Question about Amana In Wall Install Kit For Digismart Ptac Units - Wall Sleeve, And Grill
My amana ptac is not heating....the code "np" is displayed....how do I correct this...we just installed the unit and know little about operation. Thanks
  • 3 Answers
I don't see this error code in the manual. I do see nP as an error code for Window Switch lockout. I just had this happen to me and they had me reset the control board.
Remove case, flick master switch to OFF for 10 seconds. Press Heat/Cool same time turn switch back on HOLD until off light comes on.
You should be fixed. Just had to do this for my unit. I was playing around with the settings and turned on the window switch option by accident.
Posted on Nov 19, 2014
SOURCE:
oscarn
  • 110 Answers
SOURCE: ptac fan keeps blowing
Try setting the fan control to "AUTO" this will cause it to cut out with the compressor.
Posted on Sep 07, 2007
  • 49 Answers
SOURCE: Amana PTAC
Sounds like if this is a heat pump, maybe it tripped out on high pressure. Maybe just unplugging the system may reset the control boards. This maybe due to a dirty filter or dirty evaporator coil.
Posted on Nov 18, 2007
  • 6 Answers
SOURCE: amana ptac shuts on and off constantly
your control board is shot and your ac can't tell the room is cold enough. 1-888-855-9987
Posted on Sep 09, 2008
  • 26 Answers
SOURCE: Remote Thermostat
call the amana dealer nearest to you order one
Posted on Nov 27, 2008
SOURCE: looking for manuel reset on heater amana ptac
I have a Amana PTAC Model PTH153A50AC with the DigiSmart upgrade kit (DSUK01B) which as of last night stoped generating heat. I tried the Diagnostic and got a "LF" displayed. But I find no reference to what LF means. HELP please. Also I looked but can't find a reset button either.
Signed
House without heat
Posted on Jan 31, 2010
I have a new Amana PTH15E PTAC. When heat is used, sometimes is quite but sometimes sounds loud (like window AC), why?
when its quiet its the electic heat thats being used when its loud its the heating pump and the heating pump is what saves you energy and they can be a little loud when its on its normal. I work on these units at a hotel
Jan 02, 2011 | Amana PTH123B25AJ Heat Pump Air...
I have thru-wall PTAC Amana PTH093B35AM unit. I
see if you can find a new board the power failure fried it
Jun 19, 2010 | Amana PTH093B35AM Thru-Wall/Window Air...
Looking for manuel reset on heater amana ptac unit heat won't come on new control board
I dont know about this model but in general electric heat wont have a reset button the heat is controled by a sequencer and each elememt has a safty limit switch incase the sequencer sticks in the on mode here is a link to where you can get more info on this model http://www.fixya.com/support/p51773-amana_ptc153b35aj_air_conditioner
Oct 30, 2009 | Amana PTC153B35AJ Air Conditioner
How do you override the FD in the Display of the Amana PTAC
I just had that problem of having fd display and it locks everything up. makes sure you check the ds1 and ds2 and ms1 and ms2 if these are shorted then you will get that problem. I had to wiggle the wires in the connector and it worked as soon as i pushed on the right wire. They apparently are very sensitive.
Jun 09, 2009 | Heating & Cooling
I HAVE A AMANA PTH153B50AE PTACT UNIT. ANOTHER
Do you think you have a heat pump outside ?If so then I would call the installer back and show me how to operate the control.They should have did that when it was install.
Apr 06, 2009 | Amana PTC153B50AJ Electric Heat Air...
How to disable the energy saver of the amana ptac unit. Once the AC reach the lowest temp on the room , the unit turn off, then when room temp raise it turn on.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=PTH153B50AJ&siteCd=AMA
This is the link to find the manual for your unit. Make sure the model number is correct. You should be able to find the info you are looking for if it is possible to disable the energy saver. Hopefully this will help.
Mar 20, 2009 | Amana PTH153B50AJ Heat Pump Air...
Amana PTAC ptc093d35ar, when i switch to remote t-stat i get a H1 code in the display. Can you help??? Joe
H1=High voltage protection engaged. Power supply voltage is too high. Check for incoming power at correct voltage.
Jan 20, 2009 | Amana PTC093B35AE Air Conditioner
Need parts for an Amana PTH123A25AA PTAC
The Amana parts line # is 1-800-227-2919, you can also obtain parts numbers and names from their website, www.amana-ptac.com.
Please rate this answer and let me know if this helps.
Dec 13, 2008 | Amana PTH123B25AJ Heat Pump Air...
Amana In Wall Install Kit For Digismart Ptac Units - Wall Sleeve, And Grill Logo
1,710 people viewed this question
Top Amana Heating & Cooling Experts
Donni Steen
Bill Long
Dennis Boxerman
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
