace will not ignite
Check the pressure switch and the little hoses going to the pressure switch. If the pressure switch does not get a vacum from the blower it will not let the furnace light.
Heatman101
Mar 03, 2010 | York Furnace Draft Inducer Blower Fasco #...
My York Stellar PLUS furnace (Model P2UDD12N07601C) will not stay on; The ventilator fan runs, the main blower runs, the igniter comes on for approximately ten (10) seconds and you can hear the gas valve...
Check gas pressure, inspect manifold & make sure there is not a blockage.Make sure gas is present and main gas shut off valve to furnace is on also check the knob on the 24 volt gas valve and see if it is in the on position , check the MV terminal on the gas valve to 24 volt common with a volt tester to see if you have 24 volts present, if you do have 24 volts at gas valve, replace valve. if you do not have 24 volts at gas valve check high limit control & roll out limits for a open circuit, Good luck.
Feb 20, 2010 | York Furnace Draft Inducer Blower Fasco #...
I HAVE A YORK STELLAR PLUS,MODEL PEUDD12N09501C 15 YEARS OLD. THE AIR INDUCTION MOTOR RUNS FOREVER. THE AIR INDUCTION MOTOR COMES ON , THE THE THERMOSTAT CALLS FOR GAS, THE IGNITOR LIGHTS THE GAS, FURNACE...
Check the filters first, then check for blockage in the return or supplies. An easy way to do this is by putting your hand in front of the vents to make sure accurate airflow is there. Your furnace has limit switches on it that detect heat, and if heat is getting trapped inside the unit to much, you will trip these switches and the blower will just run forever. Then you have to reset it or wait forever. But try those few things first. Hope this helps.
Nov 26, 2009 | York Yankees Bedding MLB Comforter
York diamond 80 hvac blower and comp wont start on automatic
Need blower motor for York Diamond 80 Furnace I am in St Louis MO where can i get one
Jun 20, 2009 | York Furnace Draft Inducer Blower Fasco #...
York Yankees Bedding MLB Comforter Logo
943 people viewed this question
Top York Sport & Outdoor - Others Experts
Paul Carew
obsteiner
ray gallant
Are you a York Sport and Outdoor - Other Expert? Answer questions, earn points and help others
