Question about Western Digital Passport 160GB External USB 2.0 Hard Drive - Black
High Speed USB controller
I'm trying to connect my External Hard drive and I get the message that I need a High Speed USB port. How to I upgrade the USB port to a High Speed USB controller?
  • Satin P
    Satin P Feb 08, 2009
    The only thing is that I already have something in the card slot. I have my Linksys wireless internet card in there. Is there a software that can be loaded instead.
  • 45 Answers
You can purchase a high-speed PCI usb card. These are generally inexpensive and can be found at best-buy or perhaps walmart.
Posted on Feb 02, 2009
  • Nick Arrain
    Nick Arrain Feb 09, 2009
    Unfortunately you cant upgrade them with software. Sorry about the inconvenience
Recently, when I insert a USB flash drive into my laptop's USB port, I get the message: This USB device can perform faster if you connect it to a HI-SPEED USB 2.0 port.
Your laptop has USB1 port and the USB 2 message will appear if you plug an USB 2 device into this USB port.
You maybe able to upgrade the USB port to USB 2 if there is a BIOS upgrade available from the laptop manufacturer's WEB site.
If not you maybe able to get an USB 2 PCMCIA card to install into the PCMCAI slot on your laptop.
Dec 04, 2012 | Computers & Internet
I have a seagate external drive of a capacity of 250GB. the free space available is 177 GB. the hard disk is very slow? please help?
Are you connecting this high-speed ("USB 2.0") device to a low-speed ("USB 1.1") USB-port on your computer? If so, and your computer has a "USB 2.0" port, connect your device to that port.
If not, then purchase an add-in PCI card for your computer, to add "USB 2.0" port(s).
Nov 10, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Not recognized by 2tb hitachi simpledrive
USB ports on computers can be either the older '1.1' speed, or the newer (and much faster) '2.0' high-speed.
Your external drive is capable of using the high-speed USB 2.0 interface, but you connected it to a USB 1.1 port on your computer.
So, you can either "live" with the slower speed of a 1.1 port, or you can "upgrade" -- add hardware to your computer to add USB 2.0 ports -- so that the external drive will be over 7 times faster.
May 30, 2010 | Apple Powerbook G4 1.33GHz 512mb 60GB...
USB's slow and external drive
For the USB ports, you may want to verify that the drivers for the "enhanced USB" are up to date and for USB 2.0 or 1.1. USB 2.0 ports are generally backwards compatible for 1.1 devices. The "enhanced" does indicate USB 2.0 controller. 30mins to backup 3GB to your external drive is a VERY long time. USB 2.0 transfers data up to 480mbps, but if you get an error message indicating that the device can perform faster on a 2.0 port, you maybe transferring data at 12mbps which is USB 1.1 speed
To speed up the transferring of data, identify which USB contoller in Device Manager is the USB port you're having a problem with, and delete it from Device Manager. Then, plug in your external drive into a USB port its never used before.
As for the naming of hard drives, Hitachi partners with several drive manufacturers including Dell and IBM.
Feb 22, 2010 | Philips Computers & Internet
Usb does not recognise external hard drive
try using all available USB ports......or install chipset driver of laptop...do reply back
Oct 05, 2009 | Toshiba Tecra 8200 Notebook
USB External Harddisk Detection Problem
some people say that its because of not enough power . try inserting the hard disk in other usb slots ( at the back ). onlu usb slots at the back of my pc detects my hard disk
Aug 06, 2009 | ASUS M2N-MX Motherboard
External HD not recognizing USB ports as being Hi-speed ports
I have the same issue. I have 4 Simpletech Signature 250GB drives. They all worked fine at first. After about six months two of them started connecting at USB 1 speeds. It occurs on 4 different computers!!! The post about it being the computer assumes is wrong. How can it work fine for six months and then suddenly change. Also it occurs on different computers. I have submitted a tech support request with simpletech and will post the results.
Jun 14, 2009 | SimpleTech Signature Mini 160GB External...
Dell Latitude CPx H - USB controller upgrade??
May be your system is not supporting usb 2.0.That's way your dvd writer is not functioing at higer speed.To get the advantage of latest technology like this,ultimately u need the latest motherboard .Instead of upgrading your hard drive,Ram and other compnents u should have gone for a new laptop .Cost wise also u could have got full satisfection.
Jul 14, 2008 | Dell Latitude CPX Notebook
Zippy USB external hard disk case (2.5
I know this is an old thread, however if it helps any one try this:
Zippys power supply failed for me also. The problem here is your case support USB 2.0 ("A high speed USB device") and your port is only USB 1.1 ("plugged into a non-HI-SPEED usb hub"). This will not give adequate power to the drive. So use a y-cable (http://www.toshibadirect.com/images/ui3/accessories/toshiba-usb-y-cable-ba82010-300.gif) and connect one end to your casing and the two pins at the other end should be connected to two USB ports. (get it at http://www.toshibadirect.com/td/b2c/adet.to?poid=438342).
Another costlier way is to upgrade to USB 2.0 by a card like this http://www.belkin.com/support/download/download.asp?category=1&lang=1&mode=
or even better a USB 3.0 card : http://www.asus.com/product.aspx?P_ID=lGYmelQ8mJvPtYTv
Jan 28, 2008 | Computers & Internet
Western Digital Passport 160GB External USB 2.0 Hard Drive - Black Logo
155 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
