Question about MSI PM8M-V Motherboard
Is my MSI PM8M-V AGP or PCI???
I can't find out where it says, all help is appreciated in advance!
  • DEKR
    DEKR May 11, 2010
    what exactly are you looking for
  • 2,229 Answers
Your board supports AGP 8X
bg
Posted on Feb 01, 2009
  • MSI Master
  • 4,806 Answers
Hi there
Graphics support is AGP (66MHz) for 8x/4x mode for that model motherboard.
Thanks for using Fixya!!!!
The back panel of the motherboard is not working but when I test the memory its ok and when I put the video cord in the back panel there's no display. and I try to put a video card in the agp or p
Hello download the manual here:
http://www.msi.com/product/mb/PM8M-V.html#/?div=Manual
Look here also:
http://www.tomshardware.co.uk/forum/261145-13-perform-steps-posting-boot-video-problems
Check the power supply, and all your power connections again.
Try to reset the cmos by removing the battery, and inset it again.
Look also for bad caps on the mainboard:
If they look like this,scrap the mainboard.
It does not pay, to let them be changed.
Good luck
Jan 21, 2013 | MSI PM8M-V Motherboard
Can i chage my processor pentium 4 to core2duo my motherbourd is(MSI PM8M-V H (MS-7104 v2) thnkz
No, you cannot upgrade to a core 2 duo with that motherboard because it is a socket 478.
Jun 04, 2012 | MSI Computers & Internet
Motherboard Name MSI PM8M-V H (MS-7104 v2) (3
MSI PM8M-V is a VIA UniChrome P4M800-based, PC motherboard. Form Factor: Micro ATX. Compatible with Intel P IV and Celeron. Maximum Bus speed would be 800MHz. Maximum RAM Supported is 2GB.
If the specifications differ please inform me.
Thanks for contacting Fixya! Please rate the answer if it solves your problem.
Jun 05, 2010 | Computers & Internet
ATI RADEON X1650 512MB DDR2 AGP not detect on my MSI PM8M-V
I have checked you motherboard and the graphics card you mention is supported by your board. See the direct link to the msi website and save it to favourites. http://www.msi.com/index.php?func=proddesc&maincat_no=1&prod_no=205 More help? chris http://www.motherboardsrus.net
Jun 05, 2009 | MSI PM8M-V Motherboard
MSI pm8m-v on board grapic
Onboard graphic will be disabled automatically if there is a graphic card in AGP slot.
Mar 19, 2009 | MSI PM8M-V Motherboard
I want the instalation for vga carrd compatabile at motherboard msi pm8m-v plz... thank you very much
I tried to look up you manual for *********** board but I would have needed the CPU socket and the type cpu either AMD or INTEL. so I am answering w/o the info. If your motherboard  already had an VGA video card Either AGP,PCI or PCIe. on a slot all you have to do is buy the same type of card, plug it in where the old one went, install the sofware that came with it, including the driver.
If you are tryign to install a present card. Go to the manufactors website of that card ,download the software and driver and instal the same. Write back with more details and we can  provide  more specific directions.
http://global.msi.com.tw/index.php?func=downloadindex
Jan 05, 2009 | MSI PM8M-V Motherboard
MSI PM8M -V shaking/vibrating screen
Check the cable connection from the monitor to the computer for bent or damaged pins in the connector. Make sure it's connection is secure.
No problems found there?
try resetting your LCD or CRT monitor. Some CRT's can be degaussed, if yours can - try that.
LCD's, choose factor reset otion if available.
Still no luck?
Right click on the desktop and go to properties, then to settings, then to troubleshoot. Slide the hardware acceleration slider all the way to the left. Click OK.
If that doesnt solve your problem then you could have a bad video card or Monitor. If your video card is on your motherboard, try installing a PCI or AGP card ( if your system is AGP capable )
If you still have the shaking, you should start shopping for a monitor.
Hope this helps,
PC REPAIR
PC REPAIR
Oct 12, 2008 | MSI PM8M-V Motherboard
HIS HD 2600XT iceQ trubo 512mb AGP
I see no reason for the 2600XT not to run on your board.
Mike
Oct 07, 2008 | MSI PM8M-V Motherboard
Graphics cards
Hi noxiney, you're MSI motherboard does have 1 opened AGP 8x4x slot. You can install & run the ATI Radeon X1650 PRO AGP. You can not run PCI-Express because there are no PCI-E slots on the board. There are PCI (White in color) on the board but the AGP slot is much faster than the PCI (White in color slots). The manual states the AGP card can only support 1.5volt video cards & not 3.3volt AGP cards. (Keep this in mind when looking for an AGP card).
Below is a link to a bunch of AGP 8x4x video cards. One or two include DDR2 memory. Carefull where you buy. Check the warranty. (Longer is better). The first one on the list would be compatible. Its not DDR2 but it does have 512MB of memory.
http://www.google.com/products?hl=en&q=AGP+ATI+Radeon+X1650+PRO&um=1&ie=UTF-8&sa=X&oi=product_result_group&resnum=1&ct=title
This card is 1.5v compatable.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3101648&CatId=318
& this is compatable.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1642902&CatId=318
Just remember, if the card can run both 8x & 4x it should support the 1.5volt needed to function on the MB.
Enjoy!
Mike
Jul 08, 2008 | MSI PM8M-V Motherboard
Do I need a video card for this mainboard?
Since you have able to connect your monitor to the board it means that it has a built in video on the mother board but there's no display on the screen if that's the case there's a possibility that the built in video is not working fine, so I'm suggesting you get a AGP video card because its really better not to use the built in video.
Jun 16, 2008 | MSI PM8M-V Motherboard
MSI PM8M-V Motherboard Logo
152 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
